Which variables determine the exact output of this condensing device?
The discussion revolves around the efficiency and design variables of an Atmospheric Water Harvester (AWH) device. Participants explore the mechanisms of condensing water from humid air using temperature differences created by heating and cooling air streams. The conversation includes theoretical considerations, practical challenges, and the implications of various design choices.
  • One participant suggests that running hot humid air over cool air is an efficient mechanism for water harvesting, questioning the main variables affecting output.
  • Another participant argues that heating humid air does not increase water mass and emphasizes the need to cool the air below its original temperature to achieve condensation.
  • A clarification is made regarding the system design, stating that hot air is generated through a solar collector and cool air is produced by a fan, with both air streams intended to create condensate.
  • Concerns are raised about the effectiveness of heating air without a source of moisture, with some participants questioning the logic behind this approach.
  • One participant expresses confusion about the factors dictating condensate output, suggesting that mass flow rates of air streams are critical and seeks a proportionality equation relating these variables to output.
  • Several participants challenge the assumption that heating air will aid in condensation, emphasizing the importance of cooling the humid air to below the dew point temperature.
  • Disagreements arise regarding the potential for condensation from the described system, with some participants asserting that the design may be fundamentally flawed without a reliable source of cold air.
  • Participants discuss the implications of using a fan to create cooler air, with some arguing that it does not effectively lower the air temperature sufficiently for condensation to occur.
  • One participant suggests exploring pressure reduction as a method to condense water, indicating alternative approaches to the problem.
Participants express multiple competing views regarding the effectiveness of the proposed AWH design. There is no consensus on the best approach to achieve condensation, with ongoing debate about the roles of heating and cooling air streams.
Participants highlight limitations in the current design, including the need for a reliable source of cold air and the potential misunderstanding of how temperature differences affect condensation. The discussion reflects various assumptions about the mechanisms involved in atmospheric water harvesting.
  • #31
anikad said:
Thanks for sharing that!
If I understand correctly, these devices will not produce condensate at night , since there's no solar power to heat the turntable dessicant (and thus no temperature difference) ?
So oversize by a factor of 4. Unless you are in the Sahara desert or Australian Outback, the plants aren't likely to die of dehydration in one day!
(Have you figured out how you will prevent over-watering?)
  • #32
anikad said:
Summary:: I'm looking to discuss the main variables that define the output/yield of a Atmospheric water generator device.
Good day all:smile:!
I've been researching on 'Atmospheric water harvester' (AWH) devices.
As I researched many functioning mechanisms on such devices, the most workable mechanism to me seems to be the one illustrated in the picture attached to this thread. (i.e running hot humid air over cool air using renewable energy source & collect the condensing water output.)
So my questions are twofold:
1) Am I right in thinking that this mechanism could be the most efficient to harvest water with no outside interference?
2) And what are the main variables that would affect the condensing water output we can get ..
In my mind, I suppose: the more mass volume of both hot & cold air we can get in contact per unit time, the better the condensing output?
Thanks a lot in advance for your input!
P.S: I'm new to the forum, but I intend to stick around & be an active participant here!
Heating up a load of nitrogen/oxygen for no good reason is always going to be inefficient.
Likewise cooling them.
Whatever you think the process is doing and how it is doing it, you need to figure out an optimum solution to regenerate the thermal state of the gases you heat/cool, so you don't have to do that over again with the next 'charge' of gas.
You will only get condensate when the working volume you are manipulating drops below its dew point, so worth reviewing that too, maybe there is some means to do what you want but in a depressurised system? You'll have to figure out how to gate a sample charge of gas, lower the pressure, extract condensate, then recover the latent energy used to form the depressurisation.
  • #33
I agree (forcefully) that the originally system is not going to work at all, despite the OP entreaty to find an accomplice to defy the laws of known physics.
However this statement is overly broad. There are methods (usually involving changing effective dimensionality) to modify the kinetics for physical changes. For instance a catalytic converter can produce desired reactions on its 2D surfaces. Oxygen concentrators use surface reactions to pull nitrogen from the air in a cycle . The device I referenced in #27 above is similarly cyclic and probably relies on 2D surface kinetics.(?)
So there may be many ways to approach this problem, some may be simple, but none of them are easy.
  • #34
I would respectfully disagree with that, and not just because I'm the apparent "accomplice"😉
I don't see anything wrong with the theory, not qualified to comment on the engineering.
The system transfers water from the atmosphere to a bucket through two sequential fixed media : dessicant and internal air.
Warm air from the outside comes in, interacts with the dessicant and goes out, slightly drier. It has the dual purpose of cooling the dessicant and provides it with some moisture.
