What's wrong with this local realistic counter-example to Bell's theorem?
177 replies · 34K views
ThomasT said:
What you're calling Bell's realism assumption isn't, "You measure a (from Alice) and b (from Bob), but ASSUME there must be a c (third) spin component value which exists - although not itself measured."
Apparently you think Bell's introduction of c has something to do with an abc dataset.
However, Bell's introduction of c is simply to have the three datasets (ab, ac, and bc) necessary to produce his inequality.
Well, it's really not that hard. I assume you agree that Alice and Bob will give identical results when each are measured at any c. I assume you agree that Alice and Bob will give results following the cos^2 rule when each are measured at any a and b respectively. If you believe that Alice and Bob are independent (locality holds) and the prior 2 statements are simultaneously correct, then clearly I can come up with a/b/c setting for which there are no stream of values which average to the cos^2 rule.
Alice is a clone of Bob, therefore Alice(a)=Bob(a); Alice(b)=Bob(b); Alice(c)=Bob(c). As well:
Alice(a)=+
Alice(b)=+
Alice(c)=-
Alice(d)=-
Alice(e)=+
Alice(f)=+
... simultaneously to infinity
You agree with the above, correct? If you do, you are a realist. And if you do, you will find that for a=0, b=120 and c=240, you have problems. Big problems. Of course, you can always say you are a realist and then simply abandon or ignore the above.
Alice(a)=+
Alice(b)=+
Alice(c)=-
Alice(d)=-
Alice(e)=+
Alice(f)=+
What does any of this have to do with my post #118, to which you're ostensibly replying?
You are simply mouthing words which basically have no meaning. Clearly, I am asking you to provide an actual realistic example. You just say something is realistic without providing support, as does JenniT and Gordon. Hey folks, realism means that the attributes DON'T have to be measured to exist. So provide putative values for these, will ya? That would be a and b AND c! Get this, c is NOT measured, a and b are.
I have a chair. It has simultaneous leg1, leg2, leg3 and leg4 each which have a position. The positions are relative to each other, each a foot apart forming a square at the base. If I observe the positions of any 2, without measuring the other 2, I can make the statement that the legs are realistic. That is because there are values for the 2 legs I don't observe that are not inconsistent with the relative positions of the 2 legs I do measure.
This analogy does NOT hold for quantum objects, specifically entangled particle pairs. They are not realistic! And neither are any objects which follow the HUP at the microscopic level.
Here is an example (settings 0/120/240 for a/b/c):
a/b/c
Note that the ab coincidence rate is 25%, exactly as predicted by QM. The bc rate should also be 25%, and it is in fact 25%. But the ac rate should also be 25%, and it is instead 50%. Oops! This is not consistent. Go to progressively larger datasets and you get no closer than this. The averages always ends up around 33% instead of the QM expectation of 25%.
W H E R E I S T H E B E E F ?
(And I don't mean DEADBEEF :)
So my point is that how *realistic* is an example that cannot show us that there are unobserved values which, if measured, would be consistent? Everything else being said is simply empty words.
DrChinese said:
You must be kidding. Ace, the burden is entirely on you. Perhaps you don't realize that you position violates mainstream science. Unless you can back up your statements, I would say your claims violate PF guidelines.
You say you have the example formula to generate the dataset. Great, so apply it and give the results to us. I will tell you if I consider it suitable. The angle settings have been laid out. (Of course I already know you cannot deliver what you claim.)
DrC and Admins: I have neither the intention nor the desire to breach any PF guide-line. I am here for the long-haul; I am here to learn, and I am learning. So I would welcome explicit directions and guidance if a possible breach of PF Guidleines ever seems to be the case. I am happy to lodge an application to the "Independent Research" section of PF, should that be required. I have been restrained in what I said in some posts above; and am still restrained in preparing some of the replies that I am yet to deliver. ThomasT raises questions that I believe I will need to answer in IR. (They relate to what I term LRQ -- a local realistic interpretation of QM -- which combines a widely-accepted view of the wave-function with equivalence classes.)
