Which drawing represents an AC generator?
9 replies · 2K views
Asmaa Mohammad
A magnet bar has been installed in the vertical rotation axis of a coil. Which of these drawings represents an AC generator?
2. Relevant rules
Fleming's right-hand rule.
Fleming's right-hand rule assumes that the coil is in motion, but in the drawings the magnet is in motion, and that's what made me not able to know how to apply it correctly here. So could anyone give me some hints, please?
I think both (a) and (b) could be AC generators, but the problem statement says that only one is correct.
I don't see significant difference between (a) and (b).
Also, what is meant by vertical rotation axis?
kuruman said:
Draw some field lines and see in which drawing(s) they could be in a direction perpendicular to the plane of the loop as the magnet rotates.
Ok, here is it:
And from that figure I would exclude drawing (c), but still (a) and (b) have a chance to be AC generators, right?
I agree with you regarding (a) and (b), and also I don't understand what does it meen by saying "vertical rotation axis"!
The emf should be induced "along" the length of the coil. For this to happen,a component of magnetic field, "linear" velocity (instantaneous) 'v' of the magnet and length of the coil should be perpendicular to each other.
Ok, I think this happens in both (a) and (b), doesn't it?
Looks like it does.
So both a and b can be generators.
cnh1995 said:
Looks like it does.
That's what confuses me actually, because the book says only one drawing is correct. Some people told me that may there be something regarding " the vertical rotation axis" which I don't understand, neither I understand what does it mean by "vertical rotation axis".
If you just rotated b through 90 degrees CCW, you'll get a (I haven't checked the polarity).
So I think both the options are correct.
They have specified the axis of rotation and direction of rotation of the magnet in each case. So you need not think what vertical axis means here.
Does your book provide the answer?
No, it doesn't. But in the problem statement it is clear that it considers only one drawing could be a generator, or that's what I think.
