Where Can I Find an Affordable Oscilloscope?
  • Thread starter Thread starter MRClark32493
    Oscilloscope
The discussion revolves around finding an affordable oscilloscope suitable for various projects. Participants share their experiences and recommendations, addressing factors such as bandwidth, sampling rates, and specific needs for amateur use versus professional requirements.
  • Homework-related
  • One participant, Matt, expresses a need for an oscilloscope and seeks recommendations for affordable options.
  • Another participant suggests that understanding the intended use, such as required bandwidth and connectivity options, is crucial for making a recommendation.
  • A recommendation for the Rigol DS1052E oscilloscope is made, highlighting its 50 MHz bandwidth and potential for overclocking.
  • Some participants mention that USB oscilloscopes can be found for under $100 but express concerns about their low sampling rates and suitability for serious work.
  • One participant contrasts the convenience of portable scopes with the performance of traditional bench scopes, emphasizing the importance of sampling rate over bandwidth for capturing transients.
  • Matt specifies a preference for a scope with 2-5 MHz bandwidth and mentions the possibility of using one or two channels, along with a desire for waveform extraction options.
  • A suggestion is made that an old analogue scope could be a cost-effective solution, using a USB camera for visualization.
Participants have differing opinions on the suitability of USB oscilloscopes, with some advocating for their affordability while others caution against their limitations. The discussion remains unresolved regarding the best option for Matt's specific needs.
Participants note various assumptions about the intended use of the oscilloscope, such as the importance of bandwidth versus sampling rate, and the potential for different types of scopes to meet amateur versus professional requirements.
MRClark32493
I am in need of an oscilloscope due to recent projects that i have been working on. I have used ones before, but now need my own. I know little about them, and am not looking to spend to much money. Is anyone selling one that is in good condition, or does anyone know of one that i could get for fairly cheap that works fairly well. Thanks
~Matt
~Matt
It will help us if we could know more about what you will use the 'scope for. What bandwidth do you need, what memory depth, how many channels, what kind of connectivity for pulling out waveforms (Ethernet, USB, floppy, etc.)?
The Rigol DS1052E 50 MHz bandwidth is a good deal
http://cgi.ebay.com/Rigol-DS1052E-Digital-Oscilloscope-50MHz-2CH-1G-/150444190623?cmd=ViewItem&pt=BI_Oscilloscopes&hash=item23072c2b9f
and can be overclocked to 100 MHz bandwidth if needed.
If you don't need lots of clever triggering and relatively low (say 25MHz) bandwidth you can get USB scopes for <$100
I would generally stay away from USB scopes. They are just too cheap, with small sampling rates, and are just not suitable for professional, and even most amateur work.
Depends what you need it for - great for on-site trouble shooting, wouldn't swap a modern bench scope for it though!
My pico scope does a lot more (and at higher bandwidth) than the first HP DSO that we paid $10,000 for 20 years ago.
It's also lot more convenient to have in the bag with my laptop than to always carry a Tek 475 everywhere just in case.
But there are some very tempting <$400 LCD scopes though if you need a benchtop instrument.
That's true, the OP didn't say what he needed the scope for.
In general, the sampling rate is more important than the bandwidth. It allows you to catch more transients, which is absolutely necessary for observing and troubleshooting digital and analog signals. Where as a low sampling rate scope is only good for observing long steady state signals.
Most general purpose USB scopes have very low sampling rates 10-50 MS/s, except maybe one of those high end ones that cost more than a regular scope.
Here is one those better 2000 series picoscopes:
PicoScope 2205 2 + AWG 25 MHz 200 MS/s 16 kS 8 bits
(12 bits) £295.00
$486.75*
and the Rigol in the link above has a 1 GS/s sampling at a same price. The difference between their performance is like comparing a black and white TV vs. a 1080P HDTV.
i would like one that has fairly good sampling, i am an amateur so professional grade is not required, and as for bandwidth, i would need at least to 2-5MHz, as i am not measuring anything more. I would like two channels, however not required, i can use one for everything if needed. if possible a floppy for pulling waveforms, however not required. what else would need to be known before buying one? Thanks
~Matt
All you want is any old analogue scope. It should cost next-to-nothing. Put a USB camera in front of it and you're away
14K
