Why Are Waves So Long in Frequency and Wavelength?
  • Thread starter Thread starter Newtons Apple
    Waves
The discussion centers on the relationship between frequency, wavelength, and the speed of electromagnetic waves, specifically in the context of Ham Radio and Extremely Low Frequency (ELF) communications. It is established that all electromagnetic waves, including ELF waves, travel at the speed of light, 299,792,458 meters per second, regardless of their frequency. The conversation highlights that lower frequencies can penetrate materials like seawater better than higher frequencies, which are absorbed more due to their shorter wavelengths. The unit of frequency, hertz (Hz), is defined as cycles per second, and the wavelength can be calculated using the formula λ = speed of propagation / frequency.
  • Understanding of electromagnetic wave properties
  • Basic knowledge of frequency and wavelength calculations
  • Familiarity with radio communication principles
  • Knowledge of the speed of light (299,792,458 m/s)
  • Research the principles of Extremely Low Frequency (ELF) RF communications
  • Learn about the modulation techniques for low-frequency signals
  • Explore the effects of different materials on electromagnetic wave propagation
  • Study the relationship between frequency, wavelength, and wave speed in various media
Ham Radio enthusiasts, telecommunications engineers, and anyone interested in the physics of radio wave propagation and communication technologies.
Newtons Apple
Hi everyone... So, I may be putting too much thought into this. But I'm studying for my Ham Radio license, and I was pondering the size of our allotted range of frequencies. The lowest frequency is in the 160 meter range (clocking in at 1.8 Mhz) So, of course I was thinking what other things use those lower ranges and what they equate to in meters. I noticed that 1 Hertz. (One cycle per second) is equal to 299792458 meters! How is this possible? And Why? If a hertz is a cycle per second, does that really mean it's traveling 299792458 meters per second?
Also for something like low, can you possibly even modulate it to send data? To me, it feels like that wavelength is so long, that it'd be hard to actually "apply" data.
Yes, light travels at 299792458 meters per second.
Extremely Low Frequency RF communications is used with submarines because the low frequency RF can penetrate seawater much better than shorter wavelengths:
https://en.wikipedia.org/wiki/Extremely_low_frequency
Wikipedia said:
ELF frequencies have been used in only a very few human-made communication systems. ELF waves can penetrate seawater, which makes them useful incommunication with submarines.
Realize that all electromagnetic waves travel at that speed (through vacuum), regardless of frequency.
Thanks for the responses everyone...So I suppose without getting *Too* technical... why is it that lower frequencies can go through certain materials, but high frequency waves can't? What is it about the properties that make one wave good for one type of propagation? Just like how higher frequency waves are good at getting through the Ionosphere, but longer waves are pushed back down?
Newtons Apple said:
without getting *Too* technical...why is it that lower frequencies can go through certain materials, but high frequency waves can't?
The 'Simple' answer is that the losses occur per cycle of the wave. Shorter wavelengths have more cycles per given distance, hence are absorbed more by, say, seawater. (Ref Post #3 by berkeman)
Likes analogdesign and the_emi_guy
I see! Thanks everyone, I never sort of combined the two pieces of knowledge that EM waves travel at the speed of light. And one hertz is the wave "Traveling" So it can travel (complete 1 cycle) once per 299792458 meters. Hence 2 cycles, means that it travels twice as fast...dividing that number in two... Okay I get it, thanks guys!
The frequency, f, of the wave is independent of the propagation medium.
The unit of frequency is hertz, Hz, which has the units of sec-1.
From frequency you can calculate the wave period, T, in seconds, T = 1 / f.
The wavelength, λ, is then the period * speed of propagation.
Only in free space is λ = 299792458 / f.
no that is incorrect, the velocity of the wave didn't change
  • · Replies 68 ·
  • · Replies 31 ·
  • · Replies 17 ·
