Why adding more polarized filters results in more light passing?
In summary, the conversation discusses how adding middle angle polarized filters can increase the amount of light passing through, and how this phenomenon was not fully understood before the discovery of quantum mechanics. The conversation also touches on the pop-sci presentations of quantum mechanics and how they often oversimplify the topic. The concept of filtering entangled photons is also mentioned as a way to address the question of why the original thinking was discarded.
flyguille
I was watching this video ...
And basically the video show how adding in middle angle polarized filters it makes more light to pass.
Then comments about quantics and blah blah blah.
Why cientifics thinks lot weird and how was discard the following line of a more natural thinking:
My thinking:
"Why?, why to scratch the head thinking weird anti-natural like this, "erroneous" thinking. Why they didn't simply think that passing light by a filter it can shift the polarization angle of the light itself, so, inserting a middle filter it shift a bit the light polarization angle, which result in more light be able to pass the final filter. But If you set a 90º filter to the light that comes perfectly perpendicular, the light just crashes and can't pass. But if inserting more filters in middle angles, it is like guiding a car which driver are sleep, if the car found a dead end street or 90º instant turn, it will crash, but if the car gets a curve little a little the edge of the road will make the car to turn totally and pass it safe, when more in middle steps more safe.Why not? How this thinking was discarded? or not taken in account at all?"
Science news on Phys.org
What you are describing is a kinda-sorta-OK math-free description of how quantum mechanics describes this phenomenon. The problem is that before the discovery of quantum mechanics we had no theory that explained how light and polarizing filters could behave that way - everything that we knew about electromagnetic radiation (which was a lot) said that adding a filter had to further reduce the amount of light passing through.
If a linear polariser passes the component of the E field that's aligned with the x-axis then following it with a polariser that's aligned with the y-axis will pass nothing.
However, if you follow the first polariser with a polariser aligned at 45°, it will pass a wave with 1/√2 E field strength. Following these two with a polariser on the y-axis will pass 1/√2 of what comes out of the second polariser so the overall effect is that 1/2 is passed.
This works every day with radio waves and it spoils the polarisation isolation between a HP transmitter and a VP receiver when a diagonal wire or grid intervenes.
That explanation of the phenomenon is a wave based one and it works. If it turns out to be a surprise that the photon based explanation is extra complicated then so be it but that video makes a very over simplified statement at the beginning when it claims that a polariser "selects photons" with a particular polarisation (and implies that it rejects all others). If it were as simple as that would let through a vanishingly small number of photons - which is clearly not true. It is never surprising when an over simplified approach to QM produces dodgy results.
Likes davenn
@flyguille, I would extend Sophiecentaur's comment to say that it is surprising (to me anyway) when pop-sci presentations actually get something RIGHT. I always assume they have it wrong in some way because over many years of watching a LOT of pro-sci TV shows and reading pop-sci books, that has been my experience. This applies to all areas of science but is particularly something to watch out for with Quantum Mechanics and also with Cosmology.
It was addressed. The part of the video about filtering entangled photons separated by a distance was to address that. Only one is filtered, yet the effects show up in the other. They are separated too far for any filter effect to travel at the speed of light.
why distance matters?, I agree photons is a mistery which they didn't decides what exactly it is so theorems are it is a particle and a wave at the same time. (that is what I understand)
So, we can imagine it like a flock of birds acting as one , but individually they are particles, but in conjuntion form waves. That is what I have in mind.
So, I wonder how with so many doubts in the middle, they discard more normal natural thinking,
And then prove it!.
You say it is more natural, but what mechanism do you propose that could transmit the filter effect faster than the speed of light to the other location? In trying to answer that, the "natural" explanation becomes a can of worms.
Any analogy that has been grabbed randomly out of the air is likely to lead you to very wrong conclusions. You need to be far more rigorous.
Likes FactChecker
faster than light? I never said something about "Faster than light", what I mean, the photons can be altered by each filter shifting its polarization, so the effect travels with the photon which was altered.
But, anyway, I will study more about what scientifics know "what photons really is", but I fear It is just a lot of theories, nothing proven, because how to see that? only can be observed the effects of the object in study, and measurement machines are done of atoms, and also the exact sub atomic model is in discussion, so, how to have realiable data out of two "in progress" models.
But I will study, and remove a bit of my own ignorance.
No. The video does. The distance and short time between the filtering of one light beam and the effects on the other light beam are what make it such a challenging test of what you are calling the "natural" explanation.
"Other"?, no, the same beam, I don't like that video, I thinks the video is wrong, so that is the reason why I am discussing it and wondered why too much trouble was made.
It doesn't matter how many simple experiments you can explain with a simple, "natural", theory. If someone can come up with another experiment, no matter how complicated, that your theory fails at, then your theory is no good. So you should stop thinking about your example and pay close attention to what the video is saying.
Instead of saying vaguely that the video is too complicated and wrong, you should watch it carefully and say exactly which step is wrong. The fact that very expert people believe it should give you pause.
I don't like watching videos because of the fixed pace but... it seems to me that the video does not consider contextuality, i.e "filters" affecting the behaviour of light... hence some of the "weirdness".
Worst than "fixed". Either the narrator had a very strange delivery or the video sound had been sped up in a very un subtle way. He was so "I'm very smart" that I felt a real antipathy to his message. Were the producers paying for the movie in ££ per second?
1. Why does adding more polarized filters result in more light passing?
Adding more polarized filters results in more light passing because each filter is designed to only allow light waves that are aligned with its particular polarization to pass through. As more filters are added, more of the light waves are able to pass through, resulting in an increase in the amount of light that is able to pass through.
2. How do polarized filters work?
Polarized filters work by blocking out certain directions of light waves, while allowing others to pass through. They do this by using special materials that are able to absorb or reflect light waves that are not aligned with the filter's polarization. This allows only the desired polarized light to pass through, resulting in a clearer and more contrasted image.
3. Can adding too many polarized filters cause a loss of light?
Yes, adding too many polarized filters can cause a loss of light. This is because each filter absorbs or reflects a certain amount of light, so as more filters are added, the total amount of light passing through decreases. It is important to find a balance between the number of filters and the amount of light needed for optimal results.
4. Are all polarized filters the same?
No, not all polarized filters are the same. Different filters may have different levels of polarization or may be designed for specific types of light waves. It is important to use the correct type of filter for the desired effect, as using the wrong filter may result in a loss of light or a distorted image.
5. Can polarized filters be used in any lighting conditions?
Polarized filters work best in specific lighting conditions, such as bright sunlight or glare, where there is a high concentration of polarized light waves. They may not be as effective in low light conditions or artificial lighting. It is important to test and adjust the use of polarized filters in different lighting conditions to achieve the desired results.
  • Optics
13K
13K
