What Is the Velocity of the 1.07kg Block After the Collision?
The problem involves two blocks colliding on a frictionless surface, with given masses and initial velocities. The first block has a mass of 1.07 kg and an initial velocity of 5.98 m/s, while the second block has a mass of 2.26 kg and an initial velocity of 2.59 m/s. The discussion focuses on determining the final velocity of the first block after the collision, particularly when the second block's velocity changes direction.
  • Mixed
  • Participants discuss the conservation of momentum and the correct formulation of the equations involved. There are attempts to apply the conservation of momentum and kinetic energy principles, especially in the context of elastic collisions. Questions arise regarding the assumptions of the collision type and the implications of the initial conditions.
Participants are exploring different interpretations of the problem, particularly regarding the second part of the question. Some have offered guidance on the need for additional equations when multiple unknowns are present, while others are attempting to derive relationships between the variables involved.
There is an ongoing discussion about whether the collision is perfectly elastic, which affects the equations used. Additionally, participants note that the second part of the problem introduces complexities due to the lack of a final velocity for one of the blocks.
lemin_rew
a)Two blocks are moving on a frictionless surface. The first block's mass is 1.07kg and its initial velocity is 5.98m/s. The second block's mass is 2.26kg and its initial velocity is 2.59m/s. What is the velocity of the 1.07kg block after the collision if the velocity of the second block is 5.15m/s after the collision?
b)If the initial velocity of the 2.26kg block is the same magnitude but in the opposite direction, what is the velocity of the 1.07kg block after the collision?
m1v1=m2v2
a)m1(vf+vi)=m2(vf+vi)
i made the velocities positive, because they travel n the same direction even after the collision.
(1.07kg)(vf+5.98m/s)=(2.26kg)(2.59m/s+5.15m/s)
vf= 10.37m/s
b) i will try after i get the first part right
this is wrong..im not sure what to do. please help.
The correct formula for conservation of momentum is:
m1*V1i + m2*V2i = m1*V1f + m2*V2f where
i is initial velocity before collision
f is final velocity after collision
It is not what you have written.
oh okay! thank you so much.
yes i got the answer.
then would the second part be the same equation but with the opposite direction.
so, m1*V1i + m2*-V2i = m1*V1f + m2*-V2f
like this?
For the second part, b, no final velocity is given as was the case for part a. In situation b, the momentum equation has two unknowns, namely, the final velocity of each block. You need another equation.
Is the collision perfectly elastic?
would it be then:
V1f=((m1-m2)/(m1+m2))v1i + ((2m2)/(m1+m2))/v2i
For part b the blocks are heading towards one another initially. Therefore for conservation of momentum you have the equation:
where V1i and V2i have opposite signs. However, you cannot solve the equation because you have two unknowns, namely V1f and V2f. You need another equation with the same two unknowns. That equation comes from conservation of energy providing the collision is perfectly elastic. Kinetic energy is conserved in an elastic collision.
so, then kinetic energy plays a role and the equation is:
1/2m1v1i^2 + 1/2m2v2i = 1/2m1v1f^2 + 1/2m2v2f^2
where v1i and v2i have opposite signs?
For the kinetic energy, the velocity is squared so the sign does not matter. Kinetic energy is always positive.
1/2m1v1i^2 + 1/2mv2i^2 = 1/2m1v1f^2 + 1/2m2v2f^2
So now you have two equations and two unknowns. Substitute for one of the final velocities from the momentum equation which leaves you with a quadratic to solve.
oh i think i get what you mean, let me try
thank you
i got my parabola to be
22.18v1f^2-0.257v1f-26.6463
and my root is 1.10.
its not the correct answer...
I do not get the same numerical answer as you. Plug your numerical results back into both the momentum and energy equations to see if you did the arithmetic correctly.
I should add that of the two solutions you get from the quadratic equation, one should be the initial velocity before the collision; the other should be the velocity after the collision. When you plug your quadratic solutions back into the momentum equation, you should get the corresponding velocities of the other block before and after the collision.
