Why artificial gravity is not possible?
156 replies · 40K views
Brett13 said:
Mentioning 2001 reminded me of something, along with the avatar, could we put the astronauts in a hypersleep or something? They wouldn't be using their muscles so could it somehow negate the effect of the no gravity?
There is plenty of research into induced hibernation, such as the use of Hydrogen Sulfide, but we're nowhere near "hypersleep".
Astronomy news on Phys.org
markjohn82 said:
How long does the human body need in a gravitaional environment, could the bodies needs be met during sleep time?
When you're sleeping your heart isn't pumping uphill and none of your other muscles are working, so no.
I've heard it proposed that an Elecromagnetic Field bends spacetime but can be blocked in various ways.
If you can generate a field of sufficient strengh to have a significant gravitational (bending of spacetime) component but block the field itself perhaps?
But why bother? If you're going to expend this much effort to create gravity, there's a really easy resource that provides it: mass. Make your space station really massive - enough to make gravity a factor.
The energy required to power up your EMF to the point where it bends spacetime is going to be on the order of the energy involved in moving an asteroid-sized space station around anyway, so why make a Rube Goldberg device to get the same result?
As has been hinted at earlier in the thread, generating the field is * easier.
The energy moving an asteroid-sized space station around to generate a gravitational field of 9.8 m/s is going to be several orders of magnitude less than accellerating and decellerating a mass equivilent to planet Earth wherever you want to go.
* Nothing is "easy" about this scenario of course :)
Where?
Sorry -point of order- we're mixing up ideas. My suggestion was that an asteroid-sized space station would be big enough to create sufficient real gravity (but less than Earth's gravity). If the intent is to create gravity equivalent to 9.8ms^2, then that's different.
So let's set some benchmarks. I'll go with yours. We want to make our space station have gravity of 1 Earth g.
1] Tell me why you are convinced that it would take "several orders of magnitude less energy" to produce 1g by way of an EMF than it would to simply move around an Earth-sized body. I am not convinced it would.
2] You wouldn't actually need an Earth mass body. We feel 1g because we are ~4000mles from the gravitational point source. A smaller, denser and much less massive body would accomplish the same thing. It should be calculable how small a mass you'd need.
DaveC426913 said:
Where?
Post 16, but then he went on to talk about micro-blackholes, so perhaps not!
A space station is easier since you don't have to move it nor power your artificial gravity - whether you need to rotate it or not. I was thinking of a starship.
I'll say from the outset that I am in no way qualified in the field we are talking about to provide calculations on this, and would happily accept them from anybody who cares to have a go in the thread.
My view is based on this:
http://www.sciencedaily.com/releases/2006/03/060325232140.htm - beware popular science magazine
http://esamultimedia.esa.int/docs/gsp/Experimental_Detection.pdf - experimental paper
Which produced a gravitomagnetic field 100 millionths that of Earth.
Obviously, the field scales up geometrically based on speed of rotation, strength of magnetic field, size of super-conductor, charge of super-conductor etc...
However, back-of-the envelope below and assuming it scales up linearly to give a fair minimum:
Let's say (perhaps erroneously) that this small lab uses a tenth of the LHC's annual 800,000 Megawatt hours running this specific experiment constantly - so 80'000 Mwh or 2.88x10^14 joules. Multiply by 10^9 is 2.88x10^23 J annually for an Earth-strength field.
CharlesP (https://www.physicsforums.com/archive/index.php/t-63459.html) seems to suggest that moving the Earth to any appriciable degree would take approximately 4.18 x 10 ^15 joules every 10 seconds for a billion years in one megaton bombs. A total of 1.3x10^31 J to move the Earth. To say nothing of deceleration or damage to the body.
You'd still need to move it, would the extra-terristial mining, manufacture and moving of this body take less than 2.88x10^23 J annually? - in the null case my point still stands
Why would a ship not have a rotational habitat area around a central axis?
Have you been following the thread? We're looking for alternate forms of artificial gravity. A centrifuge is only one method and it has its drawbacks.
Dickfore has already covered this in post #7, but here's another way of putting it. A planet of half the Earth's radius but the same density would have half the surface gravity (it turns out), so to maintain the same gravity you'd have to double the density. There's a maximum density that would be possible with ordinary matter, so that puts a (pretty large) limit on the minimum sized planet with 1 g surface gravity. This makes this method practically infeasible, at least until we find a way of creating a tame mini black hole.
