Where does the energy for gravity come from?
32 replies · 9K views
feyn
Basically my question is this( and sorry if my formulations are at times a bit sloppy, English is not my first language) :
1. we know energy can neither be created nor destroyed, it can only neconverted from one form into another
2.We know that an object in space, that is moving, will move along a straight line unless acted upon by some kind of force.
3. if I want to change the direction of an object in space, I have to invest some energy to do that
4. The moon moves around the earth, because there is a constant pull from gravity. Very roughly we could say that gravity pulls the moon towards Earth , but by the time the moon would have hit the Earth , the moon has already moved forward enough enough, so that it is now a quarter turn further (yea, i know it the orbit is not really round, but it is not too bad an approximation to understand the basics. I w ill ignore for now the influence of the sun, th e other planets and whatnot else)
5. If the pull of gravity is constant , where does this pull get all the energy from ? I mean the moon is a big heap of rock. If we would have to move it, we would need some serious thrust engine or something, needing one hell of a lot of energy. So where does this energy come from, which the Earth constantly "invests" to force the moon into it's orbit.
6. Another example would be a comet or a meteorite. When it flies towards Earth it constantly accelerates, getting more and more kinetic energy while flying towards the planet, till it hits it often with impressive speed. Again where does this energy come from ? my first point says energy cannot be created, so it Earth loosing energy over time?
7. In the end there can be only 2 solutions , either gravity gets weaker over time, loosing it's energy slowly but surely (which does not really make sense, since afaik that is clearly not what happens) some other kind of energy is constantly transformed into gravitational energy, which begs the questions what that energy that is , if and how it is replenished (and if it not, what happens when it runs out), and how come this transfer is so exact (since gravity does not seem to get weaker or stronger, so the transfer seems to exactly make up for the energy lost all the time, which would it make it quite a curious energy source)I hope my english and my science sucked not too bad to get my point across
The energy comes from the objects initial position, going all the way back to just after the universe was created (big bang theory). So at some point in time, the moon ended up orbiting the earth. In an ideal case, the total energy consisting of gravitational potential energy and kinetic energy of the Earth and moon is constant. In reality, only angular momentum is conserved and some energy is lost to heat due to tidal interaction. Wiki article about this effect:
http://en.wikipedia.org/wiki/Tidal_acceleration#Angular_momentum_and_energy
This point is not correct. It takes energy to increase speed, but not to change direction. Of course, you can come up with examples where energy is used to turn, but those are examples of inefficiencies where energy is being wasted somewhere.
What goes up, must come down. Well, not really, but basically, it takes energy to launch something up from the ground, because it must move against the direction that gravity is pulling. The object slows down as it increases height because the energy is converted into gravitational potential energy. Eventually (if it isn't launched with greater than the escape velocity), the object will fall back down and the energy is returned to the object. The gravitational potential energy is converted back into kinetic energy, and you end up with the object coming down with the precisely the same speed as it was launched up with, if nothing got in the way.
Objects in space have a large gravitational potential energy to start with. Where did this initial energy come from? The big bang.
Let us get back to my meteorite. If it accelerates towards earth, it gains momentum hence energy, where does that energy come from ? In my naive understandingn it must somehow come from Earth , since Earth is accelerating it
It gains kinetic energy, but loses potential energy. The sum of all energies in the system doesn't change.
Not so. Changing direction requires force, so energy must be used.
This is incorrect. The rate of doing work on an object (which is the time rate of change of the energy) is F⋅V. In a circular orbit, F and V are perpendicular, so F⋅V = 0. There is a force, and there is an acceleration, but no work is done, and the energy of the orbiting body does not change. Note that DaleSpam said the same thing.
No. Not all forces use energy:
http://hyperphysics.phy-astr.gsu.edu/hbase/work2.html
http://en.m.wikipedia.org/wiki/Work_(physics)#Constraint_forces
As phyzguy said if f.v is 0 then the power is zero. You can think in terms of the potential energy. If you stay at the same potential then no energy is used. The force is the gradient of the potential. So if you move perpendicular to the force then you stay at the same potential and no work is done.
