Which is more accurate when analyzing a circuit (for V, I or R)
  • Thread starter Thread starter AchillesWrathfulLove
    Circuit
When analyzing a circuit, the accuracy of measurements varies significantly between hand calculations, software simulations, and multimeter readings. Multimeters provide real-time measurements of the circuit as built, making them ideal for verifying design conformity, while software simulations offer precise results for theoretical designs, contingent on proper sanity checks. Hand calculations are essential for determining component magnitudes but lack the precision of software or the real-world applicability of multimeters. Each method serves a distinct purpose in circuit analysis, and the choice depends on the specific requirements of the analysis.
  • Understanding of circuit design principles
  • Familiarity with multimeter usage and measurement techniques
  • Knowledge of circuit simulation software
  • Basic skills in hand calculations for electrical components
  • Explore advanced features of circuit simulation software like LTspice or Multisim
  • Learn about Monte Carlo analysis in circuit design
  • Study the impact of component tolerances on circuit performance
  • Investigate best practices for using multimeters in circuit diagnostics
Electrical engineers, circuit designers, and technicians involved in circuit analysis and troubleshooting will benefit from this discussion.
When analyzing a circuit which is more accurate: Using hand calculations, software calculations or using multi-meter. Which one should be relied upon the first?
What are your thoughts? And what do you mean by more accurate? Would your hand calculations or multimeter measurements include a Monte Carlo analysis? And how long would that take? :smile:
All are subject to operator error. But the multimeter would be best by that measure.
Also, the multimeter will measure the circuit as implemented - so if the voltage is suppose to be 5.00VDC and multimeter says 5.02VDC, the difference is between the circuit as designed and the circuit as built. Which one are you interested in?
If you are interested in the circuit as designed, and you are willing to do cross checking, then the software will give you the most precise and reliable results. But you have to know how to good sanity checking.
None is the best, each has it's place.
Hand calculations decide the magnitude of components in possible solutions to circuit dreams.
Computer simulation of possible circuit solutions should confirm your ideas, and helps settle values.
A voltmeter quickly verifies that your circuit conforms to design and simulation expectations.
Later, a multimeter helps identify where the design errors, manufacturing faults or later component failures lie.
Likes dlgoff
Paper first: based on that you should have some understanding on the required accuracy/depth. The comes some simulation if it will be a difficult piece.
If it is something simple, straight then just build it and confirm with a multimeter/oscilloscope.
It all depends ... .
Calculations. based on theoretical values are very different in principle from building and measuring some feature of the circuit's performance. Every element in a built circuit will have a tolerance specified, which will indicate what variations to expect in the final circuit if you carry out an analysis for all combinations of component value spread. That could take for ever but you can sometimes shorten the process by knowing what elements will have most effect. For instance, the feedback components will take care of variations in many other parts of the circuit- but it's not something I'd want to do by hand every day.
Otoh, measuring the circuit characteristics with a MultiMeter will only tell you what happens for just one set of component values. That may be fine if all you wanted was to know the characteristics of just one particular circuit board but it would not be a good basis for carrying on with production of a large number of circuit boards.
  • · Replies 29 ·
  • · Replies 56 ·
  • · Replies 27 ·
  • · Replies 19 ·
