Where can I get help with Windows XP?
  • Thread starter Thread starter pmb_phy
    Windows
The user is experiencing a critical issue with their computer, which only boots in safe mode due to a black screen and blue screen error during normal startup, indicating a memory dump. They seek assistance for troubleshooting and potential fixes. Suggestions include formatting and reinstalling Windows, specifically targeting the C drive while preserving data on the D drive. The process involves booting from the Windows XP installation CD and adjusting the BIOS settings to prioritize the CD-ROM in the boot sequence. Clear instructions are provided for partitioning the drive during installation. The user expresses difficulty in booting from the CD but is guided on how to proceed with the installation process. Ultimately, they successfully complete the reinstallation after following the provided steps.
pmb_phy
My computer is fried. I can only boot up in safe mode. Otherwise as soon as I login to my computer after bootup the screen goes black, then a blue screen comes on saying there is a problem and it starts doing a memory dump to disk. I've tried fixing this all day long but am at a loss.
Where can I go for help? Any ideas how to fix this?
Pete
Computer science news on Phys.org
Have you tried to format and reinstall windows?
Where you could go for help?
I guess you could go to a psychiatric hospital, but i do not think that is where your problem lies :)
nah, just kidding. Just do what dduardo said, format the drive (or just the partition) that Windows boots on (Where to the ARC path indicates.) (I guess that you have it on C: )
If that does not work then, too bad :) You will probably be away from your computer for a couple of weeks then.
How do I do that? I reinstalled windows but that really isn't the same. I wanted to wipe my C disk clean and reinstall but I don't know how.
My system stuff is on drive C. My data is on drive D. Can I wipe C without touching D? I assume/hope so since this is why I made two partitions.
Thanks
Pete
Boot from the Win XP cd and go through the installer. You should reach a section for partiioning. Just delete the C drive and recreate it. Then select that drive for windows to install on. Then just go through the rest of the procedure. You'll probable need to re-activate, which I would assume is easy, but I've never done it. This whole procedure is no more difficult than installing any other program.
Have you ever tried this? I did and I didn't see a section for partitioning.
But here goes. If I disappear from existence then you'll know what happened. :smile:
Pete
It didn't work. I can't figure out how to boot from the CD.
How do I do that?
Can't I simply format the C drive and then boot?
Pete
I've installed win xp many times.
To boot from the cd you need to set the boot sequence in your bios to read your cdrom first before reading the hard drive.
The partition stage should look like this:
http://www.blackviper.com/Articles/OS/InstallXPPro/images/image1_9.html
Okey dokey! All done! Muchus Gracias!
Pete
