What is the total probability for the given wavefunction?
  • Thread starter Thread starter DummBlonde
    Lost Quantum
The discussion centers on calculating the total probability from a given wavefunction, psi = 1*[1/sqrt(6)]*psi_1 + 2*psi_2. Participants agree that the probability is derived from squaring the wavefunction, but there is confusion regarding the normalization of the wavefunctions and the coefficients involved. The weight of 2 in front of psi_2 suggests it is twice as likely to occur compared to psi_1, leading to a proposed distribution of probabilities. However, concerns are raised about the total probabilities not summing to one, indicating that the wavefunction may not be properly normalized. The conversation emphasizes the importance of normalization and orthogonality in wavefunction calculations.
DummBlonde
Okay, here it is: The wavefunction is psi=1*[1/sqrt(6)]*psi_1 + 2*psi_2 and I have to find the total probability (yes, there is a "weight" of 2 in front of the second part of the wavefunction).
I know that psi^2 gives the probability, but I don't understand how to square this. Do I foil or something?
psi_squared: (1/6)psi_1+ (2/3)psi_2 ?
Are you sure isn't a \frac{2}{{\sqrt 3 }} instead of a 2 for the 2nd wave function? Although even with that, your probabilities don't add up to 1 if the stationary states are normalized as they should...
You do foil it though, yes. Also remember to consider orthogonality between different psi's.
I *think* it's just a 2, not 2/sqrt(3)...
By the way, I don't see how the probabilities add up to 1 if it's 2/sqrt(3)...
It won't. I should have asked this first but is Psi and psi_1, psi_2 normalized in the problem you're having?
One more thing: since the weight of the second part of the wavefunction is a 2, which is twice as great as the first part, it would seem to me that the second wavefunction is twice as likely to occur. That is, psi_1 would be 33% and psi_2 would be 67%. However, I don't understand how the 1/sqrt(6) fits in...
Well you have to multiply the 1 and the 1/sqrt(6). Your wavefunction then looks like:
\Psi = \frac{1}{{\sqrt 6 }}\psi _1 + 2\psi _2
Thus the probability of finding \psi_2 is 2\sqrt 6 times as likely as finding \psi_1. Though something is seemingly missing in this problem because the coefficients of each \psi squared must add up to 1 since the particle has to exist...
I am soooo lost too...
obviously, the total probability should be one, because one must find something at some where...
And yes, the wave function is not properly normalized, that only makes things even worse.
Yes, the probability of a wavefunction is l\Psil^2, as long as the function is NORMALIZED.
And how to find it? Well, pretty much you just simply do it. And you'll see you can get some terns.
And using the orthogonality of wavefunctions could let you discard some of the terms (although technically, from just your question, I don't really know whether they are orthogonal or not). And I hope at this point you'll see the problem of your question. What is the probability after your calculation? And what should the total probability be?