So DrC, that said, and with respect, there seems to be a lot of bias, innuendo, intimidation, misinformation and (still) misunderstanding in your response. Especially read in the light of the simple request that triggered your response.
1. I am not kidding. Why do you say that I must be?
2. You use the term "Ace". (I at first thought you were referring to someone else, maybe a friend of yours, an earlier poster.) But I understand the "dog-whistle" in this seemingly innocuous expression, as used in American English. Best I bite my tongue.
3. You say the burden is entirely on me. I thought this was a collaborative effort (all I asked for was the test-settings), but I will accept my share of the burden, and more, quite happily.
4. To that end: If you accept that the burden is entirely on me, I will post to you my interpretation of vanesch's example, and I will use the settings therein. I trust that you will not judge vanesch's example UNSUITABLE?
5. You say: "Perhaps you don't realize that your position violates mainstream science. Unless you can back up your statements, I would say your claims violate PF guidelines." This confuses me, so I'll let it pass for now. Except when I offered to back up my statements, you chose not to supply the test data? Very confusing to me; especially with me having no wish to breach the PF rules; and my OP question approved for its possible pedagogic merit.
6. I do not know where I said this: "I have the example formula to generate the data-set"? I want to demonstrate the formula that I have on test-settings provided by you. In the absence of such settings from you, I will now use vanesch's example, but in your context.
7. The IT here is not clear to me. "I (DrC) will tell you if I consider it suitable." ? I'll push on anyway.
8. You say: "The angle settings have been laid out. (Of course I already know you cannot deliver what you claim.)" Well I cannot deliver any claim based on angles only. I need more than angles to run a test; I need to know the particles (since my formula includes s for intrinsic spin); and the specific singlet correlation that you have chosen. So I will use the vanesch example, which is EPRB as used in Bell's 1964 paper; and which is the experiment addressed in L*R's Table 1 (PDF2) etc. This way, it will be clear that I have not "cooked" any formulae; so that is the way for me to go.
9. You say: "(Of course I already know you cannot deliver what you claim.)" Then (it seems to me) "my claim" is wrong, or you misunderstand it, or you are wrong. Are there other choices? Let's see.
10. To that end, I will first revise PDF2 to PDF3, to correct the typos already signaled; and to be specific about my definition of local realism (as spelled out in a reply to JesseM).
With best regards, and not too many hard feelings,
GW
PS: The example chosen has this merit: It will tie in with issues already raised in this thread, and with some questions that I have not yet answered.
1. I am not kidding. Why do you say that I must be?...
Anyone who researches the area should know that LR theories have been definitively ruled out. This is mainstream science. See for example Aspect, Zeilinger, etc. Shimony, the S in CHSH, said "...the incompatibility of Local Realistic Theories with Quantum Mechanics permits adjudication by experiments..." and hundreds have confirmed QM over LR. So if you want to learn about the area, great, perhaps I can help. But if you are here to attempt to persuade readers that LR theories are viable, you are making a mistake. This is not a forum for alternative views of science or personal theories. This is a moderated discussion area with guidelines. I believe you have been around here enough to understand how this place works, so I have to admit I am a bit confused.
On the other hand, if you want to learn WHY LR theories are ruled out, this is an excellent place to come! And I have been trying to explain just that. :smile:
As to the setup: a suitable PDC Type I source can produce photon pairs which have identical polarization. This is easily the best way to discuss entangled pairs because they are polarization clones and you don't need to adjust for opposite spin (which can be unnecessarily confusing in nomenclature). Use a=0, b=120 and c=240 degrees. The QM prediction for correlation at any differing pair of these (ab, bc, ac) will be 25%, and will be 100% for any identical pair (aa, bb, cc). I would expect that + and - values would be more or less equal and random, but that is not something I am too strict about. Is that specific enough?
You have a black box "LR" formula you want to test. It has some internal workings, the nature of which does not concern me. All I want to know is what the values are for a, b and c - they will be the same for Alice and Bob obviously - for some run. You should actually be able to provide me with values for 0 degrees, 1, 2, 3... 359. Or for that matter, .1, .2, .3... 359.9 degrees just as easily. But all I ask is for the a/b/c I requested above. You see, if there is only a and b from your model, then you are saying NOTHING more than QM! The realist asserts that there are values even when not measured. OK, if so, what are they? Because it should be clear very quickly that the experimental correlation results ALWAYS depend on the relative angle between Alice and Bob and NOTHING else. Which is exactly what QM asserts, and no more.
