Wheatstone Bridge: No Current Flow?
  • Context: High School
  • Thread starter Thread starter Faris Shajahan
    Bridge Wheatstone bridge
The discussion centers on the behavior of current flow in a Wheatstone bridge circuit when the potential difference between two points is zero. Participants confirm that if no current flows through the bridge, the potential difference across it is also zero. They discuss the implications of this, suggesting that the bridge can be simplified by connecting its ends, treating it as a series combination of resistors. The consensus is that this approach yields the same results in circuit analysis.
  • Understanding of Wheatstone bridge circuits
  • Knowledge of electrical potential difference
  • Familiarity with series and parallel resistor combinations
  • Basic principles of current flow in electrical circuits
  • Study the principles of Wheatstone bridge circuit analysis
  • Learn about the implications of zero potential difference in circuits
  • Explore resistor combinations in series and parallel configurations
  • Investigate the concept of nodes in electrical circuits
Electrical engineering students, circuit designers, and anyone interested in understanding the principles of Wheatstone bridges and circuit analysis.
Faris Shajahan
In a circuit if the potential difference between two points is zero, no current flows between the two points, right? Or am I wrong? I feel like I am wrong. If I am right, then in a Wheatstone bridge, no current passes through the bridge. Then instead of removing the bridge, why don't we connect the two points?
Science news on Phys.org
You are correct.
What do you mean by "removing the bridge"? What two points do you want to connect?
While solving a Wheatstone bridge problem, we removing the bridging resistor and consider it as a parallel combination of series combination of two resistors. (I am sorry if I made it complicated) So what I mean is instead since no current flows through the bridge we can say the potential difference at the two ends of the bridge is zero. Hence why don't we join the two ends of the bridge and consider the whole thing as a series combination of a parallel combination of two resistors?
Btw Am I also correct when I say if there is no current flow through a resistor, then potential difference across the resistor is zero?
That would create a node in the middle and allow currents to flow criss-cross, which is not possible with the originial circuit, hence that is a misrepresentation of the circuit.
Yes.
You can. It will give you the same result.
cnh1995 said:
Yes.
Ah, yes. Multiple points with the same potential are effectively the same point, makes no difference whether you join them or not.
  • · Replies 30 ·
16K
