What is the solution (rational function/interval table)?
  • Context:
  • Thread starter Thread starter eleventhxhour
    Table
4 replies · 2K views
eleventhxhour
What is the solution of |x/(x-2)| < 5 ?
So, I did this the usual way of moving over the 5 to the left side and then cross multiplying and simplifying etc. However, I keep getting the wrong answer. I got x < 5/3 and x > 2, while the answer in the book says that it's x< 5/3 and x > 5/2.
What did I do wrong? I'm assuming it has something to do with the absolute value sign, but I'm not sure how to figure it out...
What do yo mean with cross multiplying? I'm not familiar with this.
I would solve it this way: to get rid of the absolut value signs you can square both sides, that is
$$\left | \frac{x}{x-2}\right | < 5 \Rightarrow \frac{x^2}{(x-2)^2} < 25$$
Solving this inequality gives the desired result.
Another way to get rid of the absolute value:
[math]\left | \frac{x}{x - 2} \right | < 5[/math]
splits into the two inequalities:
[math]\frac{x}{x - 2} < 5[/math]
and
[math]-\frac{x}{x - 2} < 5[/math]
and solve them separately.
The trouble with cross multiplying when using inequalities is that we need to know the sign of what we are multiplying by. For example -4/x < 1 when x is positive, but -4/x > 1 when x is negative. The same thing will occur for the x - 2 term.
-Dan
and
-Dan
So I solved each of those and for the first one I got that it's negative at x<2 and x>5/2. For the second I got that it's negative at x<5/3 and x>2. Is this correct? The book had a different answer (x<5/3 and x>5/2).
All of this has to come together. Take a look first at the lower limits of x. We have x < 2 and x < 5/3. In order for both of these to be true then we require that x < 5/3, because 5/3 is smaller than 2...both conditions are satisfied by this. See if you can do the upper limits of x based on a similar argument.
-Dan
