Which LaTeX editor do you recommend for Windows?
- Topic: LaTeX
- Thread starter James R
- Start date
- Tags
- Latex
13 replies · 5K views · last reply
- Air holes turn silicon wafers into flat ultraviolet focusing mirrors for compact optics
- Quantum gas microscope reveals individual atoms in first tunable three-component Hubbard system
- Scientists achieve record-breaking low temperature on China's space station, paving the way for new physics experiments
Discussion
graphic7
- 2
Typically, I use a port of XEmacs for Win32 whenever I use Windows, or on UNIX/BSD/Linux, I either use some sort of 'vi' (vi or nvi, preferred, but in dire circumstances, vim).
I usually don't bother to generate .dvi output. I just use 'pdflatex' to generate a .pdf (as I probably would've used dvi2ps and ps2pdf, anyways), so when possible I just use 'acroread' or 'xpdf', which uses Ghostscript as a back-end.
Triss
- 80
- 0
emacs is my favorite, almost set up like here http://www.math.aau.dk/~dethlef/Tips/
ComputerGeek
- 383
- 0
chroot said:If you're concerned about entering math into your LaTeX document, I strongly recommend MathType.
- Warren
bleh... just get a reference and use the inline math environment.. ti takes a week to get use to and then your on your way.
ComputerGeek
- 383
- 0
I agree that Texnicenter is the best IDE for Latex on windows... it is easy to compile the documents, highlights the keywords, etc. and all the documentation that you would search for on the web is already there (literally, the exact same documents)
remember though to install MikTeX is you have not already... none of these environments will work without that installed :-)
Staff Emeritus
- 45
ComputerGeek,
I know LaTeX. I built the LaTeX system into this forum
I can still enter equations in MathType an order of magnitude faster, and with less error, than typing the LaTeX commands manually. When writing complex equations manually, I often find myself fighting brace-balancing problems, and I simply have better things to do.
- Warren
- Warren
ComputerGeek
- 383
- 0
I did not mean to insinuate that you were clueless, just that when writing a paper, using the math environment is less disruptive to the writing process than having to open up a separate program to create a mathematical formula.chroot said:ComputerGeek,
I know LaTeX. I built the LaTeX system into this forumI can still enter equations in MathType an order of magnitude faster, and with less error, than typing the LaTeX commands manually. When writing complex equations manually, I often find myself fighting brace-balancing problems, and I simply have better things to do.
- Warren
Different strokes I guess.
Staff Emeritus
- 45
alt-tab, type, copy, alt-tab, paste. I don't find it disruptive. I do, however, find spending three minutes trying to figure out which brace I forgot to close, or looking up (again) how to put slashes through symbols, rather disruptive.ComputerGeek said:I did not mean to insinuate that you were clueless, just that when writing a paper, using the math environment is less disruptive to the writing process than having to open up a separate program to create a mathematical formula.
I guess. You're the one who had to comment on what was only a recommendation of a product I enjoy using, rather than just letting me continue to enjoy using it.Different strokes I guess.
- Warren
ComputerGeek
- 383
- 0
chroot said:alt-tab, type, copy, alt-tab, paste. I don't find it disruptive. I do, however, find spending three minutes trying to figure out which brace I forgot to close, or looking up (again) how to put slashes through symbols, rather disruptive.
- Warren
I don't seem to have that problem. Sorry if I struck a nerve.
Staff Emeritus
- 1,602
I use Scientific WorkPlace, which has a fairly hefty price-tag.
I couldn't agree more!
For me there is also another issue. When I write non-technical prose that contains no mathematics, I compose at the keyboard without putting pen to paper. As much as possible, I like to do the same when I write tecnhnical stuff that contains lots of mathematics.
Thisn is impossible when using straight LateX. When I see a complicated mathematical expression in LaTex, I can't, in my mind, visualize the expression both as a whole and as parts, which I need to be able to do in order to manipulate and massage parts as the expression in my head.
Scientific Workplace provides just the type of environment I need - nice visual representation of the mathematics, plotting facilities, and a built-in algebraic system (in my old version, an extensive subset of Maple) that accepts, without ever moving out of the document window, the visual mathematics as input (as opposed to ASCII).
I use this system both not only to wite the final product, but also as an electronic scratchpad to develop the mathematics on the fly.
I have attached a screenshot of work that I posted on the Special & General Relativity forum. This is not after compiling - this is how it appeared as I inputted it in. Of course, compilation is necessary to produce LaTeX output.
Regards,
George
chroot said:I do, however, find spending three minutes trying to figure out which brace I forgot to close, or looking up (again) how to put slashes through symbols, rather disruptive.
Regards,
George
ComputerGeek
- 383
- 0
Cripes... why not just use maple then?
- Rectifier
- · Replies 8 ·
- MATLAB, Maple, Mathematica, LaTeX
- Replies
- 8
- evinda
- · Replies 6 ·
- Replies
- 6
- Bachelier
- · Replies 5 ·
- Replies
- 5
- member 428835
- · Replies 3 ·
- Mechanical Engineering
- Replies
- 3
- adelin
- · Replies 8 ·
- Science and Math Textbooks
- Replies
- 8
- kaleidoscope
- · Replies 6 ·
- Computing and Technology
- Replies
- 6
- cwucopter
- · Replies 2 ·
- STEM Academic Advising
- Replies
- 2
- Leptos
- · Replies 7 ·
- General Discussion
- Replies
- 7
- maverick6664
- · Replies 5 ·
- Quantum Physics
- Replies
- 5
- fusebox13
- · Replies 3 ·
- Replies
- 3
