What's the difference between dx and ∂x?
  • Context: Graduate
  • Thread starter Thread starter izabo
    Difference Dx
The discussion clarifies the distinction between the notations dx and ∂x in the context of differential calculus. It establishes that dx represents an infinitesimal change in x, while ∂x is part of the notation for partial derivatives, specifically ∂f/∂x, which indicates the rate of change of a function with respect to one variable while holding others constant. The conversation emphasizes that dx and ∂x are not equivalent due to their differing roles in mathematical expressions, particularly in functions of multiple variables like f(x,y). The participants also critique the use of the term "infinitesimal" in physics, suggesting it often serves as a misleading shorthand for first-order approximations.
  • Understanding of partial derivatives and their notation, specifically ∂f/∂x.
  • Familiarity with differential calculus concepts, including the differential df.
  • Knowledge of functions of multiple variables, such as f(x,y).
  • Basic grasp of mathematical notation and terminology used in calculus.
  • Study the concept of partial derivatives in depth, focusing on their applications in multivariable calculus.
  • Learn about the formal definition of differentials and their significance in calculus.
  • Explore the implications of first-order approximations in mathematical analysis.
  • Investigate the historical context and evolution of the term "infinitesimal" in mathematics and physics.
Students and professionals in mathematics, physics, and engineering who seek to deepen their understanding of calculus, particularly in the context of multivariable functions and differential notation.
izabo
I understand from the equation:
df = {\frac{\partial f}{\partial x}} dx + {\frac{\partial f}{\partial y}} dy
that: dx \neq \partial x.
I understand why df \neq \partial f
(df is the change in f when the change in all the variables is infinitesimal, and \partial f is the change in f when the change in one vriable is infinitesimal and the others are constant, right?).
but doesn't both dx and \partial x mean an infinitesimal change in x? if so, why aren't they equal? if not what do they mean?
x could depend on y, for example. Or both x and y could depend on some common other variables. In the same way as ##df \neq \partial f##, ##dx \neq \partial x##
how could x depend on y? aren't they both independent variables?
Who said that?
mfb said:
Who said that?
does it really matter?
btw i meant that for f(x,y) if that wasn't clear.
If you want to make sense of this for a function ##f:\mathbb R^2\to\mathbb R## (without using definitions from differential geometry), then you should define ##df:\mathbb R^4\to\mathbb R## by
$$df(x,y,z,w)=D_1f(x,y)z+D_2f(x,y)w$$ for all ##x,y,z,w\in\mathbb R##. This ensures that for all ##x,y,dx,dy\in\mathbb R##, we have
$$df(x,y,dx,dy)=D_1f(x,y)dx+D_2f(x,y)dy.$$ What you wrote can be considered a sloppy notation for this result.
This is a way to make sense of df, dx and dy. I don't think I have ever seen anyone try to make sense of ##\partial x##. It's just a small part of the notation ##\partial f/\partial x##, which means ##D_1f##. I find the notation ##\partial f/\partial x## misleading, since it hides the fact that ##D_1f## (the partial derivative of f with respect to the first variable slot) is the same function no matter what symbols we usually use to represent the numbers we plug into ##f##.
Note that with this definition, there's no need for dx and dy to be "infinitesimal". What does that even mean? I know that there's a definition of that term, but I haven't studied it, and I'm pretty sure that almost no one of the authors of physics books who use that term have either. If you see the term "infinitesimal" in a physics book, you should assume that it has nothing to do with infinitesimals. You should interpret it as a code that let's you know that the next thing that follows is a first-order approximation. For example, to say that for infinitesimal x, we have ##e^x=1+x##, is to say (in a weird and confusing way) that there's a function ##R:\mathbb R\to\mathbb R## such that ##e^x=1+x+R(x)## for all ##x\in\mathbb R##, and ##R(x)/x\to x## as ##x\to 0##.
df(x,y,z,w) is a first-order approximation of the difference f(x+z,y+w)-f(x,y). So if we want to be weird and confusing, we can say that for infinitesimal z and w, we have f(x+z,y+w)-f(x,y) = df(x,y,z,w). If we want to cause some additional confusion, we can use the notations dx and dy for the real numbers z and w, and then drop the (x,y,z,w) from df(x,y,z,w), and the (x,y) from ##D_1f(x,y)## and ##D_2f(x,y)##. Then we would be saying that for infinitesimal dx and dy, we have
$$f(x+dx,y+dy)-f(x,y)=df=D_1f dy+ D_2f dx =\frac{\partial f}{\partial x}dx+\frac{\partial f}{\partial y}dy.$$
Δ = difference
d = Δ but small difference, infinitesimal
δ = d but along a curve
Mathematical symbols are always graphics.I’m not sure if that will be true, but it would be beautiful.
  • · Replies 16 ·
  • · Replies 31 ·
