What will higher resolution microscopes see?
Higher resolution microscopes are crucial for mapping atomic arrangements to better understand materials' chemical and physical properties, aiming for resolutions of 0.1 Å as proposed by Richard Feynman. As resolution improves, the nature of the images changes, with quantum mechanics becoming significant and measurements influenced by the method of observation. Current examples, like IBM's graphene images, are often computer-generated visualizations rather than direct microscope images. Innovations such as sub-picosecond high-resolution transmission electron microscopy (TEM) are enabling the observation of dynamic atomic processes. The evolution of microscopy will continue to enhance our understanding of materials at the atomic level.
edguy99
The Nature article http://www.nature.com/news/microscopy-hasten-high-resolution-1.16393 talks about the importance of the higher resolution microscopes: "Build precision microscopes to map atoms", and "To truly understand materials' chemical and physical properties, atomic arrangements need to be mapped with much greater precision. Resolutions of 0.1 Å — the goal set by physicist Richard Feynman in his 1959 American Physical Society lecture, 'There's Plenty of Room at the Bottom'"
These type of pictures of Graphene from ibm are pretty common:
What kind of picture will we see as resolution becomes 10x better? Are there some examples out there already?
That is not an image of the microscope. It is a computer-generated image to visualize the actual measurements.
On that scale, quantum mechanics becomes relevant and the measurements depend on the way you measure. And the computer-generated images additionally depend on the visualization technique. There is no "image with a 10x better resolution".
I saw a microscope installation that explores a dimension not mentioned by Feyman - time A sub-picosec high res TEM can map dynamic processes on an atomic scale
http://experts.umn.edu/pubDetail.asp?t=pm&id=84867549845&n=David+J+Flannigan&u_id=4936&oe_id=1&o_id=9[/URL]
Thread 'Unexpected irregular reflection signal from a high-finesse cavity'
I am observing an irregular, aperiodic noise pattern in the reflection signal of a high-finesse optical cavity (finesse ≈ 20,000). The cavity is normally operated using a standard Pound–Drever–Hall (PDH) locking configuration, where an EOM provides phase modulation. The signals shown in the attached figures were recorded with the modulation turned off. Under these conditions, when scanning the laser frequency across a cavity resonance, I expected to observe a simple reflection dip. Instead...
10K
