When will computer hardware match the human brain?
39 replies · 20K views
Carlos Hernandez
(Received Dec. 1997)
Hans Moravec
Robotics Institute
Carnegie Mellon University
Pittsburgh, PA 15213-3890, USA
net: hpm@cmu.edu
web: http://www.frc.ri.cmu.edu/~hpm/
ABSTRACT
This paper describes how the performance of AI machines tends to improve at the same pace that AI researchers get access to faster hardware. The processing power and memory capacity necessary to match general intellectual performance of the human brain are estimated. Based on extrapolation of past trends and on examination of technologies under development, it is predicted that the required hardware will be available in cheap machines in the 2020s.
Complete text at http://www.jetpress.org/volume1/moravec.htm
Any opinions on how plausible all of that is, what the consequences will be if true, and so on?
In the same category but going a bit further is "How long before superintelligence?" by Nick Bostrom.
The pure calculation speed of the computers have long exceeded the human brain, however, the "creativity" of the computers may take more than just a few decades to exceed the human brain.
In an article in Byte magazine (April 1985), John Stevens compares the signal processing ability of the cells in the retina with that of the most sophisticated computer designed by man, the Cray supercomputer:
"While today's digital hardware is extremely impressive, it is clear that the human retina's real-time performance goes unchallenged. Actually, to simulate 10 milliseconds (one hundredth of a second) of the complete processing of even a single nerve cell from the retina would require the solution of about 500 simultaneous nonlinear differential equations 100 times and would take at least several minutes of processing time on a Cray supercomputer. Keeping in mind that there are 10 million or more such cells interacting with each other in complex ways, it would take a minimum of 100 years of Cray time to simulate what takes place in your eye many times every second."
that really isn't true, while computers may be able to crunch numbers more effectively then a brain, the calculational capacity of a computer is much less than a brain, it is about the equivilent of a cockroach currently. The difference is parallel processing ability. Remember a computer can only do one calculation at a time. The brain, while it calculates slower, can do thousands of calculations simultaneosly. You can talk, walk, chew gum, breath, beat your heart, look at things, hear things, and do a hundred other things subconsciously all at the same time. I believe, that high speed supercomputers do something around
http://www.aeiveos.com/~bradbury/Authors/Computing/McEachern-RH/HaMIAEV.html
Looked at in another way if there are 1012 neurons in the brain, each performing a filtering process equivalent to performing one million arithmetic operations per second, that equals a total of one billion billion operations per second. Because of the limited dynamic range of the signals transmitted by neurons (not requiring more than about 8 bits to represent each measurement of a signal), these operations are somewhat simpler to perform than the "floating point" operations commonly used to characterize the computational power of computers. Nevertheless, the signal processing power of the brain, expressed in billions of floating point operations (gigaflops) is still on the order of 100 million gigaflops. That is millions of times more powerful than the fastest supercomputers yet built. But it is only about equal to the probable processing power of a personal computer several decades from now.
OK, the brain has billions of cells.. each cell may have between one and thousands of connections, constantly growing and other dying.
A transistor has three (?). And they can store.. 2 states? A brain cell has a state between 0 and 1.
So.. err.. never.
An individual neuron is a very complex little machine, and can support different states in different locations, and coordinate the different states inside the cell. It's more like a simple CPU than a bit switch.
Hans Moravec
Robotics Institute
net: hpm@cmu.edu
ABSTRACT
I am not sure...but it's not possible :(
As my teacher told, as your eye can't see your self...thus your brain doesn't know how it works :(
Indeed. One of the best ways to describe a neural network is consider each neuron to be a small computer (it can also 'store' a number of variables). These 'computers' interact with each other in a strictly defined manner.
When a computer first has an out of circuit experience and then creates its own religion.
My real guess; don't know. There is too much about the brain and potentially other related mechanisms to consider. For example, Chopra argues that the immune system is a part of our "intelligence". He describes it as a circulating intelligence. He is not the first to argue that intelligence is not limited strictly to the brain. Could a complete description of our mind require other factors not even considered yet?
Not my idea but I thought it was worth mentioning.
The brain is one of the most complicated things on Earth.
I vote never.
I vote soon!
(and transisters have more then 2 states, it is an analog devise-within limits, and its range is about half as much as a nauron-Push-pull anybody?)
A transistor may be an analog device but those in computers are designed to operate in 2 states. Until you design and perfect an analog computer, it will be more of the same old. Faster, more memory, etc. Until a system is self aware, it is not even comparable to the human brain. I seriously doubt that if you took all of the computer power that has EVER existed and networked it to the best of our abilities it wouldn't even resemble an incredibly crude human brain even at slow speeds.