Good luck.
DrChinese said:
We are venturing into the world of semantics with this one. By Realism we of course mean "Quantum Realism". You can define that several different and, for most purposes, equivalent ways. I agree that Counterfactual Definiteness - as you mention - might be a better term. I like noncontextual myself (because I believe the context of the measurement is essential within QM). Some also replace Realism with Hidden Variables, also a pretty good concept. Of course there are differences between these terms, but that won't change too much as to the Bell result.
DrChinese said:
Realism is the idea that ALL particle properties are independent of an actual measurement.
So if Realism ...hold, particle properties are predetermined.
So presumably the unmeasured properties have values.
is not semantics, we are talking about the existence, you are arguing that
the moon is not there if nobody observes it (someone has to watch it to exist, for be there).
you state: the electron need have a spin value, if not, the electron is not real.
there are two very different things, is not semantics.
I say the electron exists, have or not a definite spin value.
Where? I just indirectly asked you to reply to my statements in post #118 of this thread. I've pointed out to you (in the Joy Christian thread) what constitutes explicit realism in Bell's formulation, and noted (in this thread) that your conception/translation of Bell's realism seems to be based on a misunderstanding of the role that the analyzer setting, c, plays in his exposition.
Not that your 'realistic dataset requirement' (based on your "... realism means that the attributes DON'T have to be measured to exist.") isn't insightful in a way. But it isn't Bell's realism, which is defined by the functions (which determine individual datasets) in his (1). Bell's realism, per se, is compatible with qm. What qm is incompatible with is the separability of those functions (1) in Bell's (2) -- a consequence of the application of Bell's locality condition.
Your dataset requirement seems to be more than just a realism requirement. Since it requires multiple datasets, and since it's incompatible with qm, it seems more of a realism + localism requirement. Maybe I'm wrong about that, and we can discuss it in another thread. Anyway, as I'll try to show below, it isn't the most efficient way to approach assessing proposed LR models.
Clearly ... and repeatedly. :smile: Ok, it's one way to approach assessing an LR model. If the model meets your dataset requirement, then it isn't a viable model and we can discard it.
But what if it's a viable model (which is the only sort of LR models that we're interested in)? We don't really need a numerical test to determine this. If the LR formulation reduces to the qm expectation value, then it's viable, and we also then know that it has to be a non-Bell-like LR model. But, that in itself, in the absence of a logical proof that Bell's (2) is the generalized LR form, doesn't automatically disqualify it. (Note that I do think that Bell's stuff is general, but I don't know how to prove it. If you're aware of anybody who has proved it, then that would certainly save us some time.)
Whether or not it might be deemed explicitly local and realistic (and it has to be explicitly local and realistic -- not just a weird algebraic workaround of the sort that Christian offers, and not just an interpretation of the qm formalism that ultimately offers the qm expectation value without an ansatz whose content is explicitly realistic and whose form is explicitly local) requires looking at the content and form of the proposed LR formalism, and not just plugging numbers into a qm-compatible reduced version of it.
Where?
As for Gordon, we'll be holding him to task regarding the viability, realism and locality of his model. I have no doubt at this time that it's going to fail at least one of those tests.
There's an important subtlety here, imho, which I endorse in the context of the following quote from Bell (re spin-1/2 particles being unpolarized):
"Some people ... may have come to think of the result of a spin measurement on an unpolarized particle (and each particle, considered separately IS unpolarized here) as utterly indefinite until it has happened." Bell's emphasis, in Einstein-Podolsky-Rosen experiments (1976).
So, for me: Particles exist, with or without a definite polarization; entangled particles in the singlet state being unpolarized.
When discussing L*R, with its generality across spin-1/2 and spin-1, I speak of both the photon-polarizers and the SGMs as polarizers. And in L*R, all pristine entangled particles are taken to be unpolarized. I therefore speak of each particle's total spin (total angular momentum), involving the intrinsic and extrinsic spin.
