Why are there two different truth tables for BCD to Gray?
  • Thread starter Thread starter Differentiate1
    Code Converter
5 replies · 20K views
Differentiate1
Having a bit of trouble understanding why there are two different truth tables for BCD to Gray.
Using ABCD as the BCD and WXYZ as the Gray,
The way I learned it is:
1) MSB of BCD (A) = MSB of Gray (W)
2) A ⊕ B = X
3) B ⊕ C = Y
4) C ⊕ D = Z
5) Since BCD only ranges from 0 - 9, 10 - 15 become "don't cares"
Following the rules, chart prints:
http://i.imgur.com/IPsPoAS.png
However, while browsing through examples of converting BCD to Gray, I found these:
Example Problem
Example Problem 2
The rules I posted don't work in the Example Problems.
Are there some sort of exceptions that may alter the Gray Code?
There are at least 3 different BCD-codes:
Maybe that's the cause to confusion?
But why not choose the one you like, practise some Karnough mapping and make your own truth table ?
Observe: BCD4221(5) is wrong: It must be 1001 or 0111
Thanks for the reply,
The problem I'm facing requires me to,
"implement a BCD to Gray Code converter using a 4x16x4 PAL where each output collects 4 different product terms."
I completed the problem using the 8421 BCD code to Gray, but the solutions solved it the way shown here: Example Problem
Would using the 8421 BCD to Gray functions where
W = A
X = A'B
Y = A'BC' + B'C
Z = A'BC'D + B'C'D + AD + BCD + B'CD'
be considered correct in this problem still? I'm skeptical regarding my answer since the question requested "output collects 4 different product terms." I'm assuming that part just means the OR gates in the PAL needs to collect 4 connections from the AND gates.
The rules here:
2) A ⊕ B = X
3) B ⊕ C = Y
4) C ⊕ D = Z
matches the BCD and gray-codes here:
In your examples in #1, there are other gray-codes, and of course your rules will not match these.
For example, how have you found: Z = A'BC'D + B'C'D + AD + BCD + B'CD' in #3 ? That's not right.
Yeah that's not right.
Re-did the K-Map and found Z = A'C'D + B'C'D + A'CD'
But how would you solve the problem in the example using their BCD-Gray Code instead of the 8421 choice?
Certainly the rules will not work in that.
I cannot find out what you are doing. Which BCD-code and which gray-code ar you using?
As for the BCD- and gray-codes shown in #4, the result is:
Z = C ⊕ D = ( C * !D ) + ( !C * D )
( ! means "not" )
