What Is the Work Done When Moving a Mass from X to Y?
The discussion focuses on calculating the work done when moving a 1kg mass from point X to point Y, with X and Y at distances R and 2R from the Earth's center, respectively. The gravitational potential at X is given as -800 kJ/kg, and the potential energy at Y can be determined using the known gravitational potential function. It is clarified that integration is unnecessary for this problem; instead, the work done is simply the difference in potential energy between the two points. The concept of gravitational fields being conservative is emphasized, indicating that the work done is equal to the negative change in potential energy. Understanding these principles resolves the initial confusion regarding the integration approach.
DumbNut
X & Y are two points at respective distances R and 2R from the centre of the Earth, where R is greater than the radius of the Earth. The gravitational potential at X is -800kJkg^-1. When a 1kg mass is taken from X to Y, what is the work done on the mass?
Gravitational Potential = -GM/r
U= -GMm/r
I have thought over this question and tried using integration to make sense of it since gravitational potential and U varies w/ r. But when I tried thinking along the lines of integration, I find myself wondering what does the integrated value of graph U against r represent as it does not concur with what I am trying to find with regards to the concept of homogeneity. Is my idea of trying to integrate wrong? Or is my concept wrong to begin with? Please help, thank you.
Welcome to PF,
I don't think you need to integrate. Since you know the gravitational potential (often called \psi or \phi) at R, you can easily figure out what it is at 2R, since the form of the function \phi(r) is known.
Once you get the potential at 2R, you know the potential energy that this particular mass therefore has at 2R. You can compare that to the potential energy it had back when it was only at R. Recall that the work done by a conservative force on an object is equal to the negative of that object's change in potential energy.
Thank you! I guess I thought about it too mathematically, now it makes sense to me.
The work done in moving a mass between two points is the difference in the potential energy (U). As far as I know, integrating U doesn't have any physical significance. By definition, U is the work done by the gravitational field of an object to move it from a point to infinity. Thus if you consider the difference in the potential energies at any two points, you can find the work required to move a body between those two points.
EDIT: Looks like someone else beat me to it!
Sorry, but I can't understand your question.
However, why don't you use the property that gravitational field is a conservative one?
Yeap, I tried that and it worked :D thanks guys.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
