What Causes Heat to be Released in a Deformed Spring?
  • Thread starter j-lee00
  • Tags
    Heat
In summary, when a spring is compressed and extended multiple times, the temperature of the spring increases due to the transfer of energy from the applied force to the molecules of the spring. This increase in temperature is a result of the molecules' average kinetic energy rising, as the energy is stored in the spring and then released as heat when molecular links are broken during deformation.
j-lee00
95
For example
If I extend and compress a spring numerous times the spring will increase in temperature.
Where does the rise in temperature come from?
The atoms that "make up" the spring from an atomistic point where does this rise in temperature come from?
Science news on Phys.org
First off, temperature and heat are not the same thing.
Heat is the energy transferred from one object to another due to a difference in temperature.
Temperature is just the average kinetic energy of the molecules in a substance.
Correct, it was a mistake however can be rationalized, with the fact that there is heat "caused by" the compression and extension of the spring.
But the point is was, where does the temperature rise come from?
Is your ans that the average KE is increased of the spring particles?
From a rise in the kinetic energy of the substance. You put energy into the spring and the molecules reacted accordingly.
But how does the KE rise if it is assumed that atoms are spheres which interact elastically?
You just answered your own question: they don't quite act elastically.
How do they interact then in this case?
In theory, a spring does not produce heat, because all energy used to compress it, is "stored" until it is released.
In practice, metal spring can be deformed (sagging). If too much force is employed it can leads to rupture. This, obviously, means breaking molecular links (even deformation). When links are broken, energy is released in the form of heat.
1. Where does heat come from and what is its source?
Heat is a form of energy that is produced by the motion of molecules or atoms. The source of heat can vary, but it is typically generated by processes such as friction, chemical reactions, or nuclear reactions.
2. How is heat transferred?
Heat can be transferred through three main mechanisms: conduction, convection, and radiation. Conduction is the transfer of heat through direct contact between objects, convection is the transfer of heat through the movement of fluids, and radiation is the transfer of heat through electromagnetic waves.
3. What materials are good at trapping heat?
Materials that are good at trapping heat are called insulators. These materials have a low thermal conductivity, meaning they do not allow heat to easily pass through them. Examples of good insulators include air, wool, and rubber.
4. How does heat affect the temperature of a substance?
When heat is added to a substance, it increases the kinetic energy of its molecules or atoms, causing them to move faster and collide more frequently. This increase in movement results in a rise in temperature. Conversely, when heat is removed from a substance, its temperature decreases.
5. Can heat be created or destroyed?
According to the Law of Conservation of Energy, energy cannot be created or destroyed, only transferred from one form to another. This means that heat cannot be created or destroyed, but it can be converted into other forms of energy, such as light or electricity.
  • Thermodynamics
  • Thermodynamics
  • Thermodynamics
  • Thermodynamics
  • Thermodynamics
  • Thermodynamics
