What is the Role of J in Complex Numbers and its Use in Electrical Engineering?
  • Context: Undergrad
  • Thread starter Thread starter cmcraes
    Difference
The discussion centers around the role of the imaginary unit J in complex numbers and its application in electrical engineering, contrasting it with the use of i in mathematics and physics. Participants explore the definitions, implications, and historical context of these notations.
  • Historical
  • Some participants assert that i is the square root of -1, while J is sometimes claimed to have J^2 = 1, leading to confusion about its meaning and use.
  • It is noted that electrical engineers use J for the imaginary unit to avoid confusion with the symbol i, which represents current.
  • One participant suggests that J is a thought experiment or inspiration in mathematics, indicating that it has no conventional mathematical relevance.
  • Another participant introduces the concept of split-complex numbers, where J can be defined such that J^2 = 1, suggesting a different mathematical context.
  • There are mentions of quaternions and their relationship to J, with discussions about the algebraic properties of these numbers.
  • Participants discuss the historical use of J by electrical engineers, referencing Steinmetz's work in AC circuit analysis.
  • Some express confusion about the distinction between J and i, particularly regarding their use in physics and engineering contexts.
Participants do not reach a consensus on the role and definition of J versus i, with multiple competing views and interpretations remaining throughout the discussion.
There are unresolved questions regarding the definitions and implications of J and i, particularly in relation to their use in different fields and the historical context of their adoption.
This discussion may be of interest to students and professionals in mathematics, physics, and electrical engineering, particularly those exploring the nuances of complex numbers and their applications.
cmcraes
I know that i is the square-root of -1 but I heard that J^2=1
I was wondering what J is, why it isn't equal to one and what its used for, thanks!
Where exactly did you hear this?
Mathematicians and physicists:√-1 = i
Electrical engineers: √-1 = j (they use i for current)
this is where i heard it
No, j2 = -1.
In the context of this thread, i and j are the same thing, the imaginary unit. As you already mentioned, engineers use j because they already use i for current.
okay thanks, i guess the video was wrong
Yeah, the guy definitely said j2 = 1, but j ≠ 1 (which leaves the only other possibility, which is that j = -1). So he didn't know what he was talking about.
One of the wonderful things about the internet is that even idiots can post!
*This is wrong, read lower, j can be expressed as a split complex number that has mathematical importance
So j is confusing because it's also used by physicists because they use I for current. But Henry and Vi from MinutePhysics and ViHart respectively aren't wrong in their appreciation of the number j. j is not a conventional whole number or complex number, and in fact it has no mathematical relevance. To a budding mathematician, j is a simple thought experiment, or perhaps better stated, an inspiration. In the same way that i was regarded as nonsensical because root(-1) should have no solution but in the end has had huge importance in higher level mathematics and physics, j is a prompt to remember that there is more math, more math languages, more operations to be discovered/created. Its a reminder to be unconventional. j^2=1 but j is not 1. Its just an example to think beyond.
You do realize that the split-complex numbers are a thing in mathematics, right?
Split complex numbers- okay, maybe I was wrong. When I tried to dig up info on j=root(1) and j=/1, I didn't get anywhere. Thanks for giving me a name to look for.
confusion?
Do you mean j2=1 or -1
Or do you mean the axises i^.j^,^k
It's j2, not j2, and j here refers to the hyperbolic or split-complex numbers. See the link provided by pwsnafu in post #10. The hyperbolic j is a quantity that is independent of 1 but whose square is 1. Note that -1 is not independent of 1.
Perhaps the easiest way to envision what this hyperbolic j is is to look to the quaternions. Here there are three independent quantities, i, j, and k, each of which when squared yields -1. These i, j, and k certainly doesn't make sense with normal algebra, any more than does the hyperbolic j. How can there be more than two different numbers that squared yield -1 or 1 (or for that matter, any specific number)? The solution is simple: You're not in Kansas anymore. The quaternions have their own algebra, as do the hyperbolic numbers.
The use of [itex]\hat{\imath}[/itex], [itex]\hat{\jmath}[/itex], and [itex]\hat{k}[/itex] to indicate the unit vectors in three space comes directly from the quaternions.
In the physics literature, they were [re]discovered as the "perplex numbers".
They provide a route to the geometry of special relativity,
just as complex numbers provides a route to Euclidean Geometry.
as u people said if i used by mathematicians& physicists and j only used by electronic engineers..what you suggest about the term j which is used in physics also(for same usage) ? and why are you saying like j is only for the representation of -1 ,current density also we represent with the same notation,what you mean by it?
then what about the current density for which we use the same notation j?
I just followed your link. I had never heard of this before. In split complex numbers j2 = 1. So maybe that is the context where the original post came from.
The difference between 'i' and 'j' is the difference between normal people and electrical engineers!
Ha Ha!
Actually, some of us EEs do use i and j interchangeably. In some instances, especially when reconciling results from physics and EE literature, it is convenient to use j for [itex]e^{j \omega t}[/itex] time dependence, and i for [itex]e^{-i \omega t}[/itex]. The mapping between results is then straightforward.
The argument that EEs use ##j## instead of ##i## because ##i## is used for current has always confused me. Don't physicists come across electric current a lot as well?
Maybe 'i' came from the math side where 'imaginary' roots had to be explained. Leibniz called them "impossible" numbers.
It is my understanding that the used of complex numbers by electrrical engineers mostly traces back to Steinmetz, who published a paper in 1893 and a few years later a textbook on AC circuit analysis. Steinmetz used j, but didn't say why (at least in my skimming of his paper). EDIT: This is pretty far off-topic from the OP - sorry!
jason
