What variables do I need to consider for my projectile motion project?
The discussion revolves around the variables and calculations necessary for a projectile motion project involving the construction of a siege weapon, specifically a ballista, to launch a water balloon a specified distance. Participants explore the physics principles related to projectile motion, energy conservation, and the mechanics of tension in the context of the project.
  • Homework-related
  • One participant describes the project requirements and expresses confusion about calculating the necessary tension to achieve the desired launch distance.
  • Another participant suggests using the range formula to determine the required initial speed and applying conservation of energy to find the necessary stretch of the ballista.
  • Formulas are provided, including the range equation and energy conservation equations, though the context of their application is not fully detailed.
  • Participants seek clarification on the meaning of the variables used in the formulas, indicating a need for further understanding of the concepts involved.
There is no consensus on the specific calculations or methods to be used, as participants are still clarifying the variables and their meanings. The discussion remains unresolved regarding the exact approach to take for the project.
The discussion lacks detailed explanations of how the variables interact within the context of the projectile motion project, and assumptions regarding the setup of the ballista and the properties of the materials used are not fully explored.
marcusnguyen
I'm new to this place so I really didn't know where to post this but here's the deal. My Physics teacher assigned us a projectile related to projectile motion. We are to build a siege weapon (catapult, trebuchet, ballista, etc.) that would launch a 1lb water balloon 25 ft in distance. We are planning to build a ballista and we know that to get the furthest distance, the ballista must be angled at 45 degree. However, I am having trouble understanding how the tension stuff works to calculate how much is needed to send the water balloon flying far enough to get a 100 on the project. Can someone please help me?
From the formula for the range, you can get the speed required. Conservation of energy can then be applied to find out how far you need to stretch the object back before it can get enough energy for the correct speed (assuming a sling-shot type thing is used).
If I remember correctly the formulas are
[tex]R = \frac{v_0 ^2 sin 2 \theta}{2g}[/tex]
[tex]\frac{1}{2}{m}{v^2} = \frac{1}{2} kx^2[/tex]
[tex]T = kx[/tex]
Can you please tell me what those variable mean?
R= range
v0, v = initial velocity
θ = angle of launch
g = acceleration due to gravity
k = spring constant of material
x = extension
m = mass
T = tension
  • · Replies 17 ·
15K
13K
11K
16K