The first computers were analog :cool:
But i think it would be more like bio-neural circutry (as on Star trek(little c thingy) Voyager)
Any way! A human can simply design a computer by using his brain effort but a computer will never design a human at any means. That means a human brain is capable of doing much more than anything under the sun. Thats the reality and it will remain till then!
When do you think we will make a computer that can learn and think for itself? a computer with free will? a computer with emotions?
do you think we will ever invent thinking, feeling, "alive" robots? eg AI
I do think that the human brain can do more than that we do. Everything in the universe, the earth, planets, is bases on frequence, electromagnetic frequence, and like they call shakings. The way humans react, or every being, is instructed by the universe, by the sun, if the sun changes in magnetude, we beings in the universe depending the sensitifness, reacts different to what the universe instruct to do. Everything is based on light, frequence and shakings. just like electricity but in higher form, level.
The brain reacts on what it is told to do, if you go to higher level of shaking, thinking, frequency with the mind, the neuron will start getting scharper of level of sensitifness. will shake in whitch way it is instruct to do.
In the recent society, learning patern, the human mind is not instructed how it can evolved how to use the mind in a better way. the society gives on the informatie what is has been doing for the last 1000 of years to do. When you start acting with the mind in a different way, the mind will in collaboration with the nature make a different way how to deal with situations. So it will avoid things people don't want. Society, people think about money how to survive, to earn as much as possible to have a good live. that is really good, at stake of the planet place they live on.
I don't know if it's mathematically possible. I remember reading in "Introduction to the Theory of Computation" by Michael Sipser, that Kurt Godel, Alan Turing, and Alonzo Church discovered that computers can't solve certain "basic" problems which are solvable to humans - such as being able to prove if a mathematical statement is true or false.
Scientists in the field of neurology know very little about the human brain, the very fact that humans aren't digital shows what kind of difficulties an engineer might face in trying to recreate the human brain.
Besides, isn't the very definition of "artificial intelligence" is intelligence being mimicked is intelligence? That if something acts intelligent then it is intelligent? I think when some people talk about a machine being as "smart" as a human they're talking about something that acts a lot like a human but is missing something somewhere.
I don't think its possible. Humans can think original thoughts. We can create something absolutely unique which has no connection to anything around us. One example is chess. I think I read somewhere that the total number of possibilities for two or three consecutive moves is over 4 billion, but a grand master intuitively picks out the best ones.
Also, if you've read "Zen and the Art of Motorcycle Maintainence" by Robert Pirsig, then the arguments he brings up as to how we get ideas and think creatively are based not on mathematical calculations but more on intuition unique to every person. I don't know if I am being very clear, but the book's worth a read in any case. This question is more one of philosophy than anything else.
I'd say sometime between now and thirty years from now. The human brain will still have advantages then, though, especially in terms of redundancy. CPUs aren't expected to work if damaged, but the human brain has evolved to be able to take quite a pounding and still go on (damage like Alzheimer's and PTSD notwithstanding).
I agree, and interpret 'intuition' as 'heuristic'. We don't solve systems of nonlinear equatiosn exactly to determine how our 2D vision corresponds to a 3D world, but use shortcuts to come up with solutions that are usually close to being correct. Optical illusions and failed depth perception are examples of the limitations of this method.
I think when mentioning and comparing with analog and digital devices, one should consider that not even the potential and abilities of an axon counts but the quality and quantity of the chemicals released at the synaptic endings. So, it seems to be more complicated...The logic of digi works with 2 values, an analogous machine (if well controlled) might have more states, that is "levels of truth". Here a technical question arises; how well can we "level" (define and manipulate states) an analogous machine? Can we level it in a "quasi continuous way", or we can only define and work with finitely many states? Questions about the brain: how many "states" can a nerve cell have and how many can it generate in its surroundings? Can these states generate "new" states? The attempt to define the above mentioned concepts, or trying to compare these with the theoretical functioning af the brain is challenging.
When it comes to the very theory/philosophy-side of the question, I tend to sense a paradox.
don't they already? i mean that computers can compute billions of calculations per nanosecond. take tic tac toe, a computer plays millions of games in the span of about a second to logically determine the best move, and after a few games they learn your moves and modify their tactics. most people won't play that many games in a lifetime.
I think that it's only a matter of time before computers become as smart as people. Whatever that means. Perhaps when computers can do it, it won't be called "intelligence" anymore.
In a certain sense, computers are really already "intelligent"... years ago, computers were people who had real jobs crunching numbers. Nobody counts crunching numbers like that night and day a sign of intelligence anymore, since machines can do it. I think a fairly sizeable cross section of people will simply not be able to admit that what computers do is called "intelligent"... not now, not ever.
When it acts like a vertical primate. Or did I deliberately miss the point, in that the OP was considering a small and insignificant portion of the cortex for comparison.