In an internal closed loop, very hot air picks up moisture from the dessicant and is moved to a cooler zone where it is cooled and deposits the moisture. It is then heated again, etc.
Note that while it's a continuous process, it might require quite a bit of apparently fruitless circulation before the internal air has picked up enough water to start condensing on the cooler surface.
  • #35
I was referring to the original design containing no dessicant.
Here I was in particular commenting on @cmb suggestion that a pressure change would be requiired. There may be other methods as well involving surface reactions using temperature directly.
  • #36
This one ? (larger image from the article)
I added in the purpl'ish arrows in the second-from-top level (missing from the original diagram) to illustrate ambient air movement. The round thing is what I thought was a flow-across turntable, but is apparently (or possibly) a flow-thru (turning) disk.
For the OP's possible edification, the tray with the heat-exchanger on it, the airflows are not actually mixing : inside the hexagonal structure, pipes that carry the airflows carry out the heat exchanging.
  • #37
Not something I said. I said "maybe there is some means to do what you want but in a depressurised system?".
Maybe there is some reason I seem to be routinely misread?
But anyway ... it was just a suggestion ...
  • #38
?This is not a pressure change ?
  • #39
Yes, but not 'required'. I proposed it as one possible means to help achieve necessary dew point.
  • #40
Apologies. I did not intend to offend or mischaracterize.
  • #41
No prob. I thought I was adding an alternative train of thought for the OP, didn't want to make an argument of it.
  • #42
Thank you .
That's exactly what I've picked up from the original design. I'm working on a design based upon "batch processing" to prevent the highly inefficient water pickup of internal air.
  • #43
Thank you for your input!:smile:
This is still confusing to me.
The condensate forms when there is a temperature difference ( for eg: ambient temperature on outside, & high temperature on inner closed area) .
What does the dew point has anything to do with condensate?
Can you please elaborate what I'm missing?
  • #44
The Wikipedia article on "dew point" explains it quite clearly in the very first paragraph, IMHO.
  • #45
I just did a little reading on dew point.
My intuition was: if we trap heat in a closed system, and continue saturating it with moisture- then we let the highly saturated air (that can't hold any more water vapors) come in contact with the wall of the system that is slightly cooler because it's in contact with outside ambient air- the condensate will start to form.
It seems my intuition was correct even without knowing/taking into account the dew point?.
  • #46
Hey hutchphd, this is not an attempt to defy the laws of physics.
Perhaps, you didn't understood the mechanism of the device correctly?
If you can prove which law is being defied in the device, I'd take account.:smile:
  • #47
Well, you just can't say this is how it works and I can get water from air.
There is ( probably ) a limited temperature / humidity levels of the outside air, and heating from the sun, where the system will complete it's function as planned.
The air at the cool surface has to be at 100% humidity for condensate to form.
For example,
If the outside air is at 20 C 30% RH your cooling surface will be at 20 degrees also, since you are not actively cooling that surface.
If you can get the cooler air up to 100% humidity then well you will have condensate.
Then ask yourself the question, how much heat needs to be added to the air at the top section so that the RH of the top hot air is less than 30% for the wheel to transfer moisture from the ambient air to the wheel to the hot air. What is that temperature? If the temperature does not reach that level then the wheel ends up working in reverse and transferring humidity from the hot air to the outside air.
Suppose the temperature rises just 1 degree about that needed just below < 30% humidity.
Then the system does do as planned, but the yield amy be a drop an hour <-- just a simple guess.
You will have to look at your psychometric chart to get answers.
You really have to do an engineering analysis, to determine at what temperatures and RH's where the system can do something useful.
Here's a start.
https://www.odellassoc.com/how-do-desiccant-dehumidifiers-work/
https://www.trane.com/content/dam/T...wsletters/airside-design/admapn016en_0905.pdf
  • #48
This version can work. Purple arrows.
  • #49
For example,
Thank you! Now you really appear to be my accomplice:biggrin:.
So the engineering analysis of this system comes down to this : The greater the temperature difference between hot air & cooler ambient air, the quicker the air picks up enough moisture to reach 100% humidity- to be brought to a cooler surface.Am I thinking correctly?
  • #50
Also the choice of dessicant will make a big difference I believe. I found this interesting: a clever guy trying to make a desiccant-based air conditioner:
It didn't work all that well !
  • #51
Let's say the hot air reached 40°C 70% RH levels (after absorbing lots of moisture from the wheel) . And we bring it in contact with ambient air at 20°C.
Is there a physics equation that can tell whether that hot stream of air when brought to contact with a 20°C ambient air- can reach 100% RH levels ?
Basically what I want to know- the 70% RH air will be increased to higher RH (since cooler surfaces have higher RH) , but what dictates how much it will increase & whether it will increase to 100% RH so we can get the maximum possible condensate?
