What parameters make a long lasting engine?
  • Context: Automotive
  • Thread starter Thread starter John Mcrain
    Engine Parameters
58 replies · 8K views
John Mcrain
What is most important parameter when we must build long last internal combustion engine and why?
specific output : HP/Displacement ?
HP per each cylinder?
Torque per cylinder?
Displacement per cylinder?
HP / piston area ?
RPM / displacement of one cylinder?
Numbers of cylinder?
Low RPM as possible?
Low combustion pressure?
Long stroke ,narrow bore?
Piston average speed?
HP / piston area ?
RPM / displacement?
What is the context of your question? Is this for schoolwork?
No this is not schollwork,it is general discusion.
Well, then tell us what YOU think are the most important and why.
Okay. So what do you think are the most important things that lead to a longer life of internal combustion engines (ICEs)?
Oops, @phinds beat me to it, as usual...
  • Haha
All of the above, and none of the above.
My simple answer is "maximum piston speed". Keep the piston speed low for the best lubrication and minimum fatigue of the piston rings.
I am not sure so I ask here in hope some mechanical engineer will make detail explanation..
But I know that all long last engines truck,bus etc has very low specific output, around 30-40HP/L
modern car diesel engine around 100HP/L, tanker only 4HP/L !
Tanker has 100 000HP and 25480 Liters !
Have you tried researching your question at all (I mean other than just asking others for the information instead of looking for it yourself) ? We expect SOME effort on your part when you ask for help here.
1. Low mean piston speed = better longevity.
The piston must accelerate and decelerate from zero, to its maximum speed, to zero again, all within one stroke. These accelerations create tremendous stresses on the engine parts and increase the friction losses in the bearings. The high speeds also increase the friction losses.
2. Next would be the heat dissipation characteristics. Overheating an engine is not good for longevity.
3. Finally, higher pressure on the piston will add to the stresses on the mechanical parts (which brings the same consequences as stated in point 1).
jack action said:
1. Low mean piston ...
2. Next ...
3. Finally ...
OK, I guess we DON'T want him to do his own research before coming here.
Understanding IC engines is a lifelong vocation. You cannot do it over the weekend.
A short answer reduces confusion and gets the reader headed in the right direction. A full explanation would be too long for this forum.
You can find the full explanation spread through a dozen different textbooks. But it is not until you get near the end that you will realize what is actually most important with regard to durability.
I agree but brake mean effective pressure (BMFP)of tanker which last 50years is 35Bar and Ferrari high rpm engine has BMFP=12 Bar last only 100 000km.
So we can't strictly follow this numbers in sense of engine longivity because leads as to wrong conclusion that high cylinder pressure (high BMEP) means increeased engine life...
You left out the most obvious parameter: Cost.
That is why your question only has a general answer, which is not applicable to every specific engine configuration. Everything plays a part, including the driver and the service mechanic.
From a guy who grenade many many engines over the years racing, my main concern is heat and flex poor design where form does not follow function. More on this later.
Specially here, heat means excess heat, flex means dynamic flex ( non-controller harmonics).
Heat robs motor oil of lubrication properties over time. Heat destroys the valve spring life span. Then you have valve float then the piston smacks the valve, may break it off and engine eats it. Bam.
Heat can cook the motor oil and may even set it on fire. Heat can cause cracks I the block and cylinder head. Heat can warp cylinder heads and cause blown head gaskets. Heat can cause loss of coolant by changing liquid to steam and booom
Flex is where the load is more the original design limits. Flex of the crank shaft means poor lubrication, scored bearings eventual failure. Flex can mean crankshafts crack then break. Flex in valve train components mean erratic valve timing possible valve float, possible timing chain breakage. Flex here may be due to weak skinny push rods, weak timing chain /belts, accessories driven off cam timing irregularities ( distributor flex). Flex of cylinders in the engine case (block ) is horsepower robbing and long term liability.
