What's the difference between short term memory and working memory?
The discussion revolves around the differences between short-term memory (STM) and working memory (WM), including their definitions, functions, and potential physiological distinctions. Participants explore theoretical aspects, practical examples, and implications for understanding memory processes.
  • Some participants propose that working memory involves the use and processing of short-term memories to guide behavior, citing examples like navigating a new environment.
  • Others argue that working memory is a temporary holding area for information that allows for modification before it is either stored in short-term memory or lost.
  • A participant describes working memory as being processed in the prefrontal cortex, while short-term and long-term memories are associated with the hippocampal formation.
  • One participant shares a case study of H.M. to illustrate the distinction between working memory and short-term memory, noting that H.M. could engage in conversations but could not retain information once it was no longer in his working memory.
  • Some participants note that short-term memory is characterized by a limited duration and capacity, often cited as 7 ± 2 elements, while long-term memory can hold an indefinite amount of information.
  • There is mention of articles that provide deeper insights into the topic, suggesting that further reading could enhance understanding.
Participants express varying views on the definitions and functions of short-term memory and working memory, with some suggesting they are often used interchangeably, while others emphasize distinct roles. The discussion remains unresolved regarding the precise nature of their differences.
Limitations include potential ambiguities in definitions and the complexity of memory processes, which may depend on individual interpretations and the context of memory use.
jaobyccdee
What's the difference between short term memory and working memory? Is there any physiological difference?like difference in neural network formation? Thx!
Biology news on Phys.org
Working memory is the use and processing of short-term memories for effecting behaviors. So, for example, if you walk into a new building, the direction you turn at each hall is in your short-term memory. Needing to process that information to reverse your path to get back out is working memory. Though, I think I've also seen them used interchangeably at times.
Working memory is the 'online' information that is being processed at a given time. Working memory is usually dumped fairly quickly and not always sent for further memory storage (short term memory, long term memory etc).
Think of working memory (WM) as a type of rough drafting tool that you can use to alter or change memories. Like moonbears example, when you walk into a building for the first time you encode the path you took (left turn, right turn, up elevator and right turn). During this time your brain processed your path and stored it in short-term memory (STM). While you were at the office you stopped thinking about the path. This dumped the information out of your working memory. After you were finished you recalled the path from your STM back into your WM. You then processed it by reversing the directions to leave (left turn, down elevator, left turn, right turn). Once you were out of the building the directions are taken offline and out of your WM. If you return to the building the next day you would still be able to recall these memories due to their STM storage.
WM is thought to be processed in the prefrontal cortex of the brain (for rodents and humans at least). STM and LTM in the hippocampal formation. A good example of distinguishing WM from STM is the case of H.M.
H.M. was a man missing both hippocampal-formations (there are two mirror sides of the brain, thus two formations). When H.M. would meet a researcher for the first time he would greet them kindly and talk to them. He was able to carry on meaningful conversations and remember what had been said during these conversations. Thus he was able to temporarily remember and manipulate new information (WM). But if the person left the room and returned a minute or two later H.M. would not remember anything about that person or their conversations they had a minute ago. H.M. had dumped his WM store (taken it offline) but since he had no hippocampal-formation, the WM could not be stored as STM and it was lost. When the researcher reappeared, H.M. did not recognize him because he had not stored his WM into STM and would greet the researcher again as if they had never met. Futhermore, H.M. was unable to remember any long-term memories after he lost his hippocampi. He had been being researched for 20 years and had met this researcher hundreds of time before even though he never remembered him once!
It helped me to think of learning new memory in this fashion:
Sensory memory --attention--> WM --storage--> STM --consolidation--> LTM
Recalling memory goes like this:
WM <--recall-- STM or LTM
after changes and before being dumped offline
WM --reconsolidation--> New STM or New LTM
So working memory has different roles depending on whether or not the information is new or old. But in general, WM is a temporary hold for information that allows the brain to modify and adjust the online information. This new (or modified) information is sent to STM for more stable storage since WM stores are very labile.
Yes, STM and WM are often used interchangeably.
I'd further like to add that WM processes both STM and LTM.
Short-term memory is the capacity for holding a small amount of information in mind in an active, readily available state for a short period of time. The duration of short-term memory is believed to be in the order of seconds. A commonly cited capacity is 7 ± 2 elements.
In contrast, long-term memory can hold an indefinite amount of information.
  • · Replies 51 ·
9K