We covered all the possibilities from miniature black holes to magnetic fields that would fricassee your nervous system. I would say the same conclusion is the substitution of the pseud-force for another. Did you read Spike's post? He specifically compared a rotation STATION with a ship, and I was pointing out that a ship need not lack a centrifugal component... do you have an alternative suggestion?
DrGreg said:
... that puts a (pretty large) limit on the minimum sized planet with 1 g surface gravity. This makes this method practically infeasible...
Agreed. My point was simply that some EM force-field powerful enough to create a gravity well would likely use an equivalent amount of energy as it would take to throw a planet around. IMO.
The best thing to do, in the long run, will be to alter our biology to where lack of gravity won't weaken us. That, or become machines without the weaknesses of meat.
Nearer term, just use two centrifuges spinning in opposite directions, or a smaller, high speed flywheel spinning counter to the rotation of the centrifuge. That'll take care of the pesky gyroscopic effects of the centrifuge(s).
You just have to live with the Coriolis effect, but if you make your wheel with a big enough diameter, at least it won't make the occupants sick when they move their heads around.
Gravity serves other purposes than keeping our bones strong. It keeps our feet on the floor and the butcher knife on the countertop. Either of those floating around a room can be bad. Both of those floating around a room can be double plus bad.
Gravitational fields are carried by integer spin particles, EM fields are the product of a half spin particle.
Even and odd numbers, not integer and half.
https://www.physicsforums.com/showpost.php?p=2781702&postcount=12
Yep, I agree. :wink:
DaveC: Not just objects which can be dangerous in 1g; liquids can become very hazardous or at least a terrible mess, and of course there is the issue of bacterial growth in microgravity.
nismaratwork said:
...of course there is the issue of bacterial growth in microgravity.
What effect does microgravity have on bacterial growth?
[EDIT] I can see it impeding bacterial growth, but I got the impression you were suggesting growth would become problematic for occupants. I could be misinterpreting.
[EDIT EDIT] Oh yeah. Impaired bacterial growth in our bodies could negatively impact our health.
Re: Edit Edit: Exactly!
Magnets, gecko-like adhesive, velcro, clips, straps, bungee cords . . . can all secure things you don't want floating around when you're not using them.
Zero gravity is so much more useful. You get http://www.kschroeder.com/my-books/sun-of-suns/engineering-virga" that way.
You can manufacture novel materials in zero gee because liquids of different densities don't separate. You can grow large, perfect crystals without the constraint of gravity. Though with molecular manufacturing, these would probably be obsolete reasons for manufacturing materials in zero gee.
The question then becomes: if the default state for where you want most things to be is not floating around, then why create a method for each individual thing? You set your environment for the default, not the exception.
No you don't; you get exactly the same amount of living space. We have invented these things called floors.
Yeah, yeah. Perfect crystals. That old hackneyed thing is dragged out every time someone talks about uses for zero g. If zero g were so incredibly useful, someone in the last half century would have come up with more than one or two examples.
Fine, make your engineering things in zero-g. Does that mean the whole station should be in zero-g?
The same argument could be made for vacuum. Lots of things need to vacuum for their manufacture.
We should fill our space station with vacuum so that the materials are taken care of, and any silly old thing that actually needs oxygen can carry an air cannister on its back...
Feelin' kinda b*tchy today... :rolleyes:
Using adhesive patches is that much of a hassle? I'd gladly trade having to stick things "down" on any surface I choose for being able to fly freer than a bird.
In any case, it's not an all or nothing proposition. If gravity is more convenient, then use a centrifuge for those locations. Bathrooms, kitchens, and workshops could have gravity, the rest could go without. Those places needn't even have the gravity of Earth, just enough so things don't go floating around -- say 1/10th, or less, of a gee.
I respectfully disagree. When you can use each wall and ceiling as you can the floor, you clearly have five times the usable surface area.
Without gravity, there's no need for space-wasting stairwells and elevator shafts. Hardly any structural support would be needed; skyscraper-sized buildings could have frameworks as substantial as a camping tent.
The taller a skyscraper, the more of its structure goes to holding itself up than providing usable space. That's why we don't make skyscrapers with brick anymore. Steel will eventually reach its limits, then we'll have diamond, then what? Theoretically you could hold a building up like http://en.wikipedia.org/wiki/Space_fountain" to any height, but it would be a dang-expensive building to keep upright.
