What's the UNIT after you take the natural log?
The discussion centers on the dimensionality of the natural logarithm of pressure, specifically ln(p), in the context of the vapor pressure of water. Participants clarify that while ln(p) is mathematically treated as dimensionless, it fundamentally retains the dimensionality of pressure. The correct formulation is to express ln(p) in relation to a reference pressure, such as p_ref, to ensure dimensional consistency. The final consensus is that ln(p/p_o) = -L/(RT) is the appropriate expression, where p_o is the reference pressure.
  • Understanding of natural logarithms and their properties
  • Familiarity with the ideal gas law and thermodynamic principles
  • Knowledge of the heat of vaporization of water (L)
  • Basic concepts of dimensional analysis in physics and chemistry
  • Study dimensional analysis techniques in thermodynamics
  • Learn about the implications of using reference pressures in calculations
  • Explore the properties of logarithmic functions in physical equations
  • Investigate the relationship between pressure units (Pa, atm, mm Hg) and their conversions
This discussion is beneficial for students and professionals in chemistry and physics, particularly those involved in thermodynamics, vapor pressure studies, and dimensional analysis in scientific calculations.
kingwinner
I was working on an experiment for the vapor pressure of water and I have the following formula
ln (p) = -L/(RT) + ln (p_o)
L=heat of vaporization of water
R=Molar gas constant
T=temperature in Kelvins
I have some data points for the pressure p in units of mm Hg, when I take the natural log of it, ln (p), what will the units be? I am very confused...can someone please help me?
When I analyse the units of -L/(RT), it seems like it's dimensionless, but the value of ln (p) definitely depend on the numerical value of p (i.e. having p in different units, e.g. Pa, atm, mm Hg, should give different values of ln (p) ), then how can ln (p) be dimensionless?
Thanks!
The units of a ln(p) would generally be referred to as "log Pa" or "log atm."
Taking the logarithm doesn't actually change the dimension of the argument at all -- the logarithm of pressure is still pressure -- but it does change the numerical value, and thus "Pa" and "log Pa" should be considered different units.
- Warren
It seems that, strictly speaking,
the units of a function like log or exp or cos should be dimensionless,
and
the argument of a function like log or exp or cos should be dimensionless.
So, if p and p_o carry dimensions of pressure,
one should NOT write
ln (p) = -L/(RT) + ln (p_o),
but instead write
ln (p/p_ref) = -L/(RT) + ln (p_o/p_ref)
where p_ref is any arbitrary but nonzero reference-pressure so that (p/p_ref) and (p_o/p_ref) are dimensionless. Of course, if you'd rather not introduce a p_ref, then the dimensionally correct way to write the intended relationship is
ln (p/p_o) = -L/(RT)
since
ln (p/p_ref) -ln (p_o/p_ref) = -L/(RT)
ln( (p/p_ref) / (p_o/p_ref) )= -L/(RT)
ln( p/p_o )= -L/(RT) This is a good example that distinguishes mathematical variables from physical variables. As long as you are consistent, one can work "formally".
But I need to plot a graph of ln (p) v.s. 1/T, so I do need ln (p) to be isolated...
I would guess you are making the graph in order to extract the slope. A change of units will only shift the line up and down, not change the slope. Pick whatever units are handy. As robphy points out, the relation is valid in any units.
plot ln(p/1atm), ln(p/1Pa)... whatever units you are using.
and the argument of a function like log or exp or cos should be dimensionless.
but instead write
since
I would concur with this explanation.
I concur too. Kingwinner, just let p_{ref} in robphy's post be 1 Pa. You can do that as follows.
\ln(p)=-\frac{L}{RT}+\ln(p_0)
\ln(p) + 0=-\frac{L}{RT}+\ln(p_0) + 0
\ln(p) + \ln(1 Pa)=-\frac{L}{RT}+\ln(p_0) + \ln(1 Pa)
That last line is valid because \ln(1 Pa)=0.
\ln(p/(1 Pa))=-\frac{L}{RT}+\ln(p_0/(1 Pa))
\ln(\overline{p})=-\frac{L}{RT}+\ln(\overline{p}_0)
Where the quantities with the bar are dimensionless. Once it is recognized that the mathematical manipulations are no different with the dimensionless quantities than they are with the dimensionful quantities, it is at once recognized that we can go on our merry way working with quantities such as \ln(p) without worrying about the units.
ETA:
OK, I'm done editing now. :redface:
19K