Let's break this down into even more ultra basics, for the newbies. What is the first formula you learn for energy transferred by work: force times distance. I can apply any force I want without doing work, so long as I don't move the object in the direction of the force. In the orbits mentioned the distances between, for example Earth and moon, are fixed. No change in distance, no energy.
5. If the pull of gravity is constant , where does this pull get all the energy from ? I mean the moon is a ****ing big heap of rock. If we would have to move it, we would need some serious thrust engine or something, needing one hell of a lot of energy. So where does this energy come from, which the Earth constantly "invests" to force the moon into it's orbit.
I don't think gravity uses energy cause according to Newton anything made of mass has its own gravity the more mass the more gravity.as far as I can say it is related to the natural curvature of space. And I bet gravity does not use energy and gravity is not exactly a force
A handy way of visualising this is to view gravity as like a spring or elastic band. The potential energy stored in the gravity 'band' between two objects is a result of separating the two objects. You can put this energy in yourself - putting a satellite in orbit using a load of chemical energy rocket fuel, for example. If the satellite falls back to Earth the kinetic energy it acquires in falling is the energy you put into putting it up there to begin with.
In the case of a meteorite, the potential energy in the gravity 'band' is also the result of the original separation of the meteorite and Earth, and that separation work was done by the Big Bang and the expansion of the universe. The "natural" position for everything is as a single point, separating things out from that point required energy, that energy is recovered when the two things fall together under gravity.
I think it would be more correct to say that it takes energy to CHANGE speed, not just increase it. Either one (increase or decrease of speed) will change an orbit [Dale, I know you know this, I'm just pointing it out for the OP]
Increasing speed takes energy. Decreasing speed releases energy. Changing direction does neither.
Of course if you use an inefficient process (like squirting a hose at the front of a super-tanker to slow it down), you may wind up using energy even though none is required.
How do you decrease the speed of a spacecraft without expending energy?
Reverse slingshot, for example.
Agreed that there are there are no efficient ways if you are deep space depending on using reaction mass and fuel that are carried on board.
Strictly speaking, a reverse slingshot only doesn't use the spacecraft 's energy - the work is done by the planet.
In a slingshot, energy is gained by the spacecraft at the expense of the planet. In a reverse slingshot, energy is gained by the planet at the expense of the spacecraft . So yes it does use the spacecraft 's energy.
The moon stays at a constant distance from the Earth (at least for the purposes of this question) so gravity, which only works in that direction, doesn't move the moon. Fridge magnets need no energy source to stay up for the same reason.
Probably the only time I can recall Richard Feynman getting testy, was when an interviewer implied he should surely be able to say how the magnetic force works. Professor Feynman's reaction was, more or less, that one would have to go back into decades of learning and build up, step by step, on the most fundamental foundations of that facet of science before such a question could be answered.
That was magnetism, and given enough time, he could have answered that question. I feel fairly sure he wouldn't have used gravity, even in the most simplistic of analogies, to describe that answer.
And the relevance of this reply is ?
CWatters was trying to explain that a force only requires energy if it moves through a distance. This is in reference to the OP's original question about the energy expenditure of keeping the moon in its orbit. A static force requires no energy expenditure, just as supporting a 1 ton weight hanging from a hook requires no energy expenditure. It appears from your response that you missed the point completely.
Sorry, I supposed it was an overreaction to comparing magnetism with gravity. I take your point about "a force only requires energy if it moves through a distance." but using that comparison, again seems to be describing gravity as a force - and implying similar rules.
Nearly dawn here. Will get to the point tomorrow.
Not quite - the point is perhaps semantic, but while the reverse slingshot reduces the spacecraft 's kinetic energy, the spacecraft does not "expend energy" to decrease its velocity. Going back to the original question:
and your answer:
If we take a reduction of the spacecraft 's speed as "expending energy", as you've stated it above, then there is of course no way to reduce the spaceraft's speed without expending energy, because a reduction in speed necessarily implies a reduction in the spacecraft 's kinetic energy (unless it gains mass) - reverse slingshot slows the spacecraft down, thus reduces its kinetic energy, thus is "expending energy" if we use your second definition, and is therefore not an answer to the question asked originally, in which you presumably used a different definition.