The mental picture that I have is this: On interaction with a polarizer, such pristine particles ("gyroscopic" in nature) have their extrinsic spin burnt off (as envisaged in macroscopic micro-wave polarizers) and their intrinsic spin re-oriented. (It works for me. But is this view-point -- with its mental picture and dynamics -- anathema to a quantum-physicist?)
But two things re terminology:
1. Whatever ones view, particles exist!
2. Though unpolarized, the pristine singlet-entangled particles still have definite properties!
I take the realism (in "local realism") to be the combination of these two facts. Which, I suspect, goes beyond the "strict realism" that we might find in philosophy.
So maybe the question is this: Can we, or should we, non-philosophers improve our terminology? To bring philosophers into the discourse more easily? To thus enlighten them. Certainly I take the view: The moon exists, even if no one looks.
I never argued the moon isn't there when it is not being observed. Sheesh!
The Moon analogy is Einstein's, and is just an analogy! QM makes no statement about the existence of particle properties beyond the context of the Heisenberg Uncertainty Principle. Generally, the idea is that properties do not exist outside of an observation.
I think a closer reading of the literature will make clear: this is an analogy only, and no one is supposed to doubt the existence of a moon or a particle when it is not being observed. The only question is whether particles have definite properties outside of the context of an observation. The accepted answer to this is: NO, and the Heisenberg Uncertainty Principle correctly details the limits of particle properties.
Thats All.
PROPERTIES.
Realism:
Real because of its existence and not because of any properties it has.
yoda jedi said:
Thats All.
PROPERTIES.
Realism:
When you made that claim, were you aware that that claim was cast out of iron and was consistent with everything we've come to know from experiments? It's impossible to argue against becuase the experiments directly support it(see the SQUID macroscopic quantum superposition experiment for a new definition of existence).
It's time physicists turn their attention to the very notion of existence, as the old ideas are plain wrong. There is no requirement that existence be local-realistic, is there? And it all comes down to why there is something instead of nothing, doesn't it?
The question is - Would you be willing to bet more than $1 that it is? All this talk that separates real from non-real and existing from non-existing is entirely human-made, isn't it?
I think a closer reading of the literature will make clear: this is an analogy only, and no one is supposed to doubt the existence of a moon or a particle when it is not being observed. The only question is whether particles have definite properties outside of the context of an observation. The accepted answer to this is: NO, and the Heisenberg uncertainty principle correctly details the limits of particle properties.
I agree with this. Obviously, something exists independent of measurement. But to what extent do we instrumentally (including our own sensory 'instrumentation') create/fashion the 'properties' that we talk and make theories about?
Anyway, I'm engaged in closer, more extensive reading of the literature on Bell, etc., after not being able to shake the feeling that I'm missing something. I see you haven't replied to my latest posts in this thread. Good. No need to until I rethink things. Also, read your Bell's Theorem and Negative Probabilities. Looks ok, and somewhat unique, though I prefer more, er, conventional treatments of BT. Found some literature that seems pertinent to it, and an old thread on it. If I decide to nitpick because not sure of some part of your rationale is it ok to necropost in that thread (nice discussion by the way), or should I start a new one?
Anything I might have said about Gordon's LR proposal is thus put on hold, but will watch this thread for interesting developments. Thanks to all.
Hi Gordon, I've been on a trip for the last week without a lot of time to post here, should be back to regular posting by the beginning of April. In the meantime I'll give a brief comment on your question here:
Gordon Watson said:
My immediate question relates to this: there should be no "irreducibly nonlocal" facts in the universe which cannot even in principle be deduced from the complete set of local facts.
It is not an impediment to any analysis of my model, but it seems to me that it could be worded more clearly? Could you put it another way? Some clarifying punctuation, maybe?
Many thanks, as always; and henceforth to be understood.
