- 454
A couple of observations.
Piston wear occurs most during start up. The engine is cold and oil has drained off the cylinder wall surface. When you cold start you do in fact have aluminum to iron rubbing. This causes wear on the es surfaces. Pistons are not round but oval. This is because when at operating temperature the top of the piston where the piston rings are located is now Round due to thermal expansion. That time period from cold start to proper operating temperature is where all the wear happens. It used to be that much wear happened when the engine was new and never fired up. Back then a lot of material was scrubbed off during “ break in”. period. Engineers developed “ plateau Honing’ that did not generate as much “Peaks” during the honing process in the cylinder and made break in a lot shorter until the piston rings were “ set”.
This same thing happens the main and connecting rod bearing at initial break in and cold starts. You have oil film but not a whole lot at cold starts and this is the metal to metal contact period. You could avoid this with a Pre-luber that is basically an aluminum cylinder with a “Piston plug inside”. Engine oil is plumbed to the cylinder and as the engine is running, oil pressure enters the cylinder and pushes the piston that compresses a mechanical coil spring. Before engine shut off, the drive operates a shut of valve that closes the engine supply. Now you have 2 quarts of engine oil trapped din this reservoir under 40 PSI. On cold start you release the valve and you per-lube the bearings with 40 PSI oil. And fire the engine.
Over time the piston will wear the cylinder into an oval shape. This is why you must re-bore cylinders in the engine blocks that have many miles on them. The ovality only gets worse over time. You develop piston slap on bad cases of wear. Also the piston rings develop “ flutter” when severe ovality occurs. The rings will open and close at higher RPM (flutter). This introduces oil into the combustion chamber. Not good. Eventually the poor cast iron piston rings (Moly) will stop doing the job and you have major blow by or even ring breakage. Heat is one big contributor to ring failure. Heat is death to rings and valve springs.
Do not forget that automobile manufactures do not want you to have a life time engine. They would go out of business. So they use cast pistons (forged wear far longer but are more expensive). They use cheap piston rings. They know about pre-lube but this is expensive.
Piston speed is not about the piston. It is about the reciprocating mass connected to the crankshaft. Manufactures use cast pistons, cast rods and minimal life span connecting rod bolts. By article in Engine Builder Magazine Larry Carley Mar 15, 2017 - High engine speeds place enormous tensile loads on a rod. The inertia of the pistons reciprocating up and down multiplies the effective weight of a piston exponentially as RPM go up. The force generated by a piston hitting TDC at 1,000 RPM is 50 times its initial weight when the engine is not running. At 10,000 RPM, the effective weight of that same piston is 5,000 times greater! That’s a lot of force stretching the rods 166 times per second. Think about that for a second. It is a miracle we can get 150,000 miles about of production engines as we do. During catastrophic failure we usually have a lack of lubrication problem of stress failure. Very rarely will the piston fail. The con rod snaps at the small end near the wrist pin. The other common failure is the ovality of the connection rod bearing that happens over time because of this loading at top dead center 16 times a second at 1000 RPM. Very rarely will the connecting rod bolt break.