Never. Also, humans will never do the following things:
- Harness fire
- Understand gravity
- Make a heavier than air object fly
- Put a man on the moon
- Cure diseases
These things are way too complicated. Never going to happen. Sorry.
But seriously, I can't believe people are voting never. Talk about short-sighted. There is nothing magic about the brain, amazing gift of nature that it is.
Oh well. We'll just add your quotes to these one day:
"The abdomen, the chest, and the brain will forever be shut from the
intrusion of the wise and humane surgeon".
--Sir John Eric Ericksen, British surgeon, appointed Surgeon-
Extraordinary to Queen Victoria 1873.
"Drill for oil? You mean drill into the ground to try and find oil?
You're crazy."
--Drillers who Edwin L. Drake tried to enlist to his project to drill
for oil in 1859.
"Heavier-than-air flying machines are impossible."
--Lord Kelvin, president, Royal Society, 1895.
"Everything that can be invented has been invented."
--Charles H. Duell, Commissioner, U.S. patent office, 1899
- Cure diseases
Actually, computers have already found some novel cures for example:
http://news.bio-medicine.org/biology-news-3/Computer-aided-protein-design-wins-prestigious-AAAS-Newcomb-Cleveland-Prize-12989-1/
and
These were the best examples I could find off the top of my head but there have been many cases where a computer that analyzed a genetic sequence found ways to cure a disease that researchers hadn't anticipated.
Using advanced learning and data mining techniques computers have found novel solutions to problems in other field as well:
http://www.genetic-programming.com/humancompetitive.html
I think that computers will one day be able to compete with humans in every field that demands some form of intelligence. This doesn't mean that the computer will be able to simulate the brain. Many people in this post are forgetting the fact that almost no problem has one "correct" way of solving it. The computer might not be able to simulate everything the brain does - just like it's hard for it to simulate any complex physical system - but I think that it'll be able to solve the same problems using a different approach.
I once read (I forget where) that people define intelligence as "anything computers can't do". At first chess was the holy grail of AI, then learning, then ... religion?
I agree with most of what's written here:
http://web.media.mit.edu/~minsky/papers/ComputersCantThink.txt
It is too easy to say things like, "Computer can't do (xxx), because they
have no feelings, or thoughts". But here's a way to turn such sayings into
foolishness. Change them to read like this. "Computer can't do (xxx),
because all they can do is execute incredibly intricate processes, perhaps
millions at a time". Now, such objections seem less convincing -- yet all
we did was face one simple, complicated fact: we really don't yet know
what the limits of computers are. Now let's face the other simple fact: our
notions of the human mind are just as primitive.
Does anyone here know what the definition of intelligence is? I don't think we can talk about machines matching the human brain unless we can specifiy in just what way machines will match the human brain. The brain is a product of biological evolution. It has a long heritage dating back at least 300 million years. The human brain contains reptilian structures such as the limbic system which influences how we think and what we think about. I don't believe we'll want to create a limbic system for our future supercomputers, even though it might play a role in our "creativity".
Computer based genetic algorithims can evolve very rapidly to provide original solutions to complex problems by a Darwinian selection process. Are they intelligent? Does it matter what we call a very accelerated selection process as long as it works?
In terms of number crunching, computers have long since out-performed the human brain. However, the human brain is far more powerful because of intuition. A computer has to physically go through all the possibilities before it reaches a good (or the best one). For example. If you were told: "Get from Point A to Point B 100 km away by car (in a large system of streets/highways)" you would upon looking at it automatically eliminate those streets going in the opposite direction to Point B, then you would also, in a split second eliminate those roads that have a lot of traffic intersections to slow you down.
A computer on the other hand will look through all these 'bad' options which will slow down it's processing time. The only way for it to eliminate these possibilities is through human programming - which is 'cheating' in a way.
Another classic example of this is chess. Consider, in 1997 (almost 50 years into the development of computers) a http://en.wikipedia.org/wiki/IBM_Deep_Blue" was finally able to beat a human at a game with 'finite' rules. However, it was able to achieve this through processing power COMBINED with chess strategies that were 'taught' to it by human chess masters. This helped it eliminate a large amount of these 'stupid' moves that humans naturally do not consider. However it was still a big step forward.
I think that maybe in less than 15 years we'll finally have a computer that will be able to beat humans at chess with processing power alone (so it gets 'taught' the rules of chess and that's it, no strategies or tactics).
That's one aspect, where a computer is able to use processing power to simulate creativity in a game with finite rules, at other things such as life in general, it will be a LONG time until they match the human brain at game with no rules. It's far more likely that they will supplement the human brain instead in terms of knowledge retrieval and processing power, but that creative side, there will be a time. But not for a very long time
