What is the speed of a photon traveling along the sine function?
The discussion revolves around the concept of a photon traveling along a sine function and the implications of this idea within the context of electromagnetic waves and quantum mechanics. Participants explore the nature of photons, their movement, and the distinction between classical and quantum descriptions of light.
  • Some participants argue that a photon does not travel along a sine-shaped path, emphasizing that photons, as massless particles, travel in straight lines.
  • Others propose that the sine wave represents the propagation of electromagnetic fields rather than the path of a photon itself.
  • A participant suggests that visualizing the sine wave as moving at speed c is more appropriate than imagining a photon traveling along it.
  • There is a discussion about the correct labeling of axes in graphs representing electromagnetic waves, with some participants noting that the y-axis should represent the electric field component.
  • Some participants question the meaning of a photon having a frequency, debating whether it is the electromagnetic signal that possesses frequency or if photons do as well.
  • Concerns are raised about the potential misconceptions that arise from discussing photons without a proper understanding of concepts like Fock states in quantum field theory.
Participants express disagreement on the nature of photons and their movement, with multiple competing views on how to conceptualize light and electromagnetic waves. The discussion remains unresolved regarding the implications of these differing perspectives.
Limitations include the potential for confusion between classical and quantum descriptions of light, as well as the need for clarity on terminology and concepts such as Fock states and the nature of electromagnetic signals.
somega
On the image you can see a photon starting at point A at t=0.
The photons travels along the sine function and arrives point C.
I knot that this takes T=λ/c.
But this is the time for a object traveling directly from the origin to point C and not along the sine wave!
If the photon travels along the sine wave with speed c it will take longer than T for the photon to arrive at point C.
Where is my mistake?
A photon, as a relativistic massless particle, in simple terms travels in a straight line. It doesn't travel along a sine-shaped path!
Electromagnetic radiation is the propagation of sinusoidal electro-magnetic fields. That is a different model of light altogether.
Although we often say "photon" in the relativity forum because it's easier than saying "flash of light" or "light signal", that's incorrect - photons don't move or travel or follow paths or anything that you're thinking they do. If you reword your question to say "flash of light" it will be clear where your mistake is - a flash of light always moves in a straight line unless you bounce it around with a mirror (or bend its path with a lens or prism, but then it's not moving in a vacuum).
Here:
It does not travel along the sine function (unless maybe you have laid out some fiber optic cable in the shape of a sine function)
Rather than thinking in terms of the photon traveling along the sine wave, you need to visualize the sine wave as traveling at c, like this:
This particular image is 1 wavelength long. The wave travels at c to the right.
The time it takes for a wave to traverse the width of the image, or 1 wavelength is ## T = \frac{\lambda}{c}##
Thus the frequency is ## f = \frac{c}{\lambda}##
A photon doesn't travel along any line, let alone a straight line. It's a Fock state of a massless spin-1 quantum field, describing the electromagnetic field within QED. It is a completely wrong picture to envisage this as a localized particle. A photon does not even have a position observable in the usual sense. It simply cannot be localized.
I have also no clue, why a photon should travel along a sinusoidal line to begin with.
In the OP’s posted graph of a classical electromagnetic wave, the “y”-axis should be the “y-component of the electric field”. As noted by others, the wave disturbance travels along the x-axis at speed c (with no displacement components along the y or z directions).
The correct graph is neither a spatial diagram nor a Spacetime diagram.
Then the correct labeling would be ##x## for the abscissa and ##E_y## for the ordinate of the coordinate system.
Yes, but what is it within the context of a B-level thread or even I-level undergraduate physics? Until one knows what a Fock state is, your explanation doesn't help.
Until one knows what a Fock state is it is better not to talk about photons at all as it will invariably lead to misconceptions. At least they should not be talked about as ”little balls of light”.
May be, but then one shouldn't give socalled "explanations" which are utterly wrong either!
Does a photon have a frequency at all? Or is it the electromagnetic signal which has a frequency? (And the electromagnetic signal is made of many many photons.)
If you search online for "photon frequency" what do you find?
somega said:
a photon
This thread is in the relativity forum, not the quantum physics forum, so the concept of "photon" has no meaning here; the relevant theory of electrodynamics here is classical electrodynamics, not quantum electrodynamics.
Thread closed.
  • · Replies 55 ·
  • · Replies 22 ·
  • · Replies 22 ·
  • · Replies 32 ·
  • · Replies 25 ·
