What volume does the v in pv denotes?
  • Thread starter Thread starter abi.ayan
    Volume
In the discussion, the "v" in the equation HI = UI + PVI refers to the volume of oxygen (O2) involved in the reaction, not the volume of magnesium or magnesium oxide. It is emphasized that, under constant pressure, the reaction between magnesium and oxygen is exothermic and must proceed slowly to maintain pressure stability. The volume of solids, like magnesium oxide, is often neglected because it is significantly smaller compared to the volume of gases. The heat of reaction is discussed in terms of transitioning from pure reactants to pure products at constant temperature and pressure. Overall, the focus is on understanding the thermodynamic implications of volume in gas reactions.
abi.ayan
what volume does the "v" in pv denotes?
say that in a system where pressure is constant Mg reacts with O2.when dealing with above reaction thermodynamically,
HI=UI+PVI
where H is the initial enthalpy of the system
UI is the initial internal energy of the system.
And my question is that what does the VI denotes in the equation.Is it the volume of magnesium and oxygen?
Likewise when we write the equation after the reaction, what does the VF denotes?Is it the volume of magnesium oxide formed ?
can anyone explain?
Most often, you would consider only the volume of the gas, as the volume of the solid will be negligible in comparison. For the reaction you mention, I would take both VI and VF to be the volume of O2 (assuming only O2 in the reaction vessel, not e.g. air).
Interesting --
pressure is held constant -
Mg + O2 is exothermic reaction -
For the pressure in the vessel to remain constant -
the reaction must proceed slowly or there could be ( would be) an increase temperature resulting in an increase pressure unless the volume increases
On the slow reaction method - (think rusting) the presure would slowly decrease as oxygen combines with the magnesium - MgO2 being a solid is much denser than O2 gas
Pressure Volume Temperature o
HI=UI+PVI
can anyone explain?
The heat of reaction is defined such that, in the initial state you have pure reactants and in the final state, you have pure products. Also, the final temperature is equal to the initial temperature, and the final pressure is equal to the initial pressure (for both the reactants and the products). The change in enthalpy is equal to the amount of heat you have to add to go from the pure reactants to the pure products at the constant temperature and pressure.
why do we neglect the volume of solids ?
so when there is a particular volume of O2 in a vessel,does it doing a work against the atmospheric pressure? I think I 've some wrong idea about "pv".
I'm not a student or graduate in Astrophysics.. Wish i were though... I was playing with distances between planets... I found that Mars, Ceres, Jupiter and Saturn have somthing in common... They are in a kind of ratio with another.. They all got a difference about 1,84 to 1,88x the distance from the previous planet, sub-planet. On average 1,845x. I thought this can be coincidential. So i took the big moons of Jupiter and Saturn to do the same thing jupiter; Io, Europa and Ganymede have a...
9K
  • · Replies 0 ·
