What is the Substitution for Solving Second Order Differential Equations?
7 replies · 2K views · last reply
scottie_000
I am having real trouble with this second order differential
The substitution is given and i just can't seem to use it
What am i missing here?
[tex]x \frac{d^2 y} {dx^2} -2 \frac{dy} {dx} + x = 0, \frac{dy} {dx} = v[/tex]
All help welcome
You need to show some work. What problems are you having with that substitution, it shouldn't be very hard to use.
That's just the problem. I can't get much at all.
The only step I can think of is:
[tex]x \frac {dv}{dx} + 2v + x = 0[/tex]
I don't see where that leads me.
Do i need to find x in terms of v?...
From where you are put it in standard form and then think about how you would solve that ODE.
I've honestly tried for ages to put it in standard form.
I've tried finding dy/dv, dx/dv, dv/dy etc...
None of that has worked at all...
No you need to find v in terms of x. Solve that relatively simple ODE for the function v and then you have another even simpler equation that if you solve will give you y.
you have
xv' + 2v + x = 0
so
xv' + 2v = -x
Can you solve that equation?
In your first post, you said the equation was
Now, after substituting v for dy/dx, you write
One of those has a typo. Assuming the first equation is what you want, the second should be
[tex]x \frac {dv}{dx} - 2v + x = 0[/tex]
or, as d leet said, xv'- 2v= -x (correcting that sign error).
That's a linear first order differential equation and has a simple integrating factor.
Another method: write the equation as xv'= 2v- x and divide by x:
v'= 2(v/x)- 1. Now let u= v/x so that v= xu. v'= xu'+ u and the equation becomes xu'+ u= 2u- 1 or xu'= u-1, a simple separable equation.
Ahhh thank you...
I couldn't see what i was missing
It's all so simple :blushing:
