Which is more dangerous series or parallel
  • Thread starter Thread starter bjon-07
    Parallel Series
When comparing the danger of electric shock from identical parallel plate capacitors connected in series versus parallel, the consensus is that parallel configurations pose a greater risk. This is attributed to their higher equivalent capacitance (Ceq), which allows them to store more charge. The increased charge in parallel setups can lead to a more significant shock hazard when discharged. Additionally, the peak current during discharge is a critical factor in assessing danger, with higher currents being more lethal. Overall, parallel connections present a greater risk of electrocution than series connections.
bjon-07
If I identical parallel plate capacitors are hook up in series(case 1) or in parallel (case 2) to a battery and the battery is removed which of the two poses a greater risk of getting electricuted?
I think I would be parallel because in general the have a higher Ceq to hold charge, thus more charge is there to shock you? Is this right?
I believe the greater charge, would present a greater danger.
One can also look at the peak current at discharge - the maximum current is the key factor.
Thread 'What is the pressure of trapped air inside this tube?'
As you can see from the picture, i have an uneven U-shaped tube, sealed at the short end. I fill the tube with water and i seal it. So the short side is filled with water and the long side ends up containg water and trapped air. Now the tube is sealed on both sides and i turn it in such a way that the traped air moves at the short side. Are my claims about pressure in senarios A & B correct? What is the pressure for all points in senario C? (My question is basically coming from watching...
