Which Exerts More Pressure: Heated Air or Water?
  • Context: High School
  • Thread starter Thread starter Xilus
    Air Expansion Water
The discussion centers on the comparison of pressure exerted by heated air versus heated water, particularly in the context of canning operations. Participants explore the implications of heating both substances to 100°C, including potential risks such as explosions and the physical principles involved.
  • Some participants suggest that heating water to its boiling point may lead to an explosion due to steam formation, while the outcome for heated air depends on the strength of the container.
  • There is a proposal to calculate the pressure increases for both air and water under heating conditions.
  • One participant notes that the ideal gas law (PV=nRT) applies to air but not to liquids like water, indicating a limitation in applying the same principles to both substances.
  • Questions arise regarding the presence of headspace in the jars and how it affects pressure and potential explosions.
  • Participants discuss the thermal expansion of water and the glass jar, with calculations suggesting that pressure could reach significant levels, potentially leading to jar breakage.
  • One participant computes the pressure for heated air, finding it lower than expected, and engages in a back-of-the-envelope calculation to estimate gauge pressure changes.
Participants express differing views on the outcomes of heating water versus air, particularly regarding the risk of explosion and the calculations of pressure. There is no consensus on the exact pressures involved or the implications for jar integrity.
Limitations in the discussion include assumptions about the absence of air in the headspace and the simplifications made in calculations regarding the properties of water and glass. The effects of thermal expansion and elastic deformation are noted but not fully resolved.
This discussion may be of interest to those involved in food preservation, canning techniques, or anyone curious about the physical principles of pressure in heated liquids and gases.
Xilus
Lets say you have a jar of water, and a jar of air.
You heat both of them 100C
will either of them explode?
ok just kidding.
which one exerts more pressure, and is hence more likely to explode?
did heating the substance turn heat into force? (force per unit area)
100 C is the boiling point of water, so it's very likely to explode when the water boils into steam. As for the jar of air, it may or may not, depending on the strength of the jar. I wouldn't try it at home, that's for sure.
No, but it does increase the force on the jar since the molecules are moving about faster.
Why not try to work out what the pressure rises would actually be for some sample problems ?
PV=nRT
the constant R doesn't work with a liquid like water.
we could calculate the pressure for the air though! that's awesome.
Is the jar initially full of water, or is the headspace. If the latter, is there air in the head space, or just water vapor?
No headspace. One Jar broke. but 6 made it!
The effect with a totally full bottle would depend both on the expansion coefficient of the water and the glass of the bottle.
The apples were cooked in boiling water. so they probably absorbed a lot of water. that's why i chose water. of course there is lots of other biomass in the applesauce.
How did you determine that there is absolutely no heat space and that you got all the air out when you put the lid on?
Xilus said:
There was a little air at the top. not much.
How much? The volume of liquid water only increases by about 4% when heated from 20 C to 100 C.
I'm guessing that, in this typical canning operation, there actually is a small amount of head space to begin with, and that the liquid in the jar is fairly hot when the lid goes on, rather than being cold. What is the temperature at filling? I would like to estimate the pressure of the jar contents when the temperature is at 100 C? I have done this kind of calculation before when the company I was at was working on the development of plastic soup cans for use by a food manufacturer.
I have seen canning done by boiling the apples in an open kettle, separately boiling (to sterilize) the jars and lids, then filling the jars hot and immediately putting on the lids. The resulting vacuum sucks down the lids. The sucked down lid shows that everything was done hot, and that you have a vacuum seal.
In a home canning operation, one is not supposed to tighten the rings until the jars are removed from the hot water bath. The operating principle is (I assume) based on water evaporating into the head space and displacing the air there. The excess gas should bubble out through the loose seal. As the jars are cooled, the water vapor condenses and the lids are pulled down tightly -- a "vacuum seal".
The head space gives you a nice pressure reduction without a great deal of cooling and associated volume reduction in the liquid contents.
It's easy to calculate the pressure with some simplifying assumptions:
Start at 20 deg C, heat to 100 deg C.
Jar and lid are infinitely stiff, and have zero coefficient of thermal expansion.
Zero air in the water, zero air in headspace.
Density of water at 20 deg C and 1 bar is 998.23 kg/m^3.
Density of water at 100 deg C and 950 bar is 997.85.
Density of water at 100 deg C and 1000 bar is 999.70.
Interpolate to 998.23, pressure is 960 bar.
960 bar X 14.5 = 13,900 PSI. This is an upper limit because it does not include thermal expansion of the glass jar, and elastic deformation of the jar and lid, or the effect of air in the head space.
Adding in the effect of thermal expansion of the glass, and the elastic modulus of the glass and lid, will reduce the pressure. But the pressure will still be high enough to break any normal glass jar. Air in a head space is needed to save the jar.
i computed 18.71 PSI for the jar of air at 100C
its lower than i expected.
Huh? What are you computing?
Back of the envelope: You are increasing temperature from about 293K to about 373K. Call it an increase of 30 percent. So absolute pressure should increase by about 30 percent. In terms of gauge pressure, that's about 1/3 of an atmosphere. One atmosphere is about 15 PSI. So the gauge pressure should be about 5 PSI.
  • · Replies 46 ·
