What Molecular Mechanisms Cause Different Arc Phenomena in High Electric Fields?
  • Context: Graduate
  • Thread starter Thread starter Andy Kay
    Air Electrical
The discussion focuses on the molecular mechanisms behind different arc phenomena observed in high electric fields. Three distinct phenomena are identified: sparking and crackling from a ten-stage voltage multiplier, a violet arc from a current-limited voltage multiplier, and a whitish flame-like arc from a Jacob's Ladder powered by a flyback transformer. The contributors explain that the violet arc results from limited ionization without continuous conduction, while the Jacob's Ladder demonstrates continuous conduction. The generation of ozone through silent electric discharge is also highlighted as a relevant process in these phenomena.
  • Understanding of high voltage systems and safety precautions
  • Familiarity with electric discharge phenomena
  • Knowledge of ionization processes in gases
  • Experience with voltage multipliers and their operation
  • Research the principles of electric discharge and ionization in gases
  • Study the operation and design of voltage multipliers
  • Explore the mechanisms of continuous vs. non-continuous conduction in high voltage applications
  • Investigate the generation of ozone through silent electric discharges
Electronics enthusiasts, high voltage experimenters, and anyone interested in the physics of electric arcs and ionization processes.
Andy Kay
I have noted three different phenomena due to high electric fields in air.
1. When I run a ten-stage voltage multiplier I get sparking and crackling.
2. When I run the multiplier but current limit the output with ten 720k resistors in series, I get a violet arc that is sometimes smooth and quiet and sometimes jagged and hissy.
3. When I run a Jacob's Ladder from a flyback transformer (driver draws around 5A) I get a whitish flame-like arc.
Can anyone enlighten me as to what is going on at the molecular level to give these three different phenomena?
Thanks for reading.
Hi Andy Kay. :welcome:
In my home DIY experiments while at high school, I generated ozone by "a silent electric discharge in air". This involved two parallel electrodes in air, but with a length of glass tubing over one of them. This produced a purple glow inside the tubing, but a complete absence of snappy blue sparks. I'd say the mechanism is one where electrons are stripped off oxygen molecules by the high electric field but the high path impedance prevents the establishment of a continuous conductive path which would discharge the high tension source. Operation was characterised by the unmistakable penetrative smell of ozone (a gas you don't wish to breathe much of). This may be the explanation for your purple glow in (2), ionization but on a limited extent that doesn't support continuous conduction.
Thank you for your reply. I think the salient comment was "does not support continuous conduction" -- this is helpful. I'm guessing, then, that the voltage multiplier spark consists of continuous conduction for as long as the capacitor stack can sustain it before needing time to recharge. Also that the current-limited voltage multiplier is, as you say, limited ionization without continuous conduction. And finally that the Jacob's Ladder effect is continuous conduction that does not need time for recharging. That would seem to make sense. Thank you for this and please correct me if I am still getting it wrong.
  • · Replies 39 ·
18K
11K