Any answer to it will be appreciated:smile:
  • #52
I do not know a simple answer. You really need to know the various rates involved (for a continuous process). I think a far better design (as has been talked about) is to heat the dessicant directly with the solar flux to expel its trapped moisture.
  • #53
Maybe.
I haven't done any calculations myself so I won't be quick to say yeas on no.
My point is that at some temp/humidity levels the system will never work at all.
Either do calculations, or experiment. ( But I don't not think that you will get rivers of liquid water for a table top size system .)
  • #54
I agree with you on that design!:smile:
What my question was essentially: WHAT physics equation relates the following 4 variables.
Initial T ; Initial RH ; Final T ; Final RH
I believe there's ought to be an equation for this simple relation, since we already know that:
Final RH> initial RH & Final T < Initial T
  • #55
This screen capture didn't work very well, but here is the approach.
It is about 35% down in the right column at:
https://www.sciencedirect.com/topics/earth-and-planetary-sciences/dew-point
It is an excerpt from the book :
Theoretical Grounds for Humidity
Dario Camuffo, in Microclimate for Cultural Heritage (Third Edition), 2019
The DP can be easily computed from RH and air temperature, as in the next formulae. Indeed, considering that the DP is reached with an isobaric process, the vapour pressure at the original dry bulb temperature equals the saturation pressure at DP, i.e. e(T) = esat(DP). By substituting this finding in formula (3.38), with the help of the Magnus & Tetens formula, one obtains:
(3.48)u=etesatt=eDPesatt=esat0×10aDP/b+DPesat0×10atb+t=10aDP/b+DP−at/b+t
hence
(3.49)logu=aDPb+DP−atb+t
and
(3.50)DP=b+DPalogu+b+DPaatb+t≈b+talogu+t
where the last approximate finding has been obtained substituting t to DP in the right-hand side of the first identity. Of course, the first term is negative as u < 1 and log u < 0.
Another formula can be derived considering what happens above an evaporating surface. The air temperature lowers, while the increase of MR raises the DP. The air temperature t continues to decrease until the temperature of the evaporating surface, called wet bulb temperature, tw, is reached (see Section 3.9). When the evaporated vapour reaches saturation, t = tw. Starting from the Clapeyron equation and the definition of w and always considering the difference DPtw, after some steps and approximations, the following formula is obtained:
(3.51)DP≈bblogu+tlogu+atab−blogu−tlogu
where a and b are the Magnus & Tetens coefficients for vapour in equilibrium with the liquid phase. Eq. (3.50) is a better approximation. The formulae can be used once the RH is known, and obviously
(3.52)logu=logRH100=logRH−2
DPT and DP = T only when RH = 100%. The DP is determined once the air temperature T and the RH are both known, or also when only the MR (or SH) is known. In particular, maxima of MR correspond to minima of DP, and vice versa, so that the DP can be used for diagnostic purposes instead of the MR and may be useful to express the moisture content in °C.
The dew point spread (also called spread), i.e. the difference ΔDP = TDP basically depends on both the actual air temperature T and the MR. Following the approximation (Eq. 3.50 ), it can be expressed as a function of air temperature and RH
(3.53)ΔDP≈−b+talogu
It physically shows how much the air temperature is close to, or far from, the DP. The zones having smaller ΔDP are more prone to form condensation, to allow microbiological life and more intense weathering. Useful maps of this variable can be easily drawn for diagnostic purposes. However, although the RH is a very different but related variable, in general the areas with RH maximum are the same as those in which the ΔDP is minimum. If one is not interested to know how much the ambient is above the dew point, i.e. how much wall temperature (not air temperature!) should be raised to avoid condensation, maps of RH are sufficient to give a qualitative idea of most critical areas.
Dew has the typical form of droplets and especially forms on leaves during the nocturnal cooling due to the infrared (IR) emission. The formation of dew on leaves is favoured by the local excess of moisture due to stomatal transpiration. The surface tension of water tends to displace the larger droplets to the edges of the leaves and in particular to the points of leaves, especially the lance-shaped ones. The upward IR loss during clear nights is a very effective cooling mechanism. The surfaces on which dew forms are free from any upper shield and in practice are the same that are reached by rainfall. This is the reason why people often believe that dew falls similarly to drizzle. Dew is favoured over vegetated areas, but it occurs on monuments as well, when their surface temperature falls below the DP. When the temperature of a surface falls below the DP, in the viscous layer surrounding the surface RH >100% and condensation occurs.
Hope this helps!
Cheers,
Tom
  • · Replies 16 ·
  • · Replies 19 ·
10K
  • · Replies 152 ·
12K
