Where Is the Electric Field Zero Between Two Negative Charges?
3 replies · 2K views
tuggler
Two points are resting on a string. The first point is resting at x = 6.0 m and has charge q1 =−7.1 µC. The second point is resting at x = −4.0 m and has charge q2 = −4.3 µC.
At what location is the total electric field zero from the two points(other than infinity)?
[tex]E =\frac{KQ}{r^2}[/tex]
[tex]\frac{q_1}{r_1^2} = \frac{q_2}{r_2^2}[/tex]
I divided away the constant K from my second equation because they cancel out when you set them equal to each other.
I don't know what my [tex]r_1,r_2[/tex] should be here?
Why don't you set the distance from the first charge x and define the distance from the other with x and the distance between the two charges? Thus you introduce only one variable in one equation.
Don't forget that the contribution to the electric field from each charge has direction, so, if the point is between the two charges, the contribution from the charge at x = 6 is pointing in the negative x-direction, and the contribution from the charge at x = -4 is pointing in the positive x-direction.
I am not following can you guys elaborate more please?
