Why are moving objects blurred in a camera?
  • Thread starter Thread starter CyberShot
    Camera
Camera photos appear blurred when capturing fast-moving objects due to the finite exposure time of the camera's sensor, such as a CCD chip, which integrates light over a specific duration. If an object moves during this exposure, it causes light to hit different parts of the sensor, resulting in a blurred image. This effect is particularly significant in astronomy, where telescopes must track celestial objects to avoid blurring during long exposures. Indoor photography often suffers from blurriness because lower light levels require longer exposure times, allowing more movement. Faster shutter speeds are essential in sports photography to minimize motion blur, necessitating larger lenses to gather sufficient light quickly.
CyberShot
Forgive me if I'm missing something truly basic about photography, but I always wondered why camera photos appear blurred if the object's moving fast.
Isn't the speed of light large enough where, even if the object is moving rapidly, the time it takes to reach the object is negligible compared to the object's velocity?
Thanks
Sure, but cameras don't take pictures instantly. A CCD chip, for example, integrates an exposure over a finite time interval. A typical shutter speed is something like 1/60th of a second I believe.
So if at the beginning of the exposure, the subject is on the right hand side of the field of view and is moving to the left, the light the subject emits will initially be dumping photons on the right hand side of the CCD chip. However, as the subject moves, photons will begin dumping themselves towards the left hand side. This creates a blurry image.
This concept is VERY apparent in astronomy and is why telescopes must do what is called 'tracking' in order to have imagines that are worth something. The dimmer the object you want to see, the longer the exposure. So if you want to see an object that is so dim that it requires a 10 minute exposure time (very common!), you have to have the telescope track objects in the sky so that it rotates with the rotation of the Earth. If you just let the telescope sit there, over the 10 minutes the star in question will move along the field of view and instead of depositing photons in a small, concentrated area of the chip (giving a crisp, clean image), it'll trail off as the Earth rotates, dumping photons in a wider area making it very blurry.
The amount of blurring depends on the time of exposure versus how far an object's image moves across the surface of the film (or ccd's if it's a digital camera). Depending on shutter movement, you can also get "curved" images if different parts of the image are taken at different times. The shorter the duration in exposure time and/or the slower the object image is moving, the less blurry the image.
Probably shorter ("faster" in photographer-speak) than that. I don't know the typical shutter speed for simple point-and-shoot cameras, but with my digital SLR I use 1/250th of a second or shorter in daylight. I use 1/60th or longer only in outdoor twilight, or indoors without flash.
Excellent answer by Pengwuino.
That's why indoor photos tend to be more blurry with a cheap automatic camera. There is less light indoors, so the camera leaves the shutter open longer to get enough light to form an image, but this gives a longer window in time for the subject to move, causing blurring.
And that's why in sports photography they have camera that resenble tank barrels due to their large lens sizes...so they can gather enough light in a short enough time that the subject won't move enough to cause any blurring.
Topic about reference frames, center of rotation, postion of origin etc Comoving ref. frame is frame that is attached to moving object, does that mean, in that frame translation and rotation of object is zero, because origin and axes(x,y,z) are fixed to object? Is it same if you place origin of frame at object center of mass or at object tail? What type of comoving frame exist? What is lab frame? If we talk about center of rotation do we always need to specified from what frame we observe?
  • · Replies 22 ·
  • · Replies 16 ·
  • · Replies 86 ·
