What kind of engine would you use for this project
  • Thread starter Thread starter jkenny
    Engine Project
The discussion centers on selecting an appropriate engine for a logistic robot designed for military applications. Key recommendations include considering a small 4-stroke gas engine or an electric system powered by fuel cells, given the military's investment in this technology. The importance of matching the engine with a suitable chassis and drive system for various terrains is emphasized, with suggestions to explore diesel/electric generators and high-powered bike engines, while also considering weight constraints for troop mobility. The conversation highlights the necessity of balancing power density with lightweight design to meet military specifications.
  • Understanding of 4-stroke gas engines and their applications
  • Familiarity with electric motor systems and fuel cell technology
  • Knowledge of chassis design and drive systems for off-road vehicles
  • Basic principles of weight distribution and power-to-weight ratio in vehicle design
  • Research fuel cell technology and its applications in military vehicles
  • Explore chassis design options for off-road capabilities
  • Investigate the use of diesel/electric hybrid systems in logistics vehicles
  • Examine historical military vehicles for design inspiration and efficiency
Mechanical engineers, military vehicle designers, and robotics developers interested in creating lightweight, efficient logistic robots for military applications.
jkenny
Hi I'm currently working on a logistic robot for my final project in Mechanical Engineering. My vision is to design something similar in features to this robot:
http://www.its-eng.com/logistic-robot
I would really like to join military vehicle manufacturers industry so its really important as my final project. The vehicle should drive in any terrain and the engine should be powerful but not too heavy cause I want the soldiers on the force moving with it to be able to lift it when needed.
Your advices would be highly appreciated!
A lot more important than your engine choice is what kind of chassis and drive system are you planning on implementing which will "drive in any terrain"? There are a lot of terrains out there, and that will be the primary hurdle. Should it be able to drive up stairs? In 2 ft. dia. rubble? 3 ft. deep snow?
The engine is easy in comparison because your obvious answer is probably a small 4-stroke gas engine, unless noise is an issue in which case you'll need to go with an electric system with batteries.
I vote for a fuel cell powered electric motor. Although I'm bias, but the military has been putting a lot of money into them lately.
Go away, Topher; the Mopar rule applies here. When in doubt—HEMI!.
You state the conflicting specifications of
(1) light weight for warfighter lifting
(2) high power density ("drive in any terrain"), presumably under load up steep inclines. And presumably a long way away from an electrical outlet.
Hmmmm...gotta go with with either "pocket nuke" or "warp drive".
Why get an land rover engine and rebuild it like new? I have built performance engines myself a few times now, and spent 5 years in the army.
Your either going to make a hybrid... have you the budget? Didn't think so.
Or get a used land rover engine or something similar and rebuild it for reliably.
If it needs to be really light consider a high powered bike engine, but they're too noisy for the army. Your biggest problem is matching the drive train to the engine. Absolute nightmare splinning axels.
You can think of using ultra capacitors-battery combination to power a DC motor.
Wanna know how much your final DoD armor req's are going to weigh?
No... you don't. That would eliminate 4-cyls and most other gas engines. If you're looking at fuel, it has to be on the diesel end (Mil combat vechs run on either straight diesel or JP-5 (jet fuel) they don't like the idea of transport costs & logistics on multiple forms of fuel.)
Hybrid+Armor=Very costly anchor (sorry)
Looking for innovation? Maybe try diesel/electric generators? I think power:weight will be an issue there too.
This is an industry I'm familiar with. Trust me when I say there's A LOT of hoops to jump through. If you get a working prototype, shop the design to existing contractors and sell it!
Your desire to allow the vehicle to be liftable by the troops is a useful constraint.
The Volkwagen military utility vehicle used in WW2 (later sold in the US as 'The Thing' for the surf rec vehicle crowd) was light enough to be manhandled if it got stuck, about 600kg if memory serves. Note the engine was aircooled and built of magnesium, so light weight was part of the design.
Also note it had no all wheel drive, so no complex heavy power transmission, just have the soldiers push if needed.
If you provide for impressive road clearance and big wheels, you also have long suspension and power transmission elements, which add weight and cost.
You might have a more interesting project if you focused on efficiency, keeping your robot cheap and light, rather than overly capable and expensive.
You could do worse than to look at other past efforts in this area. The Marines have used simple logistics carriers extensively, basically wheeled platforms. Those might be a useful point of departure.
Meet the Yamaha Banshee: 400 lbs, 50 hp.
http://en.wikipedia.org/wiki/Yamaha_Banshee_350
Respectfully submitted,
Steve
  • · Replies 23 ·
