What is the volume of a tetrahedron formed by given points?
The problem involves finding the volume of a tetrahedron formed by four given points in three-dimensional space. The original poster presents their approach using vector calculus and integration, while also referencing the formula for the volume of a tetrahedron.
  • The original poster attempts to solve the problem by integrating the area of triangular slices derived from the tetrahedron's vertices. They express concerns about a potential missing constant in their calculations and the appropriateness of their chosen differential.
  • Some participants suggest alternative methods, such as finding the area of the base and the height through projections, or parameterizing the volume in terms of vertical height.
  • There is discussion about the implications of parameterizing vectors and the relationship between the area of slices and the variable used in integration.
The discussion is ongoing, with various approaches being explored. Some participants provide guidance on parameterization and the relationship between the area of slices and the integration process. The original poster is reflecting on the feedback and considering adjustments to their approach.
There are indications of confusion regarding the parameterization of vectors and the interpretation of the variable used in the integration. The original poster also notes the challenge of integrating numerically and the constraints of their current understanding of the volume calculation.
mikfig
Let points P1: (1, 3, -1), P2: (2, 1, 4), P3: (1, 3, 7), P4: (5, 0, 2)...form the vertices of a tetrahedron. Find the volume of the tetrahedron.
V = 1/3 ah
A = area of base
h = height of tetrahedron
I wanted to solve this using the fact that | u x v | = area of a parallelogram formed by the vectors u and v. So I designated P1 as the "top vertex" and the other three as the vertices forming the "base" of the tetrahedron.
Then I figured I would divide the tetrahedron into "triangle slices" whose area was | u x v| / 2 while u and v where the two vectors forming this slice.
Then:
u = (P3 +t(P1 - P3)) - (P2 +t(P1 - P2))
v = (P4 +t(P1 - P3)) - (P2 +t(P1 - P2))
And I integrated | u x v | / 2 from t = 0 to t = 1. After simplifying | u x v | / 2 into an expression in terms of t, I get:
1/2 sqrt(75t^4 - 290t^3 +450t^2-290t + 75)
So when I integrated 1/2 sqrt(75t^4 - 290t^3 +450t^2-290t + 75) dt from 0 to 1, I got approximately 2.25426. Note: I had to integrate numerically as Mathematica couldn't integrate analytically.
The real answer is 20/3 or 6.66667. I looked at this and saw that if you multiply my answer by 3 then you get 6.76278, which is within 0.0961158 of the real answer.
I'm not sure if that means I am missing a constant term in my integral, but that 1/3 in the tetrahedron volume equation caught my eye as I didn't understand the reason for it when I read a proof on a website I can't remember.
Anyways, now I am thinking that I overlooked the differential and that dt should have been dy in the integral, and I would have to then somehow express dt in terms of dy. But I haven't looked at that part yet. I think I will take a look at it tomorrow, after my AP Macroecon test.
Thanks a lot,
mikfig
do you have to integrate? how about finding the area of the base then a vector perp to the base, then find the height by the projection onto that vector...
also as another idea, you could parameterise in terms of the vetical height, then the area of a slice will vary by a factor of 1 to 0, as the height goes form the base to the peak, that should be pretty easy to integrate as it will just be t...
lanedance said:
do you have to integrate? how about finding the are of the base then a vector perp to the base, then find the height by the projection onto that vector...
also as another idea, you could parameterise in terms of the vetical height, then the area of a slice will vary by a factro of 1 to 0, as the height goes form the base to the peak, that should be pretty easy to integrate as it will just be t...
No, I don't have to integrate. I just wanted to solve it this way because its more challenging than just plugging in height and base area to the tetrahedron volume equation.
As far as parameterising in terms of vertical height, that is exactly the approach that I am taking. I just didn't know how to put into words what the t variable represents. Like I said though, I think the problem I'm having is what to put for the differential. Because I don't think it makes sense for volume of a "triangular slice" to just be (| u x v | / 2) dt.
So I think I just have to ponder on exactly what should go after the cross product term.
