What is the surface charge density?
3 replies · 5K views
s0mebody
Two large parallel metal plate sheets carrying opposite electric charges of equal magnitude are separated by a distance of 38.0mm. The electric field between them is uniform and has magnitude 480 N/C.
a) What is the potential difference between the sheets?
b) Which sheet is at higher potential, the one with positive or negative charge?
c) What is the surface charge density D on the positive sheet?
I have solved a and b.
a) W/q = Potential Difference = Ed = 480(0.0038) = 1.824 V
b) Positive charge
For letter C, I have no idea how do it. It's my first time encountering the term surface charge density on this kind of problem... Pleas help.
Consult your text. I'm sure your book talks about the electric field due to an infinite sheet of charge.
Can you elaborate further? I didn't quite understand.
I'm saying read your textbook. You should know the electric field for three common charge configurations: a point charge, a line charge, and a sheet of charge. Your book will cover these.
