When Friction the block m2 start to move?
11 replies · 2K views · last reply
navneet9431
Hand-drawn free-body setup: block m1 rests on block m2, which sits on a horizontal surface. Friction coefficients labelled μ1 (between blocks) and μ2 (block to surface). Arrow labelled F = kt pushes block m2 to the right.
A block m2 is placed on a surface where the coefficient of friction is μ2 and another block m1 placed over the block m2 where the coefficient of frictio is μ1.
A force F=k*t(Force as a function of time),is acting on the block m2.
Now my question is that when would the block m2 start moving?
F=ma
Static Friction=Coefficient Of Friction*Normal Force
I tried solving this by drawing the FBD of the objects.
Hand-drawn free-body diagram of two stacked blocks: a small block on top with an orange arrow labelled f_r1 pointing right, and a long block below with orange arrows labelled f_r1 pointing left and F = kt pointing right, plus a blue arrow labelled f_r2 pointing left from the bottom block.
See two forces fr1 and fr2 will be acting on the block m2.
So m2 would start to move when F>fr1+fr2.
Or simply we can say k*t=fr1+ft2.
So the block m2 would start to move just after time "t".
Is my result correct?
  • Hand-drawn free-body setup: block m1 rests on block m2, which sits on a horizontal surface. Friction coefficients labelled μ1 (between blocks) and μ2 (block to surface). Arrow labelled F = kt pushes block m2 to the right.
  • Hand-drawn free-body diagram of two stacked blocks: a small block on top with an orange arrow labelled f_r1 pointing right, and a long block below with orange arrows labelled f_r1 pointing left and F = kt pointing right, plus a blue arrow labelled f_r2 pointing left from the bottom block.
Yes it is, just be careful on how you going to equate forces fr1 and fr2 with relation to the weights ##m_1g ## and ##m_2g ## and the static friction coefficients ##\mu_1## and ##\mu_2##.
Thanks for the reply!
So my result was correct.
See the pic I have uploaded.
Have I proceeded correctly?
Handwritten derivation on lined paper: F > f_r1 + f_r2 gives kt0 > mu1 m1 g + mu2 (m1 + m2) g, so t0 > [mu1 m1 g + mu2 (m1 + m2) g] / k, boxed. A sketch above shows m2 with friction f_r2 acting left.
  • Handwritten derivation on lined paper: F > f_r1 + f_r2 gives kt0 > mu1 m1 g + mu2 (m1 + m2) g, so t0 > [mu1 m1 g + mu2 (m1 + m2) g] / k, boxed. A sketch above shows m2 with friction f_r2 acting left.
Yes your result seems correct to me. Actually a minor correction, it should be ##t_0\geq…## not just >.
There is a common blunder in that equation, and it is causing you to get the wrong answer.
For kinetic friction it works: ##F_k=\mu_kF_N##, but for static friction there is a key difference.
You mean to say that my result is wrong?
haruspex said:
Yes.
How?Please explain.
And,also mention the correct result!
navneet9431 said:
How?Please explain.
Consider the situation when the applied force is zero. What are the frictional forces?
Zero
Ah, I think @haruspex is right, it is the maximum static friction that is equal to ##\mu_sF_N##. Static friction can take any value between zero and this maximum value.
When the box ##m_2## is about to move then the static friction between ##m_2## and the surface is indeed as you calculate ##fr_2=\mu_2(m_1+m_2)g## but box ##m_1## doesn't move with respect to box ##m_2## so the kinetic friction between m1 and m2 is just zero and also the static friction ##fr_1## is zero at the start of movement, later it gets bigger as the external force gets bigger.