Thanks,
mikfig
why not?
| u x v | represents the area of the parollelogram given by u & v, and dt represents an infinitesimal slice
in this you should parmetrise t along a line form base to peak of the tetrahedron. Depending on how you do this you will need to include a scale factor:
- if you paramterise the line, and t varies from 0 to 1, you need to scale by the height of the tetrahedron
- if you paramterise the line, and t varies from 0 to h, the scale factor will be 1 as t is direct representation of length (probably the easiest way)
the way to do that explicitly, is to first write the volume element, dV = | u x v |ds, where ds is an intesimal length element, then find ds in terms of dt in you line paramterisation & integrate over t, by substituting into your equation
also note that as t varies from 0 to 1, along t lengths are proportional to t, so the area of a slice A(t) is proportional to t^2. Hence when you integrate you get the factor of 1/3.
i've had a look at you original post and think you may have made a mistake early on. Note the way you paramterise u & v, the direction of the vectors should not change, only the length. This means you should be able to write it as
\textbf{u}(t) = \textbf{u}_0 c t
\textbf{v}(t) = \textbf{v}_0 c t
where c is some scale factor... and \textbf{u}_0, \textbf{v}_0 are the orginal base vectors
then when you take the cross product, you shold get
|\textbf{u}(t) \times \textbf{v}(t)| = |\textbf{u}_0 \times \textbf{v}_0| | c^2 t^2|
so it should just be an integral of t^2
Sorry it has taken me so long to respond, I was merely thinking over your responses.
I don't understand here how you say "along t", as t isn't a vector but rather a scalar.
As you can see from the picture I attached, I don't think that u and v can be described by any base vectors. Because as you can see, any two combinations of u and v for two different values of t are parallel. And if they are parallel then they are said to be linearly independent and thus they can't be described by each other.
Thanks,
mikfig
correct that t is a scalar, but changing the parameter t to t+dt will move you along the line and there will be a corresponding length in space ds correspodning to the change dt
Thanks,
mikfig
if you parametrise along a line perpindicular to the base, then a volume slice wil be
dV = A(t) ds = |u(t) X v(t) |/2 ds
in you diagram the direction of u does not change, only its length. Same for v.
i'm not sure what you're trying to say here... parallel vetctors are linearly dependent
damn, i just realized what a stupid statement that was :(. ok you now i see, since they're parallel then the direction is always the same by definition :D
I found that |\textbf{u}(t) \times \textbf{v}(t)| = 5\sqrt{3}t^2 - 10\sqrt{3}t + 5\sqrt{3}:
\textbf{P}_1: (1, 3, -1), \textbf{P}_2: (2, 1, 4), \textbf{P}_3: (1, 3, 7), \textbf{P}_4: (5, 0, 2)
\textbf{u}_0 = \textbf{P}_3 - \textbf{P}_2
\textbf{u}(t) = (\textbf{P}_3 + t(\textbf{P}_1 - \textbf{P}_3)) - (\textbf{P}_2 + t(\textbf{P}_1 - \textbf{P}_2))
\textbf{u}(t) = (1 - t)\textbf{P}_3 - (1 - t)\textbf{P}_2
\textbf{u}(t) = (1 - t)\textbf{u}_0
\textbf{v}_0 = \textbf{P}_4 - \textbf{P}_2
\textbf{v}(t) = (\textbf{P}_4 + t(\textbf{P}_1 - \textbf{P}_4)) - (\textbf{P}_2 + t(\textbf{P}_1 - \textbf{P}_2))
\textbf{v}(t) = (1 - t)\textbf{P}_4 - (1 - t)\textbf{P}_2
\textbf{v}(t) = (1 - t)\textbf{v}_0
|\textbf{u}(t) \times \textbf{v}(t)| = |(1 - t)\textbf{u}_0 \times (1 - t)\textbf{v}_0|
|\textbf{u}(t) \times \textbf{v}(t)| = (1 - t)^2|\textbf{u}_0 \times \textbf{v}_0|
|\textbf{u}(t) \times \textbf{v}(t)| = 5\sqrt{3}(1 - t)^2
Now I just have to figure out what how to express ds in terms of dt.
Thanks,
mikfig
yeah sorry, i think i may have confused things as well - the "line" doesn't enter specfically into the integral, but is how i always think of parameterising the problem, then slices are perp to the line
say you let t vary from 0 to 1, then just let s = ht, where h is the height of the tetrahedron - this will give the correct physical dimensions & so volume
Cool, I think that should work perfectly.
Thanks for all the help :D,
mikfig
  • · Replies 178 ·
10K
9K
10K
