Calculating Time Dilation w/ Light Clock - Implications & Mistakes?
This discussion centers on the calculation of time dilation using a light clock, specifically addressing the relationship between the moving frame (B frame) and the stationary frame (A frame). The key equations derived include the use of Pythagorean theorem in Minkowski geometry to relate the time intervals for light travel in both frames. The time dilation formula is established as T_E = T_C / √(1 - v²/c²), where T_E is the time in the stationary frame, T_C is the time in the moving frame, v is the speed of the moving clock, and c is the speed of light. The discussion clarifies common misconceptions regarding the vertical and horizontal components of light travel in this context.
  • Understanding of special relativity concepts, particularly time dilation.
  • Familiarity with Minkowski geometry and spacetime intervals.
  • Basic knowledge of Pythagorean theorem and its application in physics.
  • Ability to manipulate algebraic equations involving variables and constants.
  • Study the derivation of the Lorentz transformation equations in special relativity.
  • Explore the implications of Minkowski geometry on time and space measurements.
  • Learn about the experimental verification of time dilation effects in high-speed particles.
  • Investigate the relationship between gravity and time dilation in general relativity.
Students of physics, educators teaching special relativity, and researchers exploring the implications of time dilation in theoretical and experimental contexts.
rgtr
TL;DR
## T_B = {T_A} {gamma} ##
In this picture it shows a light clock. Let's use the moving light clock example.
Am I essentially calculating the b component of moving clock.
Assume the moving frame is the B frame.
Assume the stationary frame is the A frame
https://simple.wikipedia.org/wiki/Light_clock
Or essentially the b component of the picture below. Am I essentially calculating Light time for the vertical component?
Does this have any more profound implications?
Did I make any mistakes in my thinking ?
triangle image
In post #15 I asked the question but someone recommended I start a new post and link the the original thread. Here it is https://www.physicsforums.com/threa...ing-by-t_stationary-for-light-clocks.1015831/ .
The length of the hypotenuse of the right triangle is the distance which the light moves from the floor to the ceiling of the car for people at rest on the Earth. Divide it by c and it's time which the clocks at rest on the Earth tick for one way, say ##T_E##. Double it for go-return.
The height of those triangles, H, is the distance which the light moves from the floor to the ceiling of the car for the passengers. Divide it by c and it's time which the clocks at rest in the car tick for one way, say ##T_C##. Double it for go-return.
As for one way tick counts Pythagoras theorem says
H^2+v^2T_E^2=c^2T_E^2
where v is speed of the car, and
H=cT_C
Solving the two equations
T_E=\frac{T_C}{\sqrt{1-\frac{v^2}{c^2}}}
No. You are calculating the time for light to travel along the hypotenuse and expressing this as a ratio to the time taken for light to travel the vertical marked in your triangle diagram.
The reason for the apparent coincidence is fundamentally related to Minkowski geometry, which is the geometry of spacetime. In Euclidean geometry the distance between two points that are separated by ##(\Delta x, \Delta y, \Delta z)## is ##\Delta l##, where $$\Delta l^2=\Delta x^2+\Delta y^2+\Delta z^2$$ This is true in any reference frame - if you have rotated your axes compared to mine you will have different ##\Delta x, \Delta y, \Delta z##, but ##\Delta l## will be the same.
Minkowski geometry doesn't cover space, though. It covers spacetime. The equivalent to the above is that two events separated by ##(\Delta t, \Delta x, \Delta y, \Delta z)## are separated by a "distance" (formally called interval) defined by $$\Delta s^2=c^2\Delta t^2-(\Delta x^2+\Delta y^2+\Delta z^2)$$(NB: some sources define this with the opposite sign - either convention is fine and you just have to get used to checking your signs obsessively.) Again, if you are using a different frame with different coordinates you will have different ##\Delta t, \Delta x, \Delta y, \Delta z## but you will agree with me on ##\Delta s^2##.
So, in the case of the light clock, one frame says that the bottom and top reflection events happened at the same place (so ##\Delta x##, ##\Delta y##, and ##\Delta z## are all zero) and separated by some time ##\Delta t=T_A##. The other frame says that the reflection events were separated by ##\Delta x'=b##, ##\Delta y'=0##, ##\Delta z'=0##, and time ##\Delta t'=T_B##. But the two frames must agree on ##\Delta s^2##, so you can calculate ##\Delta s^2## in both frames and equate them:$$c^2\Delta t^2=c^2\Delta t'^2-\Delta x'^2$$
If you rearrange that you can make it look like Pytharoras' theorem applied to one of the right triangles in your image - that's the coincidence. It follows just from the presence of the minus sign in the Minkowski equivalent of the distance formula. It's pretty specific to the case where events happen at the same location in one frame.
I think I meant to say horizontal component. Saying vertical component was just a mistype. Whoops.
Direction of vertical perpendicular or Horizontal transverse do not matter with the discussion when we disregard usually tiny gravity effect of GR.
  • · Replies 22 ·
  • · Replies 54 ·
  • · Replies 16 ·
  • · Replies 88 ·
  • · Replies 55 ·
  • · Replies 36 ·
