When is Pascal's Principle applicable?
5 replies · 3K views
eprparadox
Which of the following statements about Pascal’s principle is true?
A. It is valid only for incompressible fluids
B. It explains why light objects float
C. It explains why the pressure is greater at the bottom of a lake than at the surface
D. It is valid only for objects that are less dense than water
E. None of the above are true
The answer is suppose to be E. I thought it was A. I thought Pascal's principle was only applicable to incompressible fluids.
So if A isn't true, then is Pascal's principle true for gases? What are the limits of pascal's principle?
Thanks
@Chestermiller here is my most precise definition:
A change in the pressure applied to an enclosed incompressible fluid is transmitted undiminished to every portion of the fluid and to the walls of its container.
(note that this was copied from the book and I know it includes incompressible in it. )
This is not my understanding of Pascal's principle. For what it's worth, my understanding is that, at a given location in a fluid, the pressure acts equally in all directions (i.e., is isotropic).
it sounds like time to ask your professor about what the book says. this statement sounds like a special case (like how we can use incompressible fluids)
