What Value of b Simplifies the PDE into an ODE?
  • Thread starter Thread starter Benny
    Pde Variable
The problem involves a partial differential equation (PDE) given by \(\frac{{\partial u}}{{\partial t}} = \frac{{\partial ^2 u}}{{\partial x^2 }} + 1\) with the goal of determining a value for \(b\) that allows the transformation \(u = t^b f(\xi)\) (where \(\xi = \frac{x}{{\sqrt t }}\)) to yield an ordinary differential equation (ODE) in terms of \(f\) and \(\xi\) only.
  • Exploratory, Assumption checking
  • Participants discuss the substitution of \(u\) into the PDE and the resulting ODE. There are considerations of different values for \(b\), particularly \(b = 0\) and \(b = 1\), and the implications of these choices on the form of the equation. Questions arise about the presence of the \(t\) term and the nature of the derivatives involved.
Some participants have offered insights into the implications of choosing specific values for \(b\) and how it affects the resulting equation. There is an ongoing exploration of the requirements for the ODE to involve only \(f\) and \(\xi\), with no explicit consensus on the best approach yet.
Participants note that the problem specifically asks for a value of \(b\) that leads to an ODE involving \(f\) and \(\xi\) only, which raises questions about the acceptable forms of the resulting equations and the role of derivatives.
Benny
[tex] \frac{{\partial u}}{{\partial t}} = \frac{{\partial ^2 u}}{{\partial x^2 }} + 1,0 < x < \infty ,t > 0[/tex]
Let [tex]\xi = \frac{x}{{\sqrt t }}[/tex] and write [tex]u = t^b f\left( \xi \right)[/tex]. Determine the value of b required for [tex]f\left( \xi \right)[/tex] to satisfy an ordinary differential equation involving itself and [tex]\xi[/tex] only.
I just set u = (t^b)f and substituted into the PDE (using the chain rule). I obtained
[tex] \frac{{d^2 f}}{{d\xi ^2 }} + \frac{\xi }{2}\frac{{df}}{{d\xi }} - bf\left( \xi \right) = - t^{1 - b} [/tex]
I thought about setting b = 0 so that I could use reduction of order but then there will always be a 't' term. Setting b = 1 leaves me with a constant on the RHS which I can't get rid of. I've checked my working and the ODE I've arrived at seems to be correct. I don't know how to go any further. Any help would be good thanks.
Use "reduction of order" to do what? You are not, at least in what you posted here, asked to solve the equationl. You are only asked to determine the value of b that will give you an ordinary differential equation in f and [itex]\xi[/itex]. If you take b= 1, the right hand side becomes -1 and you have no "t" in the equation.
If there was no f term then I'd be left with some combination of f'' and f'. I can rewrite that in the form (I*f')' = -I*t where I is an appropriate integrating factor. But like I said, the problem with that is that I'm left with a t and I also have a derivative, f'.
If I take b = 1 I can get rid of the t on the RHS. But I'm also left with some derivatives of f and I'm not sure if that is an acceptable answer.
? The problem said, "Determine the value of b required for [itex]f(\xi)[/itex] to satisfy an ordinary differential equation involving itself and [itex]\xi[/itex] only". What makes you think a differential equation shouldn't involve derivatives?
I probably took the wrong approach. I thought that I was supposed to go for something like d/dx(xg(x)) = 0. It seems right now though, thanks.
Hello,
I need to know how did you solve for b? Can you please let me know the procedure?
Thanks
Azad
