What is the Vertical Velocity of a Rope Sliding off a Peg?
  • Thread starter Thread starter NewbieofPhysic
    Rope Sliding
The vertical velocity of a rope sliding off a peg can be determined using the conservation of energy principle. In this scenario, a limp rope with a mass of 2.5 kg and a length of 1.2 m has 0.8 m hanging off one side and 0.4 m off the other. The correct calculation for the vertical velocity, accounting for the center of mass and potential energy, yields a result of 2.8 m/s. The initial potential energy is calculated using the formula PE = mh*g(0.8/1.2), which accurately reflects the system's dynamics.
  • Understanding of conservation of energy principles
  • Familiarity with potential energy (PE) and kinetic energy (KE) equations
  • Basic knowledge of center of mass calculations
  • Ability to perform algebraic manipulations for solving equations
  • Study the principles of conservation of energy in mechanical systems
  • Learn about center of mass calculations in varying mass distributions
  • Explore advanced kinematics involving pulleys and ropes
  • Investigate the effects of friction and counterweights in dynamic systems
Students studying physics, particularly those focusing on mechanics and energy conservation, as well as educators looking for practical examples of energy principles in action.
NewbieofPhysic
A limp rope with a mass of 2.5 kg and a length of 1.2 m is hung, initially at rest, on a frictionless peg that has a negligible radius. The rope is hung such that 0.8m hangs off the longer end, and 0.4m off the lower end. What is the vertical velocity of the rope just as the end slides off the peg?
PE = mgh
KE = 1/2mv^2
Because the kinematics of this system seemed incredibly complicated, I figured it best to use conservation of energy in the system. Knowing that the center of mass will fall 0.4 meters, I assumed:
mgΔH = 1/2mv^2
2.5*9.81*0.4 = 1/2*2.5*v^2
v = 2.8 m/s
Unfortunately, this seems to be incorrect. I assume this has something to do with the counterweight applied by the short end of the rope, but I'm not sure how to account for this.
Aha, got it! I knew the initial problem had to do with my initial potential energy, so I realized I could set it equal to:
PE = mh*g(0.8/1.2)
As the initial acceleration is dependent upon the ratio of mass at any given end and gravity. Using this, I could go straight to kinetic energy and solve.
The second attempt has the correct initial C. M.
  • · Replies 39 ·
