What should I review before taking differential equations?
7 replies · 3K views
john_in_pdx
Hey peeps,
I'll be taking diff-eq next quarter, and I was wondering what I need to do to prep myself for it. I am currently in Vector Calc, but I was wondering what are some things I should practice so I can hit the ground running when the class starts.
Thanks in Advance,
John In PDX
1.Differentiation of functions with one or more variables.
2.Integrations of functions (especially substitutions).
3.Good knowledge of trigonometry:circular and hyperbolic,hopefully u won't need elliptic one.
4.Fourier and Laplace transformations.Fourier series.
5.Complex analysis.Residue's theorem.
6.Special functions:all particular cases of Gauss' hypergeometric functions.
Daniel.
"4.Fourier and Laplace transformations.Fourier series.
6.Special functions:all particular cases of Gauss' hypergeometric functions."
Wouldn't this be taught in an intro course? You wouldn't be expected to know this going in.
So it should be normal,but course structure differs from case to case.Some of them assume having prior knowledge from a course on functional analysis.
Daniel.
If this is to be the first time you see diff eqs, then, IMO, the single most important thing you understand from what you have learned so far is:
THE CHAIN RULE OF DIFFERENTIATION
In particular, you should understand how this is coupled to the integration technique known as "substitution"
There is, of course, a lot more you need to know, but I've met quite a few students who become confused with the way that diff.eqs are solved, simply because they have failed to understand the above-mentioned issues.
To give you a hint:
When your lecturer starts talking about "separable" differential equations, pay close attention to how this is related to the chain rule&substitution integration technique.
Thanks arildno. That's the type of advice I was looking for.
I consider Linear Algebra a pre-requisite for differential equations. The whole theory of linear differential equations (which is most of introductory differential equations) is based on Linear Algebra.
I had Linear ALgebra last term, so I think I can handle that.
Thanks though for the reccomendation.