When I referred to "irreducibly nonlocal" facts it was in reference to this comment to ThomasT elaborating on my definitions 1) and 2):
Keep in mind that 1) doesn't forbid you from talking about "facts" that involve an extended region of spacetime, it just says that these facts must be possible to deduce as a function of all the local facts in that region. For example, in classical electromagnetism we can talk about the magnetic flux through an extended 2D surface of arbitrary size, this is not itself a local quantity, but the total flux is simply a function of all the local magnetic vectors at each point on the surface, that's the sort of thing I meant when I said in 1) that all physical facts "can be broken down into a set of local facts". Similarly in certain Bell inequalities one considers the expectation values for the product of the two results (each one represented as either +1 or -1), obviously this product is not itself a local fact, but it's a trivial function of the two local facts about the result each experimenter got.
A physical that is not specifically associated with a single point in space and time, like the magnetic flux through an extended surface or the state vector of a multiparticle system, would be what I call a "nonlocal fact". But some nonlocal facts are reducible to a collection of local facts in the sense above--that if you know some set of local facts in an extended region, the nonlocal fact is simply a function of these local facts, so in principle the nonlocal fact could always be determined from the local facts without any additional information being required. An "irreducibly nonlocal" fact would just be a fact that is not reducible to a collection of local facts in this sense. Whether or not there are any such nonlocal facts in physics is something we can't know for sure without knowing the most fundamental laws of physics, but one can at least imagine a universe in which there are irreducibly nonlocal facts which evolve according to their own rules and which influence the local facts, but the state of the nonlocal variables at any given moment can't be determined from the local facts alone. I am assuming in 1) that there aren't any irreducibly nonlocal facts in this sense, that all nonlocal facts must be in principle reducible to sets of local ones.
Gordon Watson said:
...Particles exist, with or without a definite polarization...
Right, Realism have nothing to do with properties, qualities, values.
Gordon Watson said:
There seems to be a major misunderstanding here. Not about my understanding of current beliefs, but about the next bit, which I'll rephrase as a question:
Q: Does GW really believe that he can come up with a local realist model that gives probabilities for P1-P8 which is "as one with QM"?
A: Yes; as has been shown in PDF2 (Table 1, Table 2, and notes thereto). So, in fact, GW believes that he has (beyond can) already come up with a local realist model that gives probabilities for P1-P8 which is "as one with QM"?
So can you please address my point that the formulas in Table 1 are clearly incompatible with those in Table 2, as shown by my numerical example in [post=3159151]post 71[/post] (which you never responded to, and you also didn't respond to my specific request to address this in post 90)?
More generally, your formulas in Table 1 are simply the ones predicted by QM, there is no possible way you could ever come up with a list of probabilities P1-P8 that reproduce the QM probabilities, based simply on the argument on the Bell inequality page[/url] which you have never really addressed:
1. According to the predetermined results given on the table, it must be true that:
P(a+, b+|ab) = P3 + P4
P(a+, c+|ac) = P2 + P4
P(c+, b+|cb) = P3 + P7
2. Since all the probabilities P1-P8 are real and non-negative, it must be true that:
P3 + P4 ≤ P3 + P4 + P2 + P7
3. Substituting the formulas from 1. into 2. gives:
P(a+, b+|ab) ≤ P(a+, c+|ac) + P(c+, b+|cb)
Therefore, any theory that gives probabilities for P1-P8 and agrees with the formulas in 1. must satisfy this inequality
4. But the QM predictions can violate the inequality in 3. for specific angles a,b,c like a=45, b=22.5 and c=0. So, no theory giving probabilities for P1-P8 can replicate the QM predictions, which are just those given in your Table 2.