This is one area severely overlooked when designing race engines.poor design where form does not follow function – Number one consideration is the oil system. Stock oil systems are great for grocery getters but terrible to race. Oil does two things, lubricate and cool. Too much oil pressure can be as bad as too little. Oil must be controlled at all levels of performance. Oil under pressure shoot up to the bottom of the piston and cools it. Too much and the piston rings are overcome and can not control it. We have smoke, fouled spark plugs and a mess. Not so obvious is the danger of too high oil pressure in the upper oil galleries. Typically the oil is meant to flow up top then make many right angle turns to various other engine components. When the speed gets too great, the oil ha a difficult time making the 90 degree turn, hence, poor oiling. One more danger is oil aeration. Passing many moving parts creates potential for introducing air bubbles into the oil and air don’t lube too good! In the old days valve lifters were in the oil gallery and after the oil passed all the way past 3 lifters the oil capability of number 4 was dramatically reduced. We found that we could supply oil into the oil galleries from both ends of the block and the oil would meet in the middle and then back fill all the 90 degree turns a lot more effectively. Proper oiling means controlling the oil to the valve train to keep the valve springs cool but not to over pump oil top side and overcome the valve seals. Oil should return the ethe oil pan as soon as possible. You don’t want a bunch of oil slinging around inside engine block as it robs power and goes where it should not. Oil sling can cause parasitic drag.
Flex – One of the most impressive engine blocks I ever saw was the 292 CID straight six truck block Ford made. It has 7 main bearing caps. I never heard of a crankshaft busting all the time this engine was raced. If you look at the small block Chevy V8 block the main bearing caps are bolter to the flat block surface. No lateral support against flex. This is one reason the y had to go to 4 bolt mains. The old Mopar (Chrysler) B block had enormous lateral support. Monster Hemi’s had the same deal and added a main cap bolt 90 degrees to the crank thru the engine block.
Mopar small blocks were famous for blown head gaskets. The cylinder head design was for 4 head bolts on each cylinder. The small block chevy had 5. One other flaw was the deck thickness the small block Mopar. This was the design engineers light weight thin wall casting block concept. They wanted a light weight V8 for the compact cars in the early 1960’s. But thin wall design meant ----- FLEX. We had to pour a concrete metallic mixture into the engine block at the water coolant passages until it was about an inch thick, This stiffened cylinders and tied them into each other to prevent flex. It still did not help the thin deck (thickness of iron material flat surface the cylinder head bolts to) but it helped longevity. Did not impact cooling either.
Any way that’s my take on things to consider.
OK, fair point.
If you must build a long lasting reciprocating IC engine, study the characteristics of existing engines that were designed to achieve that: Diesel engines for big ships and stationary power generators.
Those are heavy (abundant iron-based metal) and robust (especially bearings and valves), which help with most of the phenomena that has been very well explained above.
Poor operation, frequent start-ups and neglected maintenance can destroy the best designed engine very briefly.
I added this one at the last minute to make sure everything was covered (say using a supercharged engine fueled by nitromethane compared with a naturally-aspirated one fueled by gasoline), but the mean piston speed is really the most important one.
You can always make the engine beefier to withstand large pressures or add a more powerful cooling system to retrieve more heat, bu the accelerating parts is a catch 22: If you make them bigger, they are more resistant, but the inertia forces are also greater. Ultimately, the material strength becomes a limiting factor.
As usual Jack is correct..heartily agree, piston speed most important, if you want it to last.
Do you know what are engines with lonigest TBO(time between overahaul) and which common parameter of them reduced engine wear the most, low piston speed, low specific output(HP/L) or maybe high brake mean effective pressure(which don't make sense)?
I notice that this low rpm-long last engines has very high mean effective pressure,which increase heat and force on piston/ring/bearings..,isnt that weird ?
If piston never really touch cylinder because of oil film(in engine without failure),why than piston speed increase wear?
Can you explain what happened in high piston speed engines to increase wear and reduced life time?
I won't claim to be an expert about this but the fact that an oil film exists does not guarantee absolutely ZERO wear. The definition of the word lubricant should imply this.
