Whats the difference between q and q_v in thermodynamics?
The discussion clarifies the distinction between heat transfer at constant volume (q_v) and general heat transfer (q) in thermodynamics. It establishes that in an isochoric process, where volume remains constant, the change in internal energy (ΔU) is equal to the heat added (q) since no work is done (w = 0). The participants emphasize that while q_v can be expressed as C_v (ΔT), this relationship holds specifically for ideal gases, where ΔU = C_v (ΔT) is valid without the need for constant volume conditions. The conversation also highlights the importance of proper terminology and notation in thermodynamic equations.
  • Understanding of the First Law of Thermodynamics
  • Familiarity with concepts of internal energy (ΔU) and work (w)
  • Knowledge of isochoric processes and their implications
  • Basic principles of ideal gas behavior
  • Study the First Law of Thermodynamics in detail
  • Learn about isochoric and adiabatic processes in thermodynamics
  • Explore the relationship between internal energy and heat for ideal gases
  • Investigate the implications of constant volume on thermodynamic equations
Students and professionals in physics and chemistry, particularly those focusing on thermodynamics, will benefit from this discussion. It is especially relevant for those studying heat transfer, internal energy changes, and the behavior of ideal gases.
x86
In thermodynamics,
(delta internal energy) = (delta) U = q + w
But it is also known that (delta U) = q_v = integral of (C_v) dT
So if C_v is constant, then we have (delta U) = q_v = C_v (delta T)
But the confusing part for me is what follows. For instance, in an adiabatic process, for (delta) U = q + w, it is known that q = 0. So (delta) U = w
But then again, people will often use (delta U) = q_v = C_v (delta T) for adiabatic processes.
This is confusing to me,
Isn't q_v esentially the same as q? Except q_v is q at constant volume. So shouldn't q_v = 0 when q = 0?
Science news on Phys.org
x86 said:
In thermodynamics,
First, assume a quasi-static process.
Then this is true in general if the process is isochoric (constant volume). (I guess that's what you mean by "q_v". I would avoid that particular nomenclature).
It is also true for any process on an ideal gas (does not have to be isochoric. So you can use q instead of q_v.)
See above. For adiabatic process, dU = dW = -pdV. W here is work done ON the system (not conventional for physicists, but is for chemists, broadly speaking).
Isn't q_v essentially the same as q? Except q_v is q at constant volume. So shouldn't q_v = 0 when q = 0?
Yes, but again I see no need to invoke "q_v". I would prefer CV = {δQ/dT}V.
Also, reserve lower case for molar parameters, e.g. Cv = ncv etc. where n = no. of moles.
But how can we say that the change in internal energy is equal to the heat flow and the work done, and then go on to say its also equal to only the heat flow (Cv*T)? What of the work?
In an isochoric process there is no work done. (Why?).
Ah, *facepalm*
Because no work is done, since work is defined as w = -P (delta) V, (delta) V = 0
EDIT: it is not correct to say that δq = CvdT unless the process is isochoric.
Start with the 1st law:
δQ = dU + pdV
In an isochoric process, dV = 0 so
δQ = dU
and δQ = CvdT = dU
so that Cv ={ ∂U/∂T}V. Note that this equation states constant volume.
However, for an ideal gas we have
U = U(T) only, so that
{∂U/∂T}v = dU/dT
So then, for an ideal gas only, we can conclude that
dU = CvdT.
In other words, the requirement for constant volume in the expression for dU drops out if the gas is ideal.
The correct expression for an ideal gas for δQ is
δQ = CvdT + pdV.
x86 said:
Ah, *facepalm*
Right, but read my post #6 anyway.
  • · Replies 16 ·
