What would be the best equation to find momentum?
  • Thread starter Thread starter lphockey14
    Momentum
The discussion centers on the best equations for calculating momentum. The primary equation highlighted is p = mv, which defines momentum (p) as the product of mass (m) and velocity (v). Another relevant equation mentioned is F = dp/dt, which relates force (F) to the rate of change of momentum. The conversation also touches on the units of momentum, which are kilograms multiplied by meters per second (kg*m/s). Additionally, a more complex equation, E^2 - (pc)^2 - p^2c^4 = 0, is introduced, indicating a connection to relativistic momentum. Overall, the key focus is on understanding momentum through its fundamental definitions and equations.
lphockey14
what would be the best equation to find momentum?
Probably Use
\vec p = m \vec v
Or
\vec F =\frac{d\vec p }{dt}
The momentum of what? Given what? The definition of momentum of a particle is
\mathbf{p} = m\mathbf{v}
Once you know the mass and the velocity you know the momentum.
What are the units momentum is measured in?
Momentum is measured in kilogram*meters/second (kg*m/s)
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
