What is the Taylor expansion of x/sin(ax)?
The original poster attempts to compute the Taylor expansion of the function $$f(x) = \frac{x}{\sin(ax)}$$ around $$x_0 = 0$$, specifically seeking the first four terms of the expansion while working within the context of complex numbers.
  • Participants discuss using the series expansion of sine and question the validity of the original poster's approach to division in the context of series. Suggestions are made to explore the expansion of $$\sin(x)/x$$ and the series for $$1/(1+y)$$, with emphasis on retaining only the necessary terms for the Taylor expansion.
Some participants provide guidance on how to approach the problem by focusing on the relevant series expansions and suggest neglecting higher-order terms. There is an acknowledgment of the original poster's progress, but no explicit consensus is reached on the final form of the expansion.
Participants note the importance of keeping track of neglected terms using the $$\mathscr O$$ notation and question how to handle the infinite series in the context of the Taylor expansion. The discussion reflects a focus on the constraints of the problem and the need for clarity in mathematical expressions.
RedDwarf
Hey everyone
1. Homework Statement
I want to compute the Taylor expansion (the first four terms) of $$f(x) =x/sin(ax)$$ around $$x_0 = 0$$. I am working in the space of complex numbers here.
function: $$f(x) = \frac{x}{\sin (ax)}$$
Taylor expansion: $$ f(x) = \sum _{n=0}^{\infty} \frac{f^{(n)}(x_0)}{n!}(x-x_0)^n$$
I thought I could use the series form of sine:
$$sin(ax) = \sum (-1)^n \frac{(ax)^{2n+1}}{(2n+1)!} $$
$$x/sin(ax) = \sum (-1)^n \frac{ (2n+1)! } { a^{2n+1} }x^{-2n}$$
While this is in fact a series, this doesn't look like a Taylor expansion at all. Is there a clever way of seing the Taylor expansion without actually calculating all the derivatives by hand?
Wolfram Alpha gives a rather neat result, but I have no clue how one gets there.
That is not how division works. You have essentially assumed that 2=(1+3)/2 = 2/1 + 2/3 = 8/3.
I suggest you do the following:
- What is the expansion of sin(x)/x?
- What is the expansion of 1/(1+y)?
- Let y = sin(x)/x - 1.
- Remember that you only need to keep terms up to ##x^3## as you are only interested in the four first terms.
The expansion of ##\sin (x)/x = 1-x^2/3!+x^4/5!-... = \sum (-1)^n \frac{x^{2n}}{(2n+1)!}##
The expansion of ## 1/(1+y) = 1-y+y^2-y^3+... = \sum (-1)^n y^n##
Then, if I set ##y = \sin (x)/x -1##:
##x/sin(x) = 1- (sin(x)/x-1)+(sin(x)/x-1)^2-(sin(x)/x-1)^3+... =3-sin(x)/x + sin^2(x)/x^2- 2sin(x)/x - (sin(x)/x-1)^3+...
= 3 - 3 sin(x)/x + sin^2(x)/x^2-...##
I am not sure how to continue from here. How can I plug in the series of sin(x)/x into the series of 1/(y+1) without everything blowing up immediately? And what do I do with the terms ##sin^2(x)/x^2## and those of higher order, where I am basically supposed to calculate the square of an infinite sum?
Thanks for your help though, I feel much closer to an answer already!
As already stated, you do not need to keep the entire infinite sum as you are only interested in the first terms. You can write (for example)
\sin(x)/x = 1 - \frac{x^2}{6} + \frac{x^4}{120} +\mathscr O(x^6).
The ##\mathscr O## will help you keep track of the order of the terms you have neglected.
Let's see if I can do this:
If ##\sin(x)/x = 1 - \frac{x^2}{6} + \frac{x^4}{120} +\mathscr O(x^6)##, then
$$1/(y+1) = 1-1 + \frac{x^2}{6} - \frac{x^4}{120} +1 + (-\frac{x^2}{6} + \frac{x^4}{120})^2
= 1+\frac{x^2}{6} - \frac{x^4}{120} +\frac{x^4}{36} - 2\frac{x^6}{6*120}+ \frac{x^8}{120})^2$$
Neglecting all terms with ##x^6## or higher:
$$x/\sin(x) = 1 + \frac{x^2}{6} + \frac{7x^4}{360} + \mathscr O(x^6)$$
Yeah, that looks like what I have seen before. Thanks a million!
You really should be writing out the ##\mathscr O## in every step or your equalities will not be correct. I also would not bother computing the higher order terms explicitly as they will be eaten by the ##\mathscr O## anyway and it already contains unknown coefficients. Just shove them into it right away. The general approach is valid though.
  • · Replies 27 ·