Is there some part of this argument you don't understand? If you understand it but think the logic is flawed, can you tell me which of these points 1-4 you disagree with? Also, please note here that the angles are considered to be defined relative to some fixed coordinate system, so there can be no notion that any of the probabilities P(a+, b+|ab), P(a+, c+|ac), P(c+, b+|cb) are defined as "averages" of different pairs in P1-P8 as opposed to the simple formulas in 1. If you want to dispute this point and continue to talk about "bi-angles", "reference frames" and other such nonsense, please reread my post #88, and respond to this section in post #92:
OK, as noted above I don't know what terms like P(ab++|a) even mean, and if it's something to do with changing how you label angles from one trial to another, I don't really want to know. Unless you are making the totally crackpot argument that proving Bell wrong requires this sort of relabeling (in which case I really have no interest in trying to reason with you), please just adopt the standard practice of picking a single way to label angles and sticking with it through all trials. Note that I already asked you to do this in two separate posts...in post #25 I said:
Look, if you want to talk about angles there's no need for some convoluted notion of defining them relative to one another and picking one as a "reference angle", just do what is always done when talking about angles in physics, and define them relative to some fixed coordinate system! You could have a long straight rod stretching from one experimenter to the other whose position never changes and which is taken to define the x-axis of your coordinate system, and then the angle of the polarizer could just be defined as the angle relative to the rod, and then if you started the polarizer out parallel to the rod you could just see how many degrees you have to rotate it counterclockwise before it reaches the desired orientation, and call that the "angle" of the desired orientation. In this case every orientation would have a well defined angle, like a=70, b=30 and c=10, and then a difference between two angles like ac could just be defined as one minus the other, so ac=a-c while ca=c-a and so forth. In this case it's clear that ac=ab+bc is true since (a-c)=(a-b)+(b-c), while ac=ab-bc is false since (a-c)=(a-b)-(b-c)=a-2b+c which doesn't work. Given my example angles above you can see that ac=70-10=60, ab=70-30=40, and bc=30-10=20, so clearly ac=ab+bc does work since 60=40+20, but ac=ab-bc doesn't since 60 is not equal to 40-20.
I really hope your entire argument doesn't reduce to an incoherent notation for labeling angles...if not, then please just phrase your argument in terms of the standard type of coordinate-based angular notation I describe above.
And in post #29 I said:
I would like you to use the standard type of notation for angles, where individual angles are defined relative to some fixed coordinate angles and differences between two angles are defined in some fixed way, like ab=a-b. If you think the terminology of "bi-angles" still makes sense in this context, then please explain clearly what you mean, hopefully using a numerical example where we have definite angles for a,b,c and can thus calculate any angles like ab and ac.
Your notion of "focusing" on 2 angles or "reference angles" are similarly incomprehensible to me, I'm just talking about angles in the standard way that physicists always talk about angles, defining them relative to some fixed coordinate system, see post #25. As I requested there, I would like you to start using this sort of standard definition of angles as well, if your argument really revolves around saying there is something fundamentally flawed about defining angles relative to a fixed coordinate system and that we must use your incomprehensible alternative definitions, then your argument really is hopelessly crackpot and I am not interested in continuing.
Will you agree to this, and not refer me to any arguments or equations involving changing definitions of which orientation is at an angle of 0 and what the angles of the other two orientations are?
Please respond to that question at the end ("Will you agree to this..."): this should take precedence over all other responses to questions in my post. I really, really, don't want to continue to hear arguments involving "bi-angles", using different "reference frames" on different trials which label the three possible orientations with different angles, and so forth; if you cannot restate your argument in terms of a fixed coordinate system, then clearly what you are talking about has nothing to do with refuting Bell's own argument since he (and every other physicist who uses the same type of notation) was assuming a fixed coordinate system where the angles associated with each of the three physical orientations are constant from trial to trial.
That might be OK for a philosophy forum. Here, we are discussing local realism and that definition does not apply. All you need is to read Einstein's definition:
"I think that a particle must have a separate reality independent of the measurements. That is: an electron has spin, location and so forth even when it is not being measured. I like to think that the moon is there even if I am not looking at it."
He is talking about particle properties: spin, location and so forth...
Hopefully this makes it clear. No one - in the discussion of realism (in the quantum sense used here) - is debating whether particles themselves exist independently of observation. It is a matter of applying the HUP.
completely wrong.
values are defined by
Counterfactual Definiteness.
i.e the definiteness of the results of measurements that have not been performed.
You can also say a dog is a cat. Here is a definition of Realism from an experimental paper from the past few days (I started a separate thread on the paper itself because it supplies strong evidence against Realism):
"Reality": The state of any physical system is always well defined, i.e. the dichotomic variable Mi(t), which tells us whether (Mi(t) = 1) or not (Mi(t) = 0) the system is in state i, is, at any time, Mi(t) = {0, 1}.
