Where Is the Electric Field Zero Between Two Charges?
  • Thread starter Thread starter phy43
    Charges Electric
The problem involves determining the point between two positive charges, a 6μC charge at (0,0) and a 1μC charge at (0,1m), where the electric field is zero. The context is within electrostatics, specifically focusing on electric fields generated by point charges.
  • Participants discuss the need to analyze the electric field at various points rather than the force between the charges. There are attempts to derive expressions for the electric fields from each charge and to find the point where the net electric field equals zero.
Some participants have provided guidance on how to set up the problem by suggesting the formulation of electric field expressions for each charge and considering the distances involved. There is an acknowledgment of the need to account for the direction of the electric fields, which may affect the signs in the equations.
There is a mention of potential confusion regarding the distances from the charges and the correct units for charge, indicating that participants are navigating through some assumptions and definitions related to the problem.
phy43
a 6uC + charge is at (0,0) and a 1uC + charge is at (0,1m). Where between them is the electric field equal to 0?
F=qE
F=K(q_1)(q_2)/r^2
F=K(q_1)(q_2)/r^2
F=(9.0*10^9)(1*10^-6)(6*10^-6)/(1^2)
F=5.4*10^-5 (The force each exerts upon each other)
F=qE
Since E=0, F=0
F=0 at:
0=K(q_1)(q_2)/r^2
Find r
0=(9.0*10^9)(1*10^-6)(6*10^-6)/r^2
And this is where we have a problem
You want to study the field from the two charges at various points, not the force between the two charges. Write an expression for the field at point X from each charge. Add to get the total field. (Careful with signs.)
Electric field at distance r for each charge
E=Kq/r^2
E_1=(9.0*10^9)(6*10^-9)/r^2
E_1 = 54/r^2
E_2=(9.0*10^9)(1*10^-9)/r^2
E_2 = 9/r^2
E_net = E_1+E_2 = 54/r^2 + 9/r^2
E_net = (54+9)(1/r^2)
E_net = 63/r^2
0 = 63/r^2
E=Kq/r^2
If a point is a distance X from charge #1, how far is it from charge #2?
E_1 = 54/r^2
Instead of calling the distance r, call it X. Don't plug in numbers right away. (And μC = 10^-6, not 10^-9.)
What direction is the field?
E_2 = 9/r^2
Instead of r, write the distance in terms of X and the distance between the charges.
Note that different directions will get different signs.
Thanks, figured it out.
  • · Replies 30 ·