So you can either define "expending energy" as meaning "applies energy itself to reducing its own velocity" or as "has its energy reduced" - your first answer is correct using your first definition but not your second, while your second answer is correct using your second definition but not your first one.
I agree. The point is semantic.
The reverse slingshot does not expend energy because there is a surplus of work coming out of the system of interest. I take "expending energy" in the sense of burning fuel or draining batteries -- drawing down free energy reserves. The bulk kinetic energy of a planetary body comes under that heading. If it is reduced, we are "expending energy". If it is increased then we are doing the opposite of "expending energy".
Gravity is a force and not energy. It is a mystery quality of mass that has never been explained in a logical manner. The tools we currently have are not able to crack the mystery of gravity. Maybe after a few hundred more years of attempting to figure it out man kind will learn what gravity is.
I will try to do the best to make my English is acceptable.
I think that the roundabout reasons explaining lack of work in system Earth - the Moon don't answer the main issue. The answer of Rob Benkham is good that at once defines impossibility of understanding of the mechanism of transformation of energy without understanding of the mechanism of the operating force, namely - the gravitation. However when I reflect on similar things, without paradoxes doesn't do. Here example:
Let in the beginning two bodies - Earth and the Moon f.e., be very far from each other and are in rest. Let total mass of system of these two bodies of Mo. Let the system was out of balance and mutual falling of two bodies at each other began. It is clear that the mass of bodies start growing in a reference system of the system's mass enter.
After falling both bodies make one body with the mass center which which remained in the original position and total mass is equal to the sum of rest mass and masses of thermal energy and energy of radiation. That looks like the initial mass of Mo is made by the sum of mass of rest of bodies and mass of their gravitational fields! paradoxically that the mass of a gravitational field of each body isn't summarized to the mass of the body. That is the first paradox. It would seem, from the point of view of formal logic, a contradiction isn't present as to potential energy of two infinitely far bodies there has to correspond some mass. Also it is the mass of gravitational fields.
On the other hand both bodies weaken a field of each other when they are divided by distance. And when they make one body, that field represents the sum of their fields in any point of space. Antispeeches that more powerful field has smaller mass. That is the second paradox.
I think that somewhere in my reasonings there are a logical mistakes. I will be glad to hear opinion of participants of a forum.
Sorry so much of so much "of" (:)) in my English. But I sincerely hope that the essence is clear.
I ain't no expert, but my meager knowledge leads me to bring back the good old bowling-ball idea. Basically, according to that model space is like a surface and large objects create dents or depressions, and say the moon is caught in Earth's "dent," what this means is that technically the moon is going "straight," but because of the "dent" it is going in a circular motion, so therefore even though the moon is going in a circle it uses the same amount of energy that it would use going straight.
please continue ...
No, that is not "clear"; it's wrong. You are leaving out gravitational potential energy. The total mass Mo of the system, as measured from very far away, at the instant that the two bodies are at rest relative to each other, is not just the sum of the two rest masses; it's the sum of the two rest masses, plus the gravitational potential energy associated with the interaction between them.
Yes, but that is the same as the original total mass Mo. Consider the process in two steps: first, the two bodies fall together. At the instant just before they collide and form one body, the total mass of the system, as measured from very far away, is still Mo, because, as above, Mo originally included the gravitational potential energy. All that happens when the bodies fall together is that the gravitational potential energy gets converted to the kinetic energy of the two bodies as they fall together.
Second, after the two bodies have collided and formed one body at rest at the center of mass of the system (note that this means the collision is perfectly inelastic), the kinetic energy of the two bodies has been converted to thermal energy and energy of radiation. The total mass of the system, as measured from very far away, is still Mo.
So there is no "paradox" anywhere; you just need to be clear about what is actually included in the total mass of the system, as measured from far away.
When an object is raised in a gravitational field the mass and total energy of the object increase. When an object is lowered in a gravitational field energy is extracted, and the object loses an equivalent amount of mass as it gives up energy. When water flows from a high reservoir to a lower reservoir and a turbine between those reservoirs extracts energy from the water, the extracted energy comes from the water in the form of a reduction in the mass of the water. A hydroelectric dam, similar to a nuclear reactor, is a device for converting mass to energy.