This from Violation of a temporal Bell inequality for single spins in solid by over 50 standard deviations. And you could find similar definitions or Realism in hundreds of papers. Not that the definition would be much different than that of Counterfactual Definiteness.
But you ARE using the term "Realism" incorrectly in this forum. If you would care to provide a quote from an authoritative quantum physics source to back up your view, go for it.
yoda jedi said:
Yes, that's correct: you added nothing to my quotes. :smile:
Hopefully, that ends this useless rabbit trail.
Welcome back. I too am constrained somewhat until early April, so let's look forward to some real progress then.
And thanks for the above clarification. Personally, I see no need anywhere to use any word associated with "nonlocal" concepts.
Your reply above, it seems to me, shows that we should get along just fine. Me not using such terms; and me understanding what you mean might mean in such contexts.
Thanks again.
DrC, with respect to this bit:
<"Reality": The state of any physical system is always well defined, i.e. the dichotomic variable Mi(t), which tells us whether (Mi(t) = 1) or not (Mi(t) = 0) the system is in state i, is, at any time, Mi(t) = {0, 1}.>
How would this apply to EPRB systems where the 2 pristine particles are pair-wise correlated by conservation of total angular momentum? With no two pairs the same?
In Bell's terms, as I understand him: they are unpolarized.
And when Einstein refers to their spin, he no doubt refers to their intrinsic spin. It being a giant leap to think that he referred to total spin?
So what dichotomic variable are we discussing in the context of the above quote and EPRB?
Thanks.
Jesse, in response to your primary question: This is interim only, but it bears repeating to keep hopes alive:
1. If you derive any contradiction with QM, you have made a mistake.
2. If you derive a contradiction, any contradiction, you have made a mistake.
3. These claims are not from arrogance, but from careful checking.
4. Each particle faces, and responds to, a detector ORIENTATION. Each independently responding to whatever setting Alice and Bob may have chosen, respectively; any correlations in the outcomes arise from their pristine correlation in the singlet state.
5. The Source has no memory of, nor info re any orientation. The particles are absorbed after responding to a particular orientation; they pass no info on. Angles, between the respective two orientations in each test on a particle pair, are clearly defined.
6. The angle ab (say 90 degrees) may be oriented any which way, in an infinity of orientations. Examples on a clock-face: 12-3, 1-4, 2-5, 3-6, 6-9, 12-9, 9-6.
7. The correlations for such are always the same, being functions of sab only.
This simply to reassure you for now that there are no games being played. And that all questions will be answered. Thanks.
PS: I will respond in complete detail -- ASAP -- early April.
Thanks.
Electron Alice and electron Bob are entangled. Therefore if you measure the spin of Alice and Bob at 0 degrees with a suitable apparatus, you will obtain as results from {0,1} for Alice and {1,0} for Bob. I.e. Alice+Bob=1, that follows the conservation rule. In fact, if you measure this pair at the same angle for any angle within 360 degrees, you obtain the same. However, the values for a stream of Alices will appear purely random, as will those for a stream of Bobs.
One might naturally conclude that in a local realistic world, this is simply due to the fact that the outcomes of the measurements at any angle setting are effectively predetermined. So if we imagined the angle settings as a wheel with many spokes: each spoke for Alice is paired with a matching spoke for Bob, such that a +1 for Alice matches a 0 for Bob - and vice versa. Perhaps there are 360 "spokes", who knows. At any rate, the spoke values would presumably be different from pair to pair, which explains the random results.
With that analogy in mind, I would conclude that the spokes are arranged in some manner such that the cos(theta) rule emerges over a sufficiently large sample. I have no idea how such would be constructed, but I simply have "faith" that such a mechanism is possible. Prior to Bell, this analogy - and vision of Realism - would have been held by many if not most physicists.
of course, just exposing your madness...:biggrin:
I've come to find DrC's madness rather enlightening ... at least when he takes the time to elaborate and clarify.
I have come to live with it, sort of like a little friend...
a very incoherent friend...