It's fatigue due to the constant pushing and pulling of the pistons (just the weight of them) and also causes the flex that @Ranger Mike was talking about in his post:
https://smartmechanicals.blogspot.com/2019/10/what-are-reasons-for-bending-bulking-of.html said:
Fatigue
Fatigue is the main cause of broken connecting rods--especially in older engines. The constant compression during the power stroke and stretching during the exhaust stroke, over thousands of times a minute, eventually wears the metal out and it becomes brittle and finally breaks. If the oil is low or dirty it can speed up this process. Running the engine hot can also speed up the process. Sometimes a fairly new engine can have fatigued connecting rods if it is a rebuilt engine and the mechanic used cheap parts or the wrong parts for the engine.
Here's what a crankshaft looks like under stress (deformations are emphasized to better see them):
jack action said:
It's fatigue due to the constant pushing and pulling of the pistons (just the weight of them) and also causes the flex that @Ranger Mike was talking about in his post:Here's what a crankshaft looks like under stress (deformations are emphasized to better see them):
So key for durability is low piston speed and low specific power.
What is difference between mean effective pressure and brake mean effective pressure formula?Does formula include max torque or torque at peak power?
Which torque is better to choose when compare two engines?
MEP is the general formula where any value of torque can be used. BMEP is where the torque value comes specifically from a dynamometer reading.
You would usually plot BMEP against rpm, just like with torque or power. The rpm for the maximum value will necessarily coincide with the rpm of the maximum torque.
There are many ways of dying. To live a long life, you must avoid all of them for as long as possible. A durable engine will be designed, manufactured and maintained in a deliberate way, intended to avoid early failure. That is a multi-dimensional problem.
The operator controls when the engine will exceed the safe operating conditions that may reduce engine lifetime. Many drivers are hard on their vehicles, which leads to an early failure. A performance engine may need to be fitted with a RPM limiter, to protect it from it's operator. Keep the maximum engine RPM down.
A ships engine room is staffed by skilled engineers whose job it is to care for the engine. It is not unusual to see a spare connecting rod, protectively wrapped and bolted to an engine room bulkhead. It is continuous care that makes the difference.
We all know of engines with statistically poor reputations, engines that wear out quickly, or that fail catastrophically. Those engines were poorly designed, or not produced for the job they were later called on to perform.
I wonder if "engine life" has technical definition. For example, if a engine blows a head gasket, does that count as end-of-life even if the engine can be repaired?
This. If you take the most likely cause of failure and make it much less likely, at some point the second most likely dominates. Continues improvement of the original element will have a smaller and smaller impact.
And it's probabilistic. Luck matters. It's also possible to do everything wrong and still have a not so bad outcome. Below is an engine that's gone 84000 miles on the original oil.
As a teenager I accidentally bought one that looked like that.
  • Drain oil
  • Refill with kerosene
  • Run it for a short time AT IDLE
  • Repeat a few times 'til the kerosene is somewhat cleaner
  • Refill with oil
  • Drive gently
  • If it knocks
    • Stop immediately
    • Drain
    • Fill with the heaviest oil you can find (50W was heaviest available)
    • Sell immediately (you are about to lose a connecting rod)
Another car I had I bought from a wholesale consumer product salesman I worked with. Manual transmission, almost all short trip city driving, except he would shift according to the length of time he was in a gear, not vehicle or engine speed. Maintenance schedule was: If it won't run, get it to run, repeat.
It ran decent, until I took it on a 400 mile trip to a new job. On the Interstate Highway it suddenly started running very rough, noisy, and low power. Oh well, it still moved. When I got to surface streets it really strained to get moving after a stop.
Some investigation revealed the rear cylinder of the straight 6 was not working. Removing that spark plug made it drivable but VERY noisy. It was a rural area with a few scattered towns, so I probably didn't wake up more that 50 people or so!
The failure was insufficient oil to the rocker arms. The rocker arm shaft sheared off at the back end, therefore the #6 exhaust valve never opened.
A clean-up, replacing the rocker shaft and rocker arm allowed me to drive it about another 5 years, including 3/4 of the way across the country.
1. Is MEP value in engine specifications calculated for max torque or torque at peak power?
Here is example at link below ,where write mean effective pressure: 28.8Bar
https://www.mtu-solutions.com/cn/en/stories/marine/new-mtu-16-cylinder-series-8000-engine-for-marine.html
2. So MEP value has nothing to do with engine durability/life time(time between overahul),but can we say that engine with higher MEP value has higher efficiency?
