Why am I hearing audible noise from my SMPS?
  • Thread starter Thread starter victorb
    Noise Smps
The discussion revolves around the audible noise generated by a buck converter in a switch-mode power supply (SMPS) circuit. Participants explore potential causes of the humming noise, particularly in relation to the converter's operation under varying duty cycles and loading conditions. The conversation includes technical aspects of the circuit design, component behavior, and noise generation mechanisms.
  • One participant describes their buck converter setup and notes audible humming noise occurring at duty cycles between 30% and 90%, while it is absent at 0% and 100% duty cycles.
  • Another participant questions the necessity of eliminating the humming, suggesting it may be related to the 250Hz PWM control frequency.
  • A participant expresses concern that the noise undermines the reliability of the circuit and mentions that similar circuits do not exhibit this humming.
  • One contributor attributes the noise to magnetostriction in the power magnetic element and suggests testing with an unshielded inductor or a toroidal inductor.
  • Another participant clarifies that the buck converter's switching frequency is 150kHz, while the load is controlled by a separate PWM signal at 250Hz.
  • A participant reports that adding a larger output capacitor significantly reduced the humming, indicating that the original capacitance may have been insufficient for the load's rapid changes.
  • One participant challenges the idea that magnetostriction is the source of noise, suggesting that air gaps, loose windings, or vibrating shields may be more likely culprits, and mentions that capacitors can also produce noise under certain conditions.
  • Concerns are raised about the duty cycle limitations in a buck converter circuit, emphasizing that duty cycles should not reach 100% or 90% to ensure proper operation.
Participants express differing views on the source of the audible noise, with some attributing it to magnetostriction and others suggesting alternative causes such as air gaps or capacitor behavior. The discussion remains unresolved regarding the definitive cause of the humming and the best approach to mitigate it.
Participants note that the circuit's behavior may depend on specific component characteristics and configurations, and there are unresolved questions about the adequacy of capacitance and the implications of switching frequency on noise generation.
victorb
Hello, I'm a newbie for this forum, and I don't have much practical experience on SMPS too. I found this forum when I'm searching for my solution from internet.
My Circuit:
I'm using a simple buck converter:
Vin: 24V
Vout:3.3V
Iout: 1.5A (dynamic load)
The loading is running in PWM control, that means sometime it will draw around 1.5A and sometime it will draw around 0.05A, the PWM's frequency is about 250Hz.
The converter is fine when I'm running it at fully ON (100% duty-cycle) and fully OFF (0% duty-cycle).
But when I'm running it from 30% to 90% (duty-cycle), I can hear some audible noise (humming) clearly from the circuit.
As I didn't hear the noise at fully OFF mode, so I think DCM is not the reason.
I tried to remove the buck converter's inductor, and plug in a 3.3V at the converter output directly, then the noise disappeared, so I think the noise is from the converter circuit.
I tried to replace the inductor with another brand and bigger size (higher current rating) inductor, the noise seems reduced slightly (the original inductor's current rating is about double of the converter's output current already), and both of them are shielded inductor with EPOXY potted already, so more EPOXY may not be helped.
Anyone can share some experience knowledge with me on how to solve this issue?
And any reply will be appreciated
Just courious. Why do you need to get rid of the humm? Isn't it the 250Hz of the inverter you're hearing?
BTW Welcome to PF.
um... because it makes me feel unreliable on the circuit
And I saw other similar circuit won't have this kind of humming
and more information: I'm using 150kHz switching freq. and tried to change it to 250kHz, but the humming is still here.
Well, in your first post you said Hz not kHz. That's why I was asking; since you can hear 150Hz.
The audible noise is most likely due to magnetostriction in the power magnetic element:
http://en.wikipedia.org/wiki/Magnetostriction
You are not hearing the 150kHz directly, you are hearing effects of the PWM tracking for controlling the output voltage. You say you are using a shielded inductor with potting, so that's probably where the noise is coming from -- the interface between the two parts (inductor and shield).
Try using an unshielded inductor to see if the noise goes away. If you need a shielded inductor for that part for other reasons, try using a toroidal inductor instead (it is self-shielding for generating external B-fields, not for being immune to external interfering B-fields).
dlgoff,
Thank you for your advice. I'm sorry that I didn't stay it clearly. What I mean is:
1. The buck converter's switching frequency is 150kHz.
2. The output's loading is driving by another switch and the switch is controlled by another PWM signal which is about 250Hz. That means the converter's circuit will be 1.5A, and then switch to 0.05A in 4ms, and then keep switching...
berkeman,
Thank you for your opinion, I think I need sometime to study the "Magnetostriction". After I read wiki, I only can get that it can convert magnetic energy into kinetic energy.
I tried to replace the inductor with WE-PD4-330,33uH, it still humming, and I can hear some higher frequency noise (weeeeeeeeeeeeee) at very low loading condition. I will check did I make anything wrong...
(PS: The humming sounds like cry of cicadas)
Today, I tried to add another output capacitor on my buck converter, so the output capacitance changed from 200uF to 2400uF, and the humming seems gone.
Maybe 200uF is not enough to handle the fast switching from 1.5A to 0.05A...
Of course, I can't use 2200uF capacitor on it, but I think it's 1 of the right ways for me to go, my next step is to find out the proper capacitance.
Thank you for all the advices.
Magnetostriction is (almost) never the source of noise in an inductor or transformer. Airgaps - also in the form of poorly assembled cores - are a common source, loose windings is another. And yes, I heard once a shielding vibrate.
Capacitors sometimes make sounds. Quite unexpected. I heard it from a type-III ceramic one. But logical after all: it used BaTiO3 as a huge-K dielectric because it is ferromagnetic, and under polarisation it acts as a piezoelectric material and is commonly used in transducers. Type-I ceramic don't do that, plastic capacitors neither.
The get a hum from a 150kHz switching frequency, you must have something flawed in your circuit: typically an oscillating regulation - consistent with the bigger capacitor stabilizing it. And by the way, 150kHz is already huge, I wouldn't go to 250kHz.
The duty cycle can't be 100% nor 90% in an inductor buck circuit with 24V and 3.3V; and even with a transformer, designers stop at <90% duty cycle so that the transistor always switches.
  • · Replies 21 ·
