The Initial colors of the mixtures in wells A-1 through A-3, A-4, and A-5 were high pink, medium pink, and high pink respectively. When Na2SO4 solution was added to well A-1, the color changed to a light orange. When NaHSO4 was added to well A-3, the color changed to magenta. When the mixture from well A-4 was heated, the color changed to a very light pink. When the pipet containing the mixture from well A-5 was placed in cold water, the color changed to a higher pink. When the pipet containing the mixture from well A-4 was placed in cold water, the color changed to a higher pink. When the pipet containing the mixture from well A-5 was placed in hot water, the color changed to a light orange. HSO4-(aq) + H2O(l) <—> H3O+(aq) + SO42-(aq)If Na2SO4 is added to the mixture in A-1, the reaction should shift to the left since Qc will be great than Kc. When Na2SO4 was added to well A-1 in the experiment, the color became lighter indicating the presence of acid, meaning the reaction shifted to the left.
HSO4-(aq) + H2O(l) + Heat <—> H3O+(aq) + SO42-(aq)The initial colors and appearance in the mixtures of wells B-1and B-2 were both milky. After adding HCl to well B-1, and adding Na4EDTA to well B-2 the mixtures of both wells cleared. The initial colors of the mixtures in wells B-3 and B-4 were both magenta. After the mixture from well B-3 was heated, it turned light pink. After the mixture from well B-4 was cooled, it turned violet. When the mixtures from B-3 and B-4 had their temperatures reversed, they turned light pink and light violet respectively. Mg(OH)2(s) <—> Mg2+(aq) + 2OH-(aq)The initial color of the mixture in well C-1 was light purple. With the addition of water, HCl, and AgNO3, the color of the mixture in well C-1 turned light pink, purple blue, and into a very light pink. When adding water to the mixture in well C-2 the color turned blue. After the addition of ethyl alcohol, the mixture turned medium pink. When H2O was added to the mixture in well C-3, the color turned pink. When the mixture from well C-6 was heated and cooled, the color turned blue and pink respectively.[Cocl4]2-(alc, blue) + 6H2O(l, colorless) <—> [Co(H2O)6]2+(aq, pink) + 4Cl-(aq, colorless)