Perhaps we simply haven't thought of the uses yet. Imagine the first person to discover how to make glass. They clearly didn't think of lenses, window panes, fiber optic cables, fiberglass composites, fiberglass insulation, or even glass containers. All they saw was fused sand under what was their campfire.
It IS possible, you have to rotate the ship about its horizontal axis to create a force that holds the astronauts to the circular hull/floor of the ship
Did you just not read the last four pages? Did you even read the last four POSTS?!
All excellent points. I had not thought of the structural angle. Conceded.
Then you don't get points for it. :biggrin:
1] You can't submerge hoomans in an environment on spec, in the hopes that we'll think of reasons for it.
2] You do that kind of thing in your labs, not in your living spaces.
Imagine if we had the same l9ine of thought for vacuum. (Bah, humans can just wear helmets all day. Think of the discoveries we might make! )
It might be worth while to mention here that there are other methods of inducing a gravitational like state the does not require rotation or extreme mass. One possible alternative would be an industrial alternative (ex: incorporating metal into clothing in such a way as to have a similar effect to gravity on earth. ) Another possibility is the idea that gravity is at it's heart a magnetic attraction. if you could generate enough of the right polarity you might be able to produce an gravitational field. another option, though probably less feasible than the first or second, would have to do with how you would power an inter stellar or long travel ship. The ships would have to be huge in order to house a large enough garden to produce sufficient oxygen. best way to power such a large structure in space would be a fusion reaction. Space would greatly help with the heat issues that stop fusion from being feasible on a planet and a sufficient reaction could be fairly heavy in mass, almost like a mini sun. just some thoughts to keep in mind. there is no point in saying something isn't possible, after all discovery means proving someone else wrong. Einstein was a great man but at some point someone will prove him wrong somehow.
How does incorporating metal into one's clothing induce a gravity-like effect?
tbwhel said:
Anothero possibility is the idea that gravity is at it's heart a magnetic attraction.
No it isn't.
How does this follow?
Hrm, so you're saying a spaceship that has a big enough mass will have its own gravity. Well, kind of more like and asteroid than a spaceship then. The more massive it is, the less it can maneuver like a spaceship (and the harder it is to get it up to speed). There's a diminishing returns thing there.
People keep mentioning putting a "mini black hole" at the center of the ship in this thread, but I don't think the conventional definition of a black hole allows for the possibility of a "small" one (isn't the critical mass required to create a black hole much larger than the Earth or even our Sun?).
On another note, I did hear about the "metal in clothes" idea and thought it was a good one (previous poster didn't explain it very well). Basically if you have a floor full of electromagnets, and a person has metal in a sort of a jump suit. You could simulate 1G by utilizing a properly-powered magnetic field and strategically distributed metal and/or magnets in the astronaut's suit.
Well, a natural one yeah. But don't think that would apply to BH technology.
Ah. That was the missing piece.
Metal weights might be useful in low gravity...it's unclear how this would work in freefall.
Gravity's clearly not electromagnetic. The second sentence boils down to "if you could generate a gravitational field you could generate a gravitational field". The only apparent ways to do so involve enormous amounts of mass and/or energy, and would be quite a bit more inconvenient than rotation.
Space would not directly help with the heat issues...while vacuum would provide good insulation for cryogenic systems for superconducting magnets, it also provides good insulation for the radiator you're trying to dispose of waste heat through. You might manage a reaction chamber open to space without chamber walls needed to exclude atmosphere, but this would "solve" the problem by throwing away the energy produced by the reactor. And I would hope that such a spacecraft could use less than a planetary mass of fusion fuel. Note that even an Earth mass of fuel under any believable pressure would have a radius much greater than Earth itself, and thus a lower surface gravity than Earth. Heating the whole thing up until it starts fusing as you suggest only makes it worse.
Again, carting around a planet with you isn't a good solution. Artificial mini-suns aren't any better. You'd be better off using a fusion drive to accelerate constantly, which only requires impractical amounts of fuel and improbably high reaction rates.
That's not what discovery means, not everything thought to be true will be proven wrong, and not everything conceivable is possible.
At present, there aren't any apparent ways to produce gravitational fields without lots of mass and energy. The odds of such a way being found and being simpler than just spinning the craft to simulate gravity are rather slim.
